JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW New JCW Brake Kit Questions
Old Aug 1, 2008 | 09:47 AM
Wolfshiem's Avatar
Wolfshiem
I've searched but I cannot find a good answer.
Does anyone know when the new JCW Brakes will be available for the R56 S?
Also, with which wheels are they compatible--17" Web-spokes?
Old Aug 4, 2008 | 01:25 PM
Wolfshiem's Avatar
Wolfshiem
Too soon?
Old Aug 4, 2008 | 02:05 PM
mellowmcs's Avatar
mellowmcs
I would say too soon. I'm also waiting for this to be released as well.
Old Aug 4, 2008 | 02:40 PM
rkw's Avatar
rkw
These are the officially approved wheels:
Originally Posted by PARTSMAN
This from the John Cooper Works Accessories bulletin...
Please note: The limitation in wheels is not only caused by the larger diameter of the brake discs, the new brake caliper is also wider, which requires a specific design of the wheel spokes to allow for enough clearance. Please do not install any other wheels other than the ones shown in the enclosed listing. These are the only approved wheel styles by MINI for these vehicles.
The list...
R97 Flame Spoke
R104 Crown Spoke
R108 Multi Spoke
R112 Cross Spoke Challenge
R113 JCW Cross Spoke
Old Aug 4, 2008 | 02:56 PM
Augie05's Avatar
Augie05
What about larger aftermarket wheels? SOL?
Old Aug 4, 2008 | 03:42 PM
rkw's Avatar
rkw
MINI won't measure or test any aftermarket wheels. You're on your own.
Old Aug 4, 2008 | 03:54 PM
NZ_M3's Avatar
NZ_M3
Have priced a full set up here locally in New Zealand and the cost is going to be ridiculous I am afraid to say - circa north of US$5,000.00 here retail.
Old Aug 4, 2008 | 04:12 PM
Wolfshiem's Avatar
Wolfshiem
Five large would be quite the hurdle.
I had been working on the assumption that the upgrade would be in line with the price from the factory ($1395 IIRC) plus labor. However, if new wheels are in order, it would certainly make it much more expensive.
Old Aug 4, 2008 | 06:03 PM
NZ_M3's Avatar
NZ_M3
That pricings was only for parts .... and apparently was at a staff rate discount too.
Old Aug 4, 2008 | 08:10 PM
fignewton's Avatar
fignewton
I talked to Will today at Morristown Mini about these. He gave me a part number for the kit, which includes the 4 rotors and calipers. He said it would be around $1,600 he thought. I'm traveling and don't have the part number with me, but will post it on Thurs when I get back, or you can call him direct.
Fig
Old Aug 4, 2008 | 08:12 PM
Doc Cooper's Avatar
Doc Cooper
$1600... hmmm how much better are these brakes compared to OEM MCS brakes...
Old Aug 4, 2008 | 08:59 PM
rkw's Avatar
rkw
It was reported to be 1780 euros in Germany.
Originally Posted by Baraka
About the brakes... yesterday I went to my dealer and found out a few interesting things.
In Germany we have a part number (34 11 0 432 802) for the complete retrofit brake kit (front and rear).
R56 MINI Cooper S (stock)
front: 294 mm (= 11.5748031 inches) brake disc diameter
rear: 259 mm (= 10.1968504 inches) brake disc diameter
R56 MINI John Cooper Works (retrofit brake kit)
front: 316 mm (= 12.4409449 inches) brake disc diameter
rear: 280 mm (= 11.023622 inches) brake disc diameter
The price tag is 1,780.00 Euros (~2,820 $US).
Have a guess what's going to happen once I sell my motorcycle ... the cash will be spent for... anyone guessing?
Old Aug 4, 2008 | 09:19 PM
diablito's Avatar
diablito
They are Brembo with a JCW logo...A set of brembos is at least $2600.00 plus these have the JCW logo on them so add another $500 for that plus MINI part another $500 ..maybe I am getting closer to the price.
They are super stoppers, comparing them to the OEM or even the JCW brake kit is like comparing a....well there is no comparing them.
If you have a MCS and wish the JCW brakes...just get out of your MCS and order a JCW, unless you have silly money then is all good.
Just a reality check.
Old Aug 5, 2008 | 12:02 AM
ghosthound's Avatar
ghosthound
wow, they are actually brembos? i just thought they were generic "bmw" calipers.
Old Aug 5, 2008 | 12:05 AM
Robin Casady's Avatar
Robin Casady
Sincere questions: How much use on an MCS are better brakes?
Do you have put wider tires on it to make use of the extra stopping power? Can they shorten braking distance with 204/45-17 tires? Or, is it something that just becomes useful with racing use of brakes?
Old Aug 5, 2008 | 12:24 AM
mellowmcs's Avatar
mellowmcs
Honestly brembo etc BBK doesn't help you stop any faster. Robin you have it right in that your tires would be a big limiting factor as would the brake pads.
What these BBK and bigger rotor/calipers give you is a big resistance to fading. However in my experience, proper cooling can go a long ways to combat fading than BBK and much cheaper as well.
Me personally I'll probably go with some kind of BBK just because I want them and for no other reason.
Old Aug 6, 2008 | 09:32 AM
fignewton's Avatar
fignewton
This is the same part number that Will gave to me; rotors are 316x22mm (12.4" dia), and he said the price from Morristown would be around $1,600.
Fig
Old Aug 6, 2008 | 08:40 PM
diablito's Avatar
diablito
I can't tell you how much better the brakes are, I have only test drive the JCW hardtop for 3 miles, I will be getting mine by the weekend, and I will run more...The only thing I have to say is that the brake feel is better and I did brake hard entering a corner at moderate speed and the MINI just follow beautifully, I have the JCW set-up with SS braided hoses on my MCS w/JCW Tuning kit, an doen not even compared to the bigger set up. Now I think the big difference will be seen after hard braking on the track, the regular JCW brake kit will tired sooner and brake fade will be apparent.
AND if it's true that one can aquired these brakes for a mere $1600 bucks, wow I will put a set on my MCS too, the looks alone is tops.
elightbo
Aug 17, 2015 01:50 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
