JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Hood Scoop Melting ?
Old Apr 2, 2014 | 06:09 PM
Evil4130's Avatar
Evil4130
I run my car pretty hard on the street and on the track, haven't had anything melt just yet. But before anything could happened I prevented what may have happened. Problem solved for under $10, This is 4000 degree resistant material , should do the trick.
Attached Thumbnails Hood Scoop Melting ?-013.jpg   Hood Scoop Melting ?-012.jpg
Old Apr 2, 2014 | 06:31 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
I tried to get M7 to make one like that last year but using their thermal gel material and instead of the one they ended up making which is more of a Turbo blanket....
Nice job !
Old Apr 3, 2014 | 07:15 AM
ljmattox's Avatar
ljmattox
Looks great, almost OEM.
I need to patch/protect a spot on my bonnet liner where it's prone to rubbing through. What product did you find to use? Thanks!
Old Apr 3, 2014 | 08:34 AM
Evil4130's Avatar
Evil4130
I don't have any spots that are rubbing, but if I did I would use 3m anti slip material...usually found on metal stairs. It's cheap and works really well.
Old Apr 4, 2014 | 02:17 PM
ljmattox's Avatar
ljmattox
Ah, so clarifying, the spot where it's rubbing is right above the turbo. So that product you used seemed like it would be ideal for what I need. Can you let me know what you used? Thanks!
Old Apr 4, 2014 | 07:48 PM
Evil4130's Avatar
Evil4130
This is what I used. http://www.lockhartphillipsusa.com/HEAT-BARRIER.html
OutMotoring
Mar 3, 2017 06:29 AM
schr5530
Oct 5, 2015 08:28 AM
Colt45Magnus
Oct 1, 2015 04:08 PM
M7Speed
Oct 1, 2015 07:05 AM
mini merle
Sep 30, 2015 04:42 PM
