JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW JCW kit on plastic ramps??
Old Aug 24, 2010 | 07:01 PM
ALSCRX's Avatar
ALSCRX
I would like to buy a set of Rhino ramps to do my oil change, but not sure if it will clear the JCW front bumper.......anyone done this?
Please share if it works or if bumper scrapes the ramp.
Thanks!
Old Aug 25, 2010 | 06:35 AM
wellard's Avatar
wellard
I personally jack up the car and slide the ramps under each wheel. In my opinion it's safer that way.
Ed
Old Aug 25, 2010 | 02:22 PM
ALSCRX's Avatar
ALSCRX
I was trying to avoid using my jack at all. I always use the jack and stands on my other cars, but i am getting tired of that now. I want it easy,lol....plastic ramps are light.
Old Aug 25, 2010 | 02:26 PM
Bigprfed22's Avatar
Bigprfed22
i have the jcw kit and use ramps, i have to put a piece of wood before the ramp to give it a little extra raise
Old Aug 25, 2010 | 03:40 PM
wellard's Avatar
wellard
I hear you. I've had ramps slip a couple of times, so I tend to use the jack method with the ramps, although it does take longer.
Old Aug 25, 2010 | 06:02 PM
Speedwing's Avatar
Speedwing
I also use a 2 x 6 - about 18" long in front of the ramps. My Rhino ramps have a rubber bumper in the bottom and do not slip on my pavement.
Old Aug 27, 2010 | 06:42 PM
ALSCRX's Avatar
ALSCRX
The rhino ramps have a 17 degree incline and under 50 bucks.
Race ramps are 10 degree but cost 200 bucks!
Old Aug 28, 2010 | 04:28 AM
richardsperry's Avatar
richardsperry
Put a lift in the garage, that's what I did...lol
You will probably have to use a pair of 2x6's or 8's to use ramps
Old Aug 28, 2010 | 05:02 AM
Herleman's Avatar
Herleman
I've had a JCW on my rhino ramps -- no issue. And I've found that I can butt the ramps up against the edge of my garage floor (from the driveway) and they don't have a chance of moving.
Unless your JCW is lowered the ramps should work fine (mine were $39 @ Wallyworld).
Old Aug 28, 2010 | 07:40 AM
ALSCRX's Avatar
ALSCRX
Cool, thanks!! I am stock height and most likey gonna stay that way.
Old Aug 28, 2010 | 08:13 AM
DneprDave's Avatar
DneprDave
Or move next door to a guy with a lift in his garage, that's what I did!
Dave
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Aug 7, 2015 09:51 AM
