JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW JCW Sport Brake kit installed on 2007 MCS
Old Apr 1, 2009 | 05:51 PM
scottab36's Avatar
scottab36
The JCW Sport Brake Kit went on yesterday. It is a very straight forward installation and it looks amazing.
I had no issues with the E-Bbrake hookup. That was a relief; everything hooked right up and went together smoothly.
I highly recommend the Motive Power Bleeder for this or any brake work where you will be working with the fluid. It saves you so much time and thoroughly bleeds the system leaving no air behind.
One quick note, you will be adding 2 pounds per rotor on the front and 1.5 pounds per rotor on the rear of the MINI.
Old Apr 2, 2009 | 07:48 AM
ImCBParker's Avatar
ImCBParker
Looks great Scott. I plan on upgrading mine at the first change. Thanks for sharing pics.
Old Apr 2, 2009 | 06:48 PM
bgregg's Avatar
bgregg
Good job, nice pics! How was the first test drive afterwards?
Old Apr 2, 2009 | 07:37 PM
scottab36's Avatar
scottab36
The first drive after new brakes is never good. They always feel weak. I should have them "broken in" tomorrow and plan on putting them through the twisties!
Old Apr 3, 2009 | 03:03 AM
pw4's Avatar
pw4
I had the front-only JCW brake kit fitted last week. The extra weight is quite noticeable in the steering, which surprised me. It's not just me either - my 20yo son - who reckons he can't tell the difference whether the sport button is on or not - had a drive and asked if the steering was heavier than usual. Tyre pressures and alignment are all OK, so I can't put it down to anything except the heavier brakes. (Mine's a JAC, so the difference in weight might be greater.)
Old Apr 3, 2009 | 07:09 AM
scottab36's Avatar
scottab36
That is odd... The front only JCW Brake Kit is the same size rotor as the factory rotor so it should not be any heavier. I have not noticed any difference with regards to my steering.
Old Apr 3, 2009 | 10:28 AM
Luv325Ci-MiniCoopS's Avatar
Luv325Ci-MiniCoopS
Just Curious,
How much is the JCW brake kit? this is something I would like to put on my MCS
Old Apr 3, 2009 | 10:34 AM
galoki's Avatar
galoki
Pictures of Minis in motion are way cooler then pictures of Minis parked!
However, moving pictures of Minis in motion are way cooler then pictures of Minis in motion.
Old Apr 3, 2009 | 10:36 AM
galoki's Avatar
galoki
sorry... meant to post that in random thoughts... clicked the wrong link
Old Apr 3, 2009 | 12:45 PM
mellowmcs's Avatar
mellowmcs
what kind of paint did you use to paint the rotor hats?
Old Apr 3, 2009 | 01:29 PM
Bullitt44's Avatar
Bullitt44
"Bullitt"
you will love'em
Old Apr 3, 2009 | 02:50 PM
scottab36's Avatar
scottab36
Originally Posted by Luv325Ci-MiniCoopS
Just Curious,
The full kit runs $1,999.00 but I got mine for $1,600.00 with a discount through the MINI dealer
http://www.trademotion.com/partlocat...egoryID=139115
I do not know how much the install is as I did the work myself. It did cost $135.00 to get the ECU re-flashed for the new brake kit.
Old Apr 3, 2009 | 02:52 PM
scottab36's Avatar
scottab36
I used a high-temp red caliper paint from DUPLI-COLOR. It's available in most auto parts stores. They came already primed grey so it only made since to paint them RED!
Old Apr 3, 2009 | 06:14 PM
pw4's Avatar
pw4
Originally Posted by scottab36
The full kit runs $1,999.00 but I got mine for $1,600.00 with a discount through the MINI dealer...
I got a similar discount through my MINI dealer, so you should ask for one! (Weirdly, the discount meant waiting until the end of the week when the order went through their weekly stock order rather than a one-off )
Old Apr 3, 2009 | 06:18 PM
pw4's Avatar
pw4
That explains it! The rotor is a LOT bigger than the standard Cooper rotor.
(Mine is a Just-A-Cooper - and the base wheel size is only 15" which the JCW brakes certainly wouldn't fit inside - in fact, it looks like they would be a tight fit on 16"s too.)
Old Apr 13, 2009 | 04:36 PM
scottab36's Avatar
scottab36
Spot on!! The Cooper-Lite front brakes are smaller than the Cooper "S" brakes. Yes a MINI 16" wheel will will fit but not the 15" MINI wheels.
Old Apr 19, 2009 | 04:33 PM
scottab36's Avatar
scottab36
Just an update with the new wheels!!!
Old Apr 19, 2009 | 05:46 PM
drsilvermini's Avatar
drsilvermini
What size wheels are those? Those brakes look huge!
Old Apr 20, 2009 | 02:59 AM
scottab36's Avatar
scottab36
The wheels are 17X7 O.Z. ALLEGGERITA HLTs.
At 14.2 pounds each they weigh 8.5 pounds less than factory wheels I replaced.
It's a noticeable difference in braking, acceleration and handling.
The factory R104s wheels will now be my winter wheels.
Old May 1, 2009 | 03:01 PM
Augie05's Avatar
Augie05
Is this for all four wheels? The Morristown site does not say ....
Old May 1, 2009 | 04:55 PM
scottab36's Avatar
scottab36
Yes, the kit is for all four wheels. Everything is bigger and badder!!
Old May 1, 2009 | 06:33 PM
Augie05's Avatar
Augie05
Sounds great. I read somewhere that the brakes are a lot heavier than stock and that the steering wheel was noticeably harder to turn.
What do you think? Do they add to the unsprung weight?
Old May 2, 2009 | 06:33 AM
scottab36's Avatar
scottab36
I did not notice that the steering was heavier.
Each front rotor is 2 lbs heavier than the ones they are replacing.
Each rear rotor is 1.5 lbs heavier than the ones they are replacing.
I compensated this weight gain buy purchasing wheels that were 8.5 lbs lighter than my factory wheels.
This reduction of rotating mass weight is a huge change for the MINI. Better, braking, better acceleration, better handling.
Old May 3, 2009 | 06:15 AM
pw4's Avatar
pw4
What you read about heavier steering might be my comment further down in this thread. But I was replacing Cooper (non-turbo) brakes, and the standard Cooper discs are smaller and lighter. The difference is less than the Sport button makes - it's noticeable but not a problem.
Old May 4, 2009 | 03:38 AM
jayxx83's Avatar
jayxx83
Brakes look awesome dude. i swapped out my 18" R95's for 17x7 Oz Super T GT's yesterday. The car is totally transformed and much more mpg now as a bonus!
Car feels like it glides along the road now.
