Interior/Exterior removing side grills
Old Feb 19, 2007 | 10:59 PM
DjR53's Avatar
DjR53
anyone know how to remove it, i wanted to paint it black not the S but the chrome of the grill
Old Feb 19, 2007 | 11:14 PM
COR BLMY's Avatar
COR BLMY
Push OUT (from inside the engine bay) at the FRONT of the grill.
Then once poped out slide it forward a bit.
I have noticed they can be a bit "loose" when replacing ... so just a touch of silicone will hold when installed and it drys
Old Feb 19, 2007 | 11:20 PM
DjR53's Avatar
DjR53
thanks man good tip too!
Old Feb 20, 2007 | 06:47 AM
ImagoX's Avatar
ImagoX
Along these same lines, has anyone tried spraying the turn-signal lens with tail-light black-out material? I know that they make a replacement, black lens, but it's clear, not "knurled" inside like the OEM lens and I don't like that you can see the bulb.
Old Feb 20, 2007 | 10:40 AM
COR BLMY's Avatar
COR BLMY
Mine above is tinted with film (RED)
I will be doing my sons this week in smoke / dark smoke
We use the heat streach film NOT regular window tint.
I'll post and if you want I could help
Old Feb 20, 2007 | 10:51 AM
ImagoX's Avatar
ImagoX
Whrre do you get such film? Sounds like just the thing I need.
Old Aug 8, 2007 | 03:44 PM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
How do you remove the S from the vent?
Old Aug 8, 2007 | 03:46 PM
glnr13's Avatar
glnr13
pull off the ring/clip that's holding it in
Old Aug 8, 2007 | 03:51 PM
littlehandegan
Hmmm not sure what your refering to....i have already removed the black grill on the back but cant seem to get the s>?
Old Aug 8, 2007 | 03:53 PM
littlehandegan
Ok nevermind i got it...thanks for the quick help!!!
Old Aug 8, 2007 | 05:46 PM
littlehandegan
Man it looks good...decided to take the little grills and paint them red and leave the red S...will post pictures
Old Aug 9, 2007 | 06:22 AM
minjae's Avatar
minjae
pictures definitely.
but wat paint are you guys using?
Old Aug 9, 2007 | 06:45 AM
thulchatt's Avatar
thulchatt
I used a paint for plastics. I can't remember brand but I don't think it will matter much. No prep except disassembly and tape over the red part of the S, I did not remove the S to paint. I have had it on over a year and no problems yet.
Old Aug 9, 2007 | 06:58 AM
edubledie's Avatar
edubledie
the red part is only a red sticker ....i took the red part off
Old Aug 9, 2007 | 07:00 AM
edubledie's Avatar
edubledie
heres a pic of mine
Old Aug 9, 2007 | 07:04 AM
Loony2N's Avatar
Loony2N
Do the ones on the R56 come off the same way?
Old Aug 9, 2007 | 07:32 AM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
Here you go.
https://www.northamericanmotoring.co...d.php?t=105573
Old Aug 9, 2007 | 08:28 PM
mini d's Avatar
mini d
OK I tried pushing out on the front of the side grills and darn near pushed a crease in my fenders! Are you sure you just push out? I am assuming you just scuff the chrome with some fine grit sandpaper right? What type of primer and paint are you using? Specifically COR BLMY and golden child, you guys have nailed the look I am after.
Old Aug 10, 2007 | 12:09 AM
FlyingSmiley's Avatar
FlyingSmiley
There is a little tab on the front that they clip into. Its pretty tight the first couple times you remove it. If its loose on the reinstal then push the tab back a little bit and that will tighten it up and no adhesive will be needed.
Smiley
boostedhaze
Jan 2, 2018 07:26 PM
ltjpunk7
Sep 6, 2015 07:32 AM
cm.d
Aug 19, 2015 08:51 AM
