Interior/Exterior Toggle Panel Mod
Old Nov 14, 2007 | 02:09 PM
  #26
Big Daddy's Avatar
Big Daddy
Originally Posted by midMOmini
that is amazing, where did you happen to get the stock looking switch at?
Lots of people part out their old toggle panels when they buy a new one. Just keep your eyes open in the Marketplace.
Old Nov 14, 2007 | 03:59 PM
  #27
GBMINI's Avatar
GBMINI
Originally Posted by Big Daddy
The LED is already installed in the toggle panel.
You must have been lucky.
I've seen 5-10 toggle panel circuits and in every case, the LED was not fitted if the switch was not fitted.
Old Aug 16, 2010 | 08:50 AM
  #28
ranczar's Avatar
ranczar
Big Daddy,...did you ever get the rear fog activated by the dealer? I'm considering this, and wondering what they charge for the activation of the toggle switch.
I've disassembled my panel and have seen that mine (from a 10/06 build R52), unfortunately, lacks the LED to illuminate the toggle, so even if I drilled a hole in my toggle, there wouldn't be an indicator light.
Thanks.
Old Aug 16, 2010 | 10:17 AM
  #29
greekzilla's Avatar
greekzilla
Thanks.
I paid around $90 at Motor City Mini to activate the rear fog. That didn't inlclude installing the new toggle panel.
Old Jul 23, 2015 | 09:20 AM
  #30
brandongoranson's Avatar
brandongoranson
Dummy Switches
[QUOTE=Big Daddy;1251028]I had also purchased a couple of dummy switches a while back and pulled them out to see if I could at least fill up the panel. When I started looking closely, I realized that the existing fog switch had a hole in the end for an LED to shine through. I also noticed that one of the dummy switches was the same
Can you tell me where to find these switches? Been looking for quite a while and all I can find are the ones for R56 and newer. No R53 in sight.
Thanks!
Old Jun 23, 2016 | 08:41 AM
  #31
intarazm's Avatar
intarazm
Great job, could you explain how did you even open it ??? seem like the pins will break before letting go...
Old Jun 30, 2016 | 12:59 PM
  #32
Eric_Rowland's Avatar
Eric_Rowland
It comes apart pretty easily. Just press on the body while lifting up on the tab, either top or bottom.
Old Jun 30, 2016 | 01:28 PM
  #33
intarazm's Avatar
intarazm
Got it !!!
I was able to open it.... here are some pictures, now the problem is to change the icons to match the switches....
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
GAT
Oct 4, 2015 07:27 PM
eMINI of the State
Oct 2, 2015 03:12 PM
DTIREY
R55 :: Clubman Talk (2008+)
Sep 29, 2015 01:00 PM
genik
Cooper (non S)
Sep 25, 2015 02:46 PM
