JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW 9000rpm engine rebuild has started!!
Old Aug 30, 2011 | 07:16 PM
  #51
mrrjm's Avatar
mrrjm
Originally Posted by PatM
Very nice Ray. This sounds like your having way too much fun
Yes sir!
Old Aug 30, 2011 | 07:17 PM
  #52
dez's Avatar
dez
Originally Posted by mrrjm
The rods and pistons are in. See the link....
http://gallery.me.com/mrrjm/100381
Ray
wow those look beautiful... love the comparison shots
Old Oct 13, 2011 | 03:29 PM
  #53
Performance Angst's Avatar
Performance Angst
any updates on this build?
Old Oct 26, 2011 | 08:14 AM
  #54
mrrjm's Avatar
mrrjm
I got the engine block and head back a couple weeks ago. I'm waiting on the Cam tools and clutch. Then we will start building the engine. I'll keep you updated. This has been a long slow process. Knowing what I know now I would have rather built an engine first.
Ray
Old Oct 26, 2011 | 09:26 AM
  #55
2009R56JCW's Avatar
2009R56JCW
Always start with the weakest link in the chain.
Old Nov 5, 2011 | 01:36 PM
  #56
oldbrokenwind's Avatar
oldbrokenwind
Ray, I seldom read the JCW portion of NAM, so I just now found this thread.
I've recently had the Giken clutch, light flywheel, and LSD installed. The flywheel is great at high rpm's, but combined with the GT28RS and its slow spooling, my low rpm performance is in the toilet. I'm learning how to slip their single disk clutch to compensate, but I can't imagine how you're going to slip their two disk clutch. I'm working with Jeff (Alta) to get a higher launch rpm, which seems to help, but it's still a work in progress. Hopefully, you plan to use this setup exclusively for the oval/track, not the 1/4 mile drags, so the low rpm performance shouldn't be an issue.
As for the Garrett, I hope you're prepared for some extra dyno work. Jeff and Tim (Cobb) working together spent over 3 hours tuning my setup. Well worth the all-day trip to Portland, OR, 'cause there's no local talent in Northern NV.
I'm gonna subscribe to this thread and wish you the best.
Old Nov 5, 2011 | 03:00 PM
  #57
mrrjm's Avatar
mrrjm
Thanks for the info. At this point I'm not even sure the GT28 project is still on the table. The reason is due to the EXTREME lack of communication and follow through of some people involved with the rebuild. With winter coming up I'm putting the engine back together with the Alta turbo and if time I'll install the Meth injection kit. The single disc OS Giken clutch I paid for at the beginning for Sept still hasn't arrived. The OS locking diff we installed last week end. And the Cam locking tool arrived yesterday. So next week the engine will get built.
I'm in the business and this rebuild is a walk in the park. Anyone planning on rebuilding the R56 engine I suggest rebuilding a core before you blow it up. The delays are not with the car or parts. It's with the people involved.
Ray
Old Nov 6, 2011 | 11:01 PM
  #58
MotorMouth's Avatar
MotorMouth
I've been working with Randy for over 15yrs.
I hope it's not another 15 before this project is finished!
Old Nov 7, 2011 | 09:30 AM
  #59
mrrjm's Avatar
mrrjm
Me too. But the problems aren't with the machine shop.
Ray
Old Nov 23, 2011 | 03:19 PM
  #60
countryboyshane's Avatar
countryboyshane
So much anticipation and now the project is practically dead. Say it aint so!
Old Nov 23, 2011 | 03:38 PM
  #61
6speedwtneed's Avatar
6speedwtneed
I hope this build finishes =]
Old Nov 23, 2011 | 06:09 PM
  #62
mrrjm's Avatar
mrrjm
It's not dead. Just got the OS clutch today. See the attached pictures of the throw-out bearing. This OS clutch makes the stock clutch look like a tin can.
So today I bolted the clutch on. Trans is bolted to the engine. Installed the turbo and oil lines. Attached the starter and verified we have oil pressure. Wife bought the Methanol and distilled water. Friday we will do the install. And hopefully have it running.
Attached Thumbnails 9000rpm engine rebuild has started!!-img_3664.jpg   9000rpm engine rebuild has started!!-img_3665.jpg
Old Nov 23, 2011 | 06:25 PM
  #63
mrrjm's Avatar
mrrjm
More pictures of interest.
Attached Thumbnails 9000rpm engine rebuild has started!!-img_3392.jpg   9000rpm engine rebuild has started!!-img_3396.jpg   9000rpm engine rebuild has started!!-rod.jpg
Old Nov 23, 2011 | 06:27 PM
  #64
mrrjm's Avatar
mrrjm
A few more.
Attached Thumbnails 9000rpm engine rebuild has started!!-img_3555.jpg   9000rpm engine rebuild has started!!-img_3593.jpg   9000rpm engine rebuild has started!!-piston.jpg
Old Nov 23, 2011 | 06:29 PM
  #65
countryboyshane
Looking good! Suscribed!!!
Old Nov 23, 2011 | 06:42 PM
  #66
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
What C/R are theese?
Old Nov 23, 2011 | 07:05 PM
  #67
mrrjm's Avatar
mrrjm
I'm told they are 10.1:1, Also we took .003" off the head. JCW stock is 10:1. So we have a slight bump in compression.
Old Nov 23, 2011 | 07:55 PM
  #68
Mike@Tech Division's Avatar
Mike@Tech Division
Yeah they are 10:1
Ray I'm glad to see you've made progress since we last talked. I rarely poke into this section of the forum so I was kinda in the dark on where your build was at.
Old Nov 26, 2011 | 08:47 AM
  #69
mrrjm's Avatar
mrrjm
After 12 hours yesterday we got it running and the Auqamist installed!! It not drivable yet. Still have things to finish up. The eng sounds really good. No noise at all from the forged pistons. The OS clutch doesn't feel heavy at all. We also installed the water/meth injector at the outlet of the intercooler.
Attached Thumbnails 9000rpm engine rebuild has started!!-img_3693.jpg   9000rpm engine rebuild has started!!-img_3692.jpg   9000rpm engine rebuild has started!!-img_3691.jpg
Last edited by mrrjm; Nov 26, 2011 at 08:49 AM. Reason: Was trying to put pics in the body. It didn't work
Old Nov 26, 2011 | 09:13 AM
  #70
Mike@Tech Division
Nice! Good job man. Can't wait to see how it does.
Old Nov 29, 2011 | 04:52 PM
  #71
ENGINE 58's Avatar
ENGINE 58
is that thing driveable yet ?
Old Nov 29, 2011 | 06:51 PM
  #72
mrrjm's Avatar
mrrjm
Yes it is. Put about 100 miles on it so far. Been trying to keep it under 10 psi. Though I've hit 15 twice. Runs great except for some cold driveability issues. I think because of 6 month old summer gas. I should have the tank empty in the next 2 days. I the Aquamist is in and set to kick in around 15 psi or so. It only activated a couple times briefly. I don't want to get on the throttle too hard until the engine is broken in a bit.
As this thread started my goal was "9000 rpm" That ain't happening right now due to valvetrain limitations. Supertech is working on springs and retainers. Also I'm using my Alta turbo not the GT28. I'm not going to do anything with the GT28 until at least Spring 2012.
I learned a lot about the car and engine during this rebuild. If anyone needs help or has questions ask away. I'll help however I can.
Ray
Old Nov 30, 2011 | 12:51 AM
  #73
khurley424's Avatar
khurley424
Id love to see/hear a video of this thing running. It sounds like a monster. Best of luck with the freshly built motor!
Old Nov 30, 2011 | 01:16 PM
  #74
ENGINE 58's Avatar
ENGINE 58
break er in and get er dynod lol and fill us all in
Old Nov 30, 2011 | 01:57 PM
  #75
oldbrokenwind
Ray
Talk to Jeff at Alta BEFORE you get too involved with the Garrett. Mine was about the 5th one he worked with, and he has a variety of war stories on the subject.
Again, best of luck with your project.
