JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Factory Jcw 2009 Build And Tuning Guide / Input / Explained
Old Mar 26, 2011 | 03:25 PM
  #26
MotorMouth's Avatar
MotorMouth
Very nice write up and pics!
I have to say though that I've never had a problem with the DSC kicking in at dangerous times.
Old Mar 28, 2011 | 02:43 PM
  #27
Fuel_Cap's Avatar
Fuel_Cap
This has just become my new favorite thread!!! You give precise comments and explainations...Keep it up! You give me a lot of ideas
Old Mar 28, 2011 | 03:20 PM
  #28
Douglas H's Avatar
Douglas H
Nicely done. Will watch your build.
Old Apr 7, 2011 | 02:48 PM
  #29
shams1924's Avatar
shams1924
part 2.95
2.95 Bonnet scoop vent mod.
If you take a look at the stock bonnet scoop vents. You may have noticed that the holes are blocked. Not all of them, but most of them are. So I thought. Cant be good for the engine heat.
not my pics!
The turbo being directly underneath it produces as much heat as the sun. so any additional air to the engine bay area will provide welcome relief and a breath of fresh air to the scorching surfaces found within. Although some may thing this is minor mod. Its still significant whereas its adding that much more cooling to an area in need of it. should provide a slightly better tolerance to heat when driving a bit spirited.
i decided to bore them all out with the help of my dremel mate. And after about an hour or two. It was done. Not that hard, the hard edges around the holes help, when carving out the holes.
10/10 free mod which add a bit more cooling to the engine.
Hmmm I like what some of the mini challenge teams are running....
Old Apr 7, 2011 | 03:05 PM
  #30
shams1924's Avatar
shams1924
part 3.1
PART 3.1
I done these next bit of mods in quick sucession. As they all complement each other so well, in regards to the installation.
Todo the front antiroll bars. You need to lower the subframe. To lower that subframe. You need to remove the zorst. So hey, why not add a miltek downpipe. You need to partially remove the wishbone arms. Why not add powerflex wishbone bushes.
Zorst removed entails easy access to gear **** underbody housing. Time to add a short shifter adapter.
3.1 Front eibach antiroll bar with alta endlinks
A great contribution to make compliment the jcw chassis. Holds the grip and transitions so well from left to right and sweepers. Car defo more planted and glued to the track a lot more.
Rear eibach antiroll bar with alta endlinks
Same as above. But the car feels like it wants to steer with the rear wheels. Meaning the grip is increased and the feeling more predictable and stable from bends.
8/10 if you stability and precision driving. Get these. Beware. Most people just install the rears as the front is a pain in the ****. Do them both to get the most out of your cars balance and complements both axles.
Old Apr 7, 2011 | 03:10 PM
  #31
MotorMouth's Avatar
MotorMouth
It's a real shame the aftermarket hasn't come out with a wire mesh that is a direct fit to replace the standard scoop grill.
If there is one I'd love someone to post a link.
Also, loving your work log.
Old Apr 7, 2011 | 03:12 PM
  #32
shams1924's Avatar
shams1924
3.2 front wishbone bushes. Powerflex.
From my limited experience. The r56 suffers from pitting and directional instability when pushing the brakes for fast stoppages. After taking off the wishbones with the rear arm. I noticed why. There is soo much flex in the rubber! About 1.5 inches from left to right, up and down in movement,
installed the powerflex poly bushes(pain in the **** to install)
Noticed when trying to flex them. Only about half an inch movement.
The wishbone bushes basically take all the chassis movement under braking and acceleration, where the suspension is concerned.
On the road difference?
Well. Just from these bushes, car feels soo different. You need to give it a few days for the rubber to settle down, under high and low temps. As it feels quite hard at first.
Once settled. Noticed much more stability under braking and acceraltion. And when you twitch from left to right. The response it exceptional.
8/10 must for performance driving. But a very hard install.
Old Apr 7, 2011 | 03:16 PM
  #33
shams1924's Avatar
shams1924
thanks
ill try to post a link to a replacement mesh. its a close match. just bought it myself for another project.
search this in ebay: "Aluminium Black Mesh Kamei Style 100 x 25 NKTuning"
Old Apr 7, 2011 | 03:48 PM
  #34
MotorMouth's Avatar
MotorMouth
Originally Posted by shams1924
thanks
yea, I know there are meshes you can buy and make fit. Just be nice if one of the aftermarket companies would pre-form everything so you don't have to rig it.
Old Apr 7, 2011 | 07:32 PM
  #35
Autoxser1975's Avatar
Autoxser1975
Excellent thread. I'm curious though, how much more rigid (harsh) is the ride with all the new suspension parts. Have you replaced the stock springs yet? Any issues with alignment or tire wear on the inside of the tire?
Old Apr 7, 2011 | 08:35 PM
  #36
Mini'mon's Avatar
Mini'mon
Thanks for sharing!
Everything is looking good. Thanks for sharing your modding adventures with the NAM community.
-Clint
Old Apr 8, 2011 | 03:51 AM
  #37
shams1924's Avatar
shams1924
thanks guys.
harshness? no. its quite stiff when you install poly bushes at first* note* at first. in the first few days. after that.the bushes settle down and you got a tidy handling chassis and no issues whatsoever in the ride comfort.
to need to allign as its a direct replacement of factory bushes. tyre wear for me the same across the pattern. my car is pretty new so no alignment issues anyway. so that helps.
regarding stock springs. i went to the marmaa mini run with stock springs and suspension. and was up against r53 with niice suspension setups. the r56 didnt let me down at all. i had to take wider and different point of attacks in the corners. but the stock s/s are decent.
ive just upgarded to meisters last week. will update soon. reason. after seeing the cars running coilovers didnt really need to move off their lane to take a sweeper. whereas i had to adjust my lines to make a fast bend. that was enuf for me to going for a track or very fast road setup.
hope that helps
Old Apr 8, 2011 | 03:52 AM
  #38
shams1924's Avatar
shams1924
-Clint
lol. yes clint how you doing. it was me who you sent that noise baffle to last week in the u.k
remember?
Old Apr 8, 2011 | 03:55 AM
  #39
Mini'mon's Avatar
Mini'mon
remember?
Yup. I remember. Looks like you're keeping yourself busy.
Old Apr 8, 2011 | 04:00 AM
  #40
shams1924's Avatar
shams1924
yes. theirs alot more to write up. then upload, format and post. takes time. sometimes i have an evening free and just post away. then leave it for a month.
for all you guys out there. ive done the D.O.S CAI.
<YES ALL OF THAT.
its that good. grrrrrr rooooaaarrrrrrrrrrrrrrrrrrrrrrrrrrRRRRRRRRRR GRGRGRGROOOAARR WHHiiine wiiiiiiiiiiiiiiiine TSHHHHHHH! tshHHHHSHSH
WILL UPDATE SOON.
Old Apr 8, 2011 | 04:56 AM
  #41
gothmdoc's Avatar
gothmdoc
This is a good idea, I'll probably do this as well.
Old Apr 12, 2011 | 10:38 AM
  #42
Fuel_Cap's Avatar
Fuel_Cap
If anyone would like to buy the same «bonnet scoop cooling vent» that you showed in the pict
It can be bought at minigenuineparts in the MINI challenge section...http://www.minigenuineparts.co.uk/mi...nge_Parts.html... just a tought!!!
Old Apr 15, 2011 | 02:15 PM
  #43
shams1924's Avatar
shams1924
thanks for that help. yes they sell it. but they seem to charge extortinate rates for the challenge parts
Old Apr 20, 2011 | 01:30 PM
  #44
shams1924's Avatar
shams1924
PART 3.3 miltek downpipe.
Stock down pipe is rated at 400cpi
Miltek is rated at 200cpi
Decat 0cpi
So it’s in between. Clears up restrictions in the airflow, whilst still cleaning the air. Still will pass an emissions test. Won’t fool the ecu tho. Regarding engine lights. Yes. You will get it. Cooper s or jcw. A remap should sort that out or a cheap code reader.
Easy install. Awkward to get the heat shield off.
Some healthy gains to be had here. Not dynoed but feels like 5-10bhp and 12ft torque.
The noise is now crazy!!!!!!!
Grrrrrrrrrrrkkkkkkkkkkkkk POP pap POP bang BANG POP!
The noise if im honest has gone up by 30% at least.
I’m not complaining, its soo addictive. To feather the throttle and ….. POP pap POP bang BANG POP!
The pops and literally speaking, the “BANGS”, are pretty loud!
And when you accelerate away, so throaty and deep roar, and just when you let off, really raspy.
What can I say… amazing! Amazing! Amazing!
9/10 but pricey.
And enjoy this lil vid just made:
Old Apr 20, 2011 | 03:20 PM
  #45
DneprDave's Avatar
DneprDave
What does CPI mean?
All I could think of is Concrete Pipe Institute, but that can't be right. The Miltek down pipe doesn't look like it's made of concrete.
Dave
Old Apr 20, 2011 | 07:09 PM
  #46
turtle343's Avatar
turtle343
Loving this thread i got a catted DP a few weeks ago and with the JCW exhaust it just totally changes the exhaust note of the car for the better. it pops so loud for me on every up shift.
Old Apr 20, 2011 | 09:16 PM
  #47
shams1924's Avatar
shams1924
Originally Posted by DneprDave
What does CPI mean?
Dave
cpi (cells per inch)
Old Apr 20, 2011 | 09:17 PM
  #48
shams1924's Avatar
shams1924
thanks. same here.
update**** video added to miltek downpipe post. WATCH IT.......... ;-)
Old Apr 20, 2011 | 11:46 PM
  #49
MotorMouth's Avatar
MotorMouth
thanks. same here.
the music ruins the video. I want to hear the exhaust. not rap.
Old Apr 21, 2011 | 06:11 AM
  #50
shams1924's Avatar
shams1924
sorry dude. my lil brother put it on. i said put a tune in the background and he did!
