Interior/Exterior Angelina Got A Nose Job.
Old Dec 12, 2006 | 07:07 PM
goaljnky's Avatar
goaljnky
Sorry about the crappy pics and the dirty car, but I couldn't wait to show off.
Old Dec 12, 2006 | 07:11 PM
ChrisW's Avatar
ChrisW
Nice that looks good
Old Dec 12, 2006 | 07:23 PM
MINI Monkey's Avatar
MINI Monkey
Very Nice!
Old Dec 12, 2006 | 09:23 PM
kenchan's Avatar
kenchan
ooo... M7 lip on aero kit.. nice. is that easy to clean? might be one
of the last pieces i might buy for my MCS.
btw, is this your 2nd MINI?
Old Dec 12, 2006 | 09:45 PM
goaljnky's Avatar
goaljnky
Thanks all.
Kenchan: The splitter is easy to clean. Just wipe it dry, otherwise it does trap some water. Make sure to put some washers (preferably black) at the mounting points. Mine don't have them (not sure if it came with them, someone else did the install) and the CF is now cracking a little bit. Just haven't had the time to address the issue. And yes, that is a second Mini. We are a two Mini household.
Old Dec 12, 2006 | 09:49 PM
kenchan's Avatar
kenchan
Originally Posted by goaljnky
Thanks all.
nice! thanks for the info on the black washers. i'll probably
put either a grommet or faucet rubber seal between there, then a
metal (black) washer to prevent it from cracking.
water trapping is no issue for me, i'll just use a leaf blower. car
doesn't get wet much anyway.
Old Dec 12, 2006 | 09:55 PM
pberry51mini's Avatar
pberry51mini
No Fear Gear
Any of your cars lowered?
Any rubbing of the diffuser or do you end up having to drive like Granny?
Old Dec 12, 2006 | 10:13 PM
cooper99's Avatar
cooper99
I was expecting to see a picture of Angelina Jolie; anyway, supurb looking MCS.
Old Dec 12, 2006 | 10:46 PM
goaljnky's Avatar
goaljnky
Both my cars are lowered. But I assume you are asking about the one with the splitter. No, no rubbing. And I have some nasty speed bumps at work. I scrape a little coming out of some driveways, which has ground down the screw that protrudes at the bottom of the splitter, but otherwise there are no other ill effects.
Old Dec 12, 2006 | 11:08 PM
MINIclo's Avatar
MINIclo
7th Gear Gal
Looks great, Jinkie!
Old Dec 15, 2006 | 09:36 PM
MINI Monkey
Thanks all.
Could you photograph or tell me exactly where the installed washers should be. I used some washers but wanted to see where you used them incase I have missed a key spot. Thanks!
Old Dec 21, 2006 | 08:32 AM
goaljnky's Avatar
goaljnky
I can show you where I would put them. Still haven't done it. I will take some pics over the weekend. Not able to do it till then.
Old Dec 21, 2006 | 08:39 AM
ProfessorDave's Avatar
ProfessorDave
Very nice! I love the two-toned interior against the BRG and silver, too.
R3411y
Nov 23, 2015 01:10 PM
Oct 1, 2015 12:13 PM
jennster
Sep 28, 2015 06:19 PM
Sep 24, 2015 07:58 AM
Sep 24, 2015 07:56 AM
