JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Steering Feel
Old Aug 30, 2010 | 03:27 AM
Teibito's Avatar
Teibito
Steering Feel
Does anyone exerience a wandering feeling when getting feedback from the steering wheel? I get this mostly on the highway when accelerating. The car just seems to wander back and forth just a little bit.
I had the JCW suspension installed on the car just a short while after taking ownership, so I really can't say how it felt before the suspension upgrade.
However, compared to my '03 MCS, it does not feel like the sterring reponse is as precise. I also get the same wandering feeling when braking from high speeds.
I'm running Yokahama Advan Sports in 215/45 ZR17 trim. These are the third set of tires I have tried, (original run flats, all-seaons, and now summer only) and they are the best at reducing the wandering feeling and getting the car to track better.
I also seem to notice that if I have the car in sport mode and the wandering feeling starts to happen, it goes away when I take it out of sport mode. This leads me to believe that the electronic steering assist is what is causing the problem.
I'm taking the car into the dealer for an alignment, but I'm not sure this is going to fix the issue.
Any thoughts???
Old Aug 30, 2010 | 03:52 AM
slinger688's Avatar
slinger688
Did you get an alignment after installing the JCW suspension?
Old Aug 30, 2010 | 07:42 AM
Teibito's Avatar
Teibito
Yep, part of the cost of getting the JCW suspension installed at the dealer is 4 wheel laser alignment.
I've been reading some other posts that say the problem is due to the soft rubber used in the front control arm busings. Alta Performance has a replacement part which they say takes out the play.
Here's the link: http://www.altaperformance.com/produ...esponse-System
Old Aug 30, 2010 | 09:10 PM
Calz's Avatar
Calz
If your car is a 2003 and has not had the front A arm bushings replaced this could cause a numb feel in the steering wheel and some wandering. Its very easy for a shop to test these bushings the vehicle is on a hoist. Usually the rubber falls apart anyways and then they will need to be replaced.
Old Aug 31, 2010 | 12:53 AM
slinger688's Avatar
slinger688
I think he is talking about his 2009 JCW with the new JCW suspension.
Old Aug 31, 2010 | 03:21 AM
Teibito's Avatar
Teibito
JCW retrofit
Well, I did a little research and believe it may be related to the electronics in the steering system. MINI has changed the programming that controls the steering on the new 2011 JCW models.
They may offer this as a dealer retrofit (software upgrade) for the 2008-2010 JCW cars. Here is the link to the article.
[FONT=Arial]http://www.motoringfile.com/2010/08/24/mini-may-offer-torque-steer-elimination-retrofit-poll/#more-12978[/FONT]
Old Sep 1, 2010 | 03:46 PM
Teibito's Avatar
Teibito
I feel stupid
I just got a 4 wheel laser alignment at the MINI dealer and the steering issue is resolved.
It was so out and pulliing to the right, that I constantly needed to pull the wheel to the left to correct it.
I would highly reccommend an alignment at least once a year or whenever you put new tires on.
Cheers!
Old Sep 1, 2010 | 03:52 PM
timfitz63's Avatar
timfitz63
Cheers!
Yeah, aren't those Pennsylvania roads wonderful...? On this end of the state, we drive in the potholes and avoid the chunks of road...!
rob&JCW
Feb 13, 2023 07:03 PM
theblackfalcon
Oct 11, 2015 09:49 AM
sevin
12
Sep 4, 2015 01:50 PM
xpunisherx
Aug 10, 2015 10:50 PM
