Interior/Exterior Black Eyed Jaundice
Old Jan 1, 2007 | 04:49 PM
slvrmni03's Avatar
slvrmni03
Black Eyed Jaundice
I decided to Lamin-x my headlights and vinyl my headlight rings during the holiday break. Different, huh?
Old Jan 1, 2007 | 05:00 PM
thulchatt's Avatar
thulchatt
How did you do the rings?
I am wanting to do the same but unsure if I should take the lights out to do it or with them in.
Do share.
Old Jan 1, 2007 | 05:04 PM
not-so-rednwhitecooper
the rings pop off of the headlight pretty easy.
you have to take the headlight off the car to do it but its really easy.
Old Jan 1, 2007 | 05:15 PM
slvrmni03's Avatar
slvrmni03
I chose to remove the headlights. They are only held on by three nuts on each so it isn't a big deal. With the lights out you can remove the headlight rings. There are three small tabs on the bottom of the ring and three larger ones on the top. Leave the top tabs alone and pry the bottom tabs out to release the ring. After those three tabs are loose push out on the ring to remove it from the headlight housing. There is double sided tape on the back of the ring so it will resist a little. Don't try to pry the top tabs because they will break off. When you apply the vinyl, start from the top and work your way down peeling off the backing as you go. You will have to cut out some material from the bottom to get it to join up properly.
I think removing the rings is a necessity to get the vinyl to fully wrap around the inside and outside of the rings. I got my vinyl sheet from a sign shop for $3 a yard. Good luck!
Old Jan 1, 2007 | 08:53 PM
robino's Avatar
robino
what do you scuff the rings with?
what do you paint the rings with?
Old Jan 1, 2007 | 08:58 PM
Motor On's Avatar
Motor On
They're vynl if I'm reading the posts right.
There is another PS Cooper with a very similar look on the boards.
How do you like hte lamin-x planning on doing the same here shortly.
Old Jan 1, 2007 | 08:59 PM
slvrmni03's Avatar
slvrmni03
I didn't scuff the rings with anything. Just cleaned them really well with alcohol and soapy water. I used a sheet of flat black sign vinyl to cover them, I thought it would be less chip prone and easier to reverse/repair than paint
Old Jan 1, 2007 | 09:02 PM
ImagoX's Avatar
ImagoX
I used vinyl on my grille exactly like Slvrmni03 did on his rings and you don't need to scuff them, just like he said. Just clean 'em really well and apply the vinyl using the "wet" application technique and a squegee to remove all air bubbles - the resulting bond is smooth and very strong. That way, if you do decide to reverse it next year, you'll have no issues.
Oh, and remember to treat the vinyl with Rubber and Vinyl protectant (whatever you use on your black trim) - UV will fade and blister the material over time and taking an extra 5 minutes once or twice a month to treat the vinyl along with your trim will keep it black, supple and wrinkle-free.
Old Jan 1, 2007 | 09:26 PM
slvrmni03's Avatar
slvrmni03
I like the Lamin-x. There is a slight haze in spots but I am hitting it with a hair dryer and it seems to be dissipating. Overall, I think it is a good product and I was surprised how easy it was to work with once I got some heat into it. I just wished that I would have done it earlier as the surface of my four year old headlights was looking pretty rough.
Motor On, what color are you going to put on your headlights?
Old Jan 2, 2007 | 12:48 AM
Motor On's Avatar
Motor On
I'm planning on paint matching the chrome surrounds to JB then putting yellow lamin-x over the head lamps. I've been wanting to do this for a while however I'm holding off until I add 2 for and 2 driving lamps which I'm holding off on doing until I have the aero grill. So that way I remove the majority of fron end chrome (If you check the gallery in my sig I'm in the process of a majority blackout) have the contrast from the yellow headlamps (I plan on doing yellow bulbs in the fogs I add on) and still have some nice bright white light I can throw down the road when I getin the boonies where its real dark.
So I'm at the point I pretty much have every detail planned out and I'm approachig time for action real soon.
Old Jan 2, 2007 | 04:02 AM
slvrmni03's Avatar
slvrmni03
That is going to look really cool when you are done. My blackout is almost complete, all I really have left are those pesky door handles and my shiny hood emblem where the logo came off.
Old Jan 2, 2007 | 10:04 AM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
I have the yellow tint Lamin-X on my factory rallys. Been on for about 3 years and I love it. Looks almost like daylight color when I turn on the rallys.
Old Jan 2, 2007 | 01:11 PM
slvrmni03's Avatar
slvrmni03
I like your alternating stripes. Too cool!
Old Jan 2, 2007 | 01:26 PM
MiniMaxx's Avatar
MiniMaxx
Does anyone have the yellow Lamin-X over Xenons?; especially 05+ Xenons?
How does it look lights on? Does it noticeably reduce the amount of light thrown down the road? I like the look when off but don't want to compromise the excellent illumination of the Xenons.
Old Jan 3, 2007 | 10:35 AM
COR BLMY's Avatar
COR BLMY
Very nice
(Agro, your headlights would look GREAT in yellow)
Please help me locate the yellow "lamin-x" product
Old Jan 3, 2007 | 03:46 PM
Agro's Avatar
Agro
Right here at http://www.lamin-x.com/
Old Jan 3, 2007 | 05:45 PM
COR BLMY's Avatar
COR BLMY
Thanks for the info
Ordered YELLOW
And I will de-chrome with black (I'll go shopping tomorow)
Old Jan 3, 2007 | 06:43 PM
slvrmni03's Avatar
slvrmni03
That will look killer. Good luck with it. BTW Your rockcrawler's cage is INSANE!
Old Jan 3, 2007 | 10:22 PM
COR BLMY's Avatar
COR BLMY
I'll post as soon as done
the "Toy" is for sale
http://sfbay.craigslist.org/eby/car/256075273.html
I have even MORE CRAZY IDEAS fro the next rig
Old Jan 4, 2007 | 05:17 AM
Yucca Patrol's Avatar
Yucca Patrol
I love yellow lights too. I used PIAA Ion-Crystal bulbs for my high beams and one day want to get the same in my rally lights.
Getrieben
Sep 12, 2024 07:03 AM
chandler_vt
Apr 29, 2017 08:08 AM
WayMotorWorks
Aug 4, 2015 01:47 PM
