JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Underbody Paneling install
Old Feb 27, 2013 | 06:05 AM
  #26
I found these:
R55 Clubman Models.
http://www.ecstuning.com/Search/51752755791/ES240753/
http://www.ecstuning.com/Search/51752755792/ES240754/
More information:
http://www.motoringunderground.com/f...d.php?p=407985
Thanks and I hope that helps.
Old Feb 27, 2013 | 06:14 AM
  #27
BlueToy's Avatar
BlueToy
Hi Boys at ECS Tuning. I just ordered the 2 underbody panels from you. Is it possible for you to supply the fasteners I need? Can that be added to my order? Thanks for the help!
-Steven
Old Feb 27, 2013 | 07:04 AM
  #28
Bluetoy-
Great, thanks.
You can contact our customer service and they can help you out, and add things to your order. I can give you the part numbers :
Brackets : just incase you need them for modification.
This is for the left and right hand side panel set:
51752753165 Left rear bracket
51752753166 Right rear bracket
51161943122 x 20 plastic nut
07147117693 x 2 hex bolt with washer ( back braket )
07119904042 x 2 hex bolt ( back braket )
07130702966 x 2 expanding rivet
51712752360 x 2 filter head screw
Customer Service Hours: 8:00 AM to 8:00 PM EST 800.924.5172
Thanks and good luck on the install : post pictures when you get it all done, I would like to see this all complete.
Old Feb 27, 2013 | 07:14 AM
  #29
BlueToy's Avatar
BlueToy
Bluetoy-
Great, thanks.
Thanks for the help, I'm going to add the fasteners and brackets to my order I'll post pics of the install.
-Steven
Old Feb 27, 2013 | 07:49 AM
  #30
Steven - Thanks
Old Feb 27, 2013 | 03:31 PM
  #31
jkapinos's Avatar
jkapinos
Yes I got my order in as well. I figure not only is it good for aero, but also for keeping salt and sand out in the winter.
Old Feb 27, 2013 | 09:35 PM
  #32
toyopet's Avatar
toyopet
Do these underbody panels come with the 2013 JCW hardtop or the JCW GP or both?
Old Feb 28, 2013 | 02:35 AM
  #33
jkapinos's Avatar
jkapinos
Should be both.
Old Feb 28, 2013 | 06:12 AM
  #34
I have seen them in person on the pre-production MINI JCW GP II .
And for newer R56 LCI JCW MINIs it is on:
JCW Aerodynamics kit
Unless there has been some changes. Anyone who has a 2013 JCW without the JCW Aero bodykit could confirm this.
Old Feb 28, 2013 | 12:31 PM
  #35
toyopet's Avatar
toyopet
I know in the US the 2013 JCW hardtop comes with the aero kit. I would like to know if the underbody panels are included.
Old Mar 1, 2013 | 07:53 PM
  #36
M'Cooper's Avatar
M'Cooper
My 2013 MCS hardtop with the JCW exterior package did come from the factory with these under body panels.
Old Mar 12, 2013 | 04:55 PM
  #37
BLK-MCS's Avatar
BLK-MCS
Do these run almost the length of the cabin(underneath) or are they only about 500mm long?
Old Mar 12, 2013 | 05:04 PM
  #38
mattkosem's Avatar
mattkosem
Fantastic! Thank you. Interesting that it only runs up part of the body. At that price ($103 with fasteners), I'll definitely be grabbing a set of these. Are the fasteners the same as those that you posted for the R56?
--Matt
Old Mar 13, 2013 | 09:19 AM
  #39
SUPRAMO's Avatar
SUPRAMO
mine came with the underbody panel!!! mini cooper hot chili S 2007, why not every mini came with that?
Tomorrow ill be fitting the GP2 rear diffuser..
Old May 6, 2013 | 05:24 AM
  #40
lex76's Avatar
lex76
I have the 2010 JCW WC 50 and it came with the JCW aerokit. The underbody aero panels were not on my car. Should these panels be there on a stock 2010 JCW from the factory?
Old May 28, 2013 | 08:23 AM
  #41
hemisedan's Avatar
hemisedan
No, this part of the JCW GPII car.
Old May 28, 2013 | 08:27 AM
  #42
jkapinos's Avatar
jkapinos
I installed them this weekend in a Roadster. Two area's had to be trimmed but otherwise its an easy install.
Old May 28, 2013 | 08:31 AM
  #43
sooper_cooper's Avatar
sooper_cooper
ECS is now selling the belly pan that goes on the front as well:
https://www.northamericanmotoring.co...y-pan-kit.html
Old May 28, 2013 | 08:53 AM
  #44
jkapinos's Avatar
jkapinos
Yes ordered it already!.
Old May 28, 2013 | 06:44 PM
  #45
sooper_cooper
I need to order it as well along with the long underbody panels.
One of the many future projects on the list...
Put up some pics when you get the belly pan installed.
Old Oct 14, 2013 | 01:28 PM
  #46
Asquared's Avatar
Asquared
BlueToy - Thanks for the underbody shots.
I can tell you using the underbody panels for the R58 might be some work. First the rear section on the panels connects to the rear chassis center brace which is blocked by the additional supports which are on the R57 convertible and R52. Also near the center mid pipe square support would need some trimming.
Back by #5 and in the center by the inside cutout. Looks like there is enough room to slide under the brace to fit but it still might need removed and then re-installed , at least the outer arms.
Other then that it might work. Sounds like a DIY in the future Bluetoy. You do have the screw studs hanging down so it will receive the panel.
Can you help me out here? I'm about to instal the panels, and as I'm looking at the hardware, I notice that the brackets (# 51752753165 and # 51752753165) are not the same... not just mirror images of each other, but very different shapes. I've attached a photo.
Is this how they are supposed to be?
Thanks in advance for your help,
Alan
Old Oct 14, 2013 | 01:52 PM
  #47
Alan
Alan,
That's what my pics looks like, one bent more then the other.
I try to here, I know Bluetoy was attempting this on the R59 when I gave him the hardware above from the R56 platform to see if it would match up. Think he got it done, but I could not find the thread.
51752753165 is the left hand side , so facing towards the front of your MINI from the rear ( on the outside corner left hand side ) , this attaches to the back of the panel. Screw portion to the bottom on the panel. tab with holes forward.
http://www.ecstuning.com/Search/SiteSearch/51752753165/
51752753166 ( which is the right ) so facing towards the front of your MINI from the rear ( on the outside corner right hand side) , this attaches to the back of the panel. Screw portion to the bottom on the panel. tab with holes forward, wit the bend forward.
http://www.ecstuning.com/Search/SiteSearch/51752753166/
Thanks and hope that helps.
Old Oct 14, 2013 | 03:04 PM
  #48
Asquared's Avatar
Asquared
Alan,
Thanks so much ECS! Yes, these are exactly the brackets I have. I'm attaching photos taken from the perspective you present to help others who pursue this mod. Also, thanks for providing the orientation description with these brackets.
I really appreciate your help.
Oh, just one more question. I purchased my panels from my dealer and they supplied 18 plastic nuts (# 51161943122) instead of the 20 that you supply. Are 18 or 20 required with an R59 installation?
By the way, loving my JCW Leather / Carbon shift **** supplied by ECS.
Cheers,
~Alan
Attached Thumbnails Underbody Paneling install-img_3455.jpg   Underbody Paneling install-img_3457-001.jpg
Old Oct 15, 2013 | 06:33 AM
  #49
Alan,
You are welcome
Calls for ( 20 ) of 51161943122 according to the R58 diagram and above. I would get a couple more, better to have them then be short a couple plastic nuts.
http://www.ecstuning.com/Search/SiteSearch/51161943122/ES2673569/
"By the way, loving my JCW Leather / Carbon shift **** supplied by ECS."
Welcome again. Look good too.
Cheers,
~Alan
Old Oct 18, 2013 | 01:10 PM
  #50
Asquared's Avatar
Asquared
Thanks... took your sage advice and got two more!
