JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW door sill strip install.
Old Feb 21, 2016 | 01:14 PM
JIM_GRAHAM's Avatar
JIM_GRAHAM
I picked up two JCW door sill strips to replace the existing Cooper S strips.
Mini part number 51710305557.
They were $25.49 each from TheMiniPartStore.com
I removed the exiting sill plates with a heat gun and cleaned everything up. There is a trick that helps make a real finished look. Sand down the 4 little caps in the sill before installing. Otherwise you will have 4 small bubbles in the sill. I did not figure that out on the passenger side, but the drivers side is sorted. Thankfully I do not open the passenger door very often to remind me!
The new sills enhance the JCW look.
Old Feb 21, 2016 | 02:33 PM
TWISTER's Avatar
TWISTER
Thanks!
http://thebmwminipartstore.com/parts...?siteid=218365
Old Feb 21, 2016 | 03:31 PM
pjsjr13's Avatar
pjsjr13
Thanks for the link to the Mini Parts store
Old Feb 22, 2016 | 11:37 AM
When I put mine on you have to make sure the sill is very clean and the old foam tape is removed.
They really look good.
Old Apr 26, 2020 | 12:22 PM
Eurothrasher's Avatar
Eurothrasher
Weren't these designed to go over the top of the stock S metal plates ?
Why if you don't the clips underneith leave the lumps in these mylar covers....
Old Apr 26, 2020 | 12:53 PM
JackMac's Avatar
JackMac
Got excited for a minute about the price, then realized this thread was resurrected from 4 years ago.
Old Apr 28, 2020 | 08:24 AM
adamwilla's Avatar
adamwilla
This topic will be relevant a long long time )
Old Dec 12, 2020 | 07:14 PM
philwarner's Avatar
philwarner
The part number comes up as discontinued. Too bad - they did look good
Old Dec 12, 2020 | 10:35 PM
Black Forest's Avatar
Black Forest
Unobtainium
Old Dec 14, 2020 | 07:14 AM
Yep they are nla, You can use the newer logo ones here. Thats really the only replacement unless you find new old stock.
https://www.ecstuning.com/b-genuine-...h/51477406651/
jl46
Jun 25, 2018 05:20 AM
May 9, 2017 12:35 PM
cdavidell
Jan 21, 2016 01:49 AM
cdavidell
Jan 20, 2016 01:46 PM
Jan 18, 2016 10:38 AM
