Interior/Exterior Removing rear windshield wiper
Old Dec 18, 2006 | 10:42 AM
  #51
MCDriver's Avatar
MCDriver
i removed mine too. i went to Lowes and bought the 3 required parts from their extensive fasteners selection.
1-elevator bolt with a head slightly larger than the hole in the rear glass and
2-black rubber washers slightly larger than the head on the elevator bolt
i painted the head of the elevator bolt semi-flat black and installed it.
i like this best as it lays very flat against the glass and is the least obvious solution possible yet it is a sound seal given the ability to tighten the nut on the opposite end of the elevator screw.
Old Dec 22, 2006 | 12:25 PM
  #52
TonyB's Avatar
TonyB
For some reason I never got the email alerts regarding replies in this thread...
Hmm... 4 pounds max to like 10 pounds. Was sort of hoping for 5+. I'll check with onasled also as he gutted everything out of his MCS, and likes to weigh stuff. Thank you.
Old Dec 22, 2006 | 12:32 PM
  #53
TonyB's Avatar
TonyB
MCDriver, would you happen to have the part #'s? The way you explain it, I like what you did... I'll be making a trip to Lowe's over the weekend... Thanks much!
Old Dec 23, 2006 | 10:14 AM
  #54
MCDriver's Avatar
MCDriver
unfortunately i don't have the part numbers as i did this several months ago. go to lowes. have the OD of the opening in the glass with you as the head on the elevator bolt and the washers will need to be larger than this OD. also i failed to mention that you will need a large flat washer for the interior side against the rubber washer. it is all straight forward. i can post a photo if need be. this is a 1 (easy) on the DIY scale.
Old Dec 23, 2006 | 06:05 PM
  #55
TonyB's Avatar
TonyB
Nice to have an easy project for once, so that's good. I think I'm good to go then. I wouldn't mind seeing a photo of how yours turned-out though. If not much trouble.... Otherwise, no biggie. Thanks much.
Old Mar 27, 2007 | 03:21 PM
  #56
RonP's Avatar
RonP
Found the plug at Ace along with some silly-cone. Did the mode today and love how it looks.
Old Mar 27, 2007 | 05:50 PM
  #57
Smokey's Avatar
Smokey
Nice looking shelf
Now you need to come up with a use for the rear washer fluid line.
I now use mine to spray the intercooler
Old Mar 27, 2007 | 06:52 PM
  #58
El_Griton's Avatar
El_Griton
Old Mar 27, 2007 | 07:57 PM
  #59
slvrmni03's Avatar
slvrmni03
Anyone remove the antenna as well, or am I the only one who doesn't care about AM radio?
Old Mar 28, 2007 | 01:49 AM
  #60
not-so-rednwhitecooper
I dont care about AM, but I still listen to FM.... kinda still need the antenna for that!
Old Mar 28, 2007 | 05:27 AM
  #61
slvrmni03's Avatar
slvrmni03
Actually, the antenna in the rear window picks up the slack just fine for FM.
Old Mar 28, 2007 | 08:21 PM
  #62
El_Griton's Avatar
El_Griton
ive seen the shark fin like on the new beemers, but not totally shaved off, would be pretty trick. plus I dont have mine hooked up anyways. I didnt spend all that money on a bad *** system to listem to crappy fm or am!
Old Apr 15, 2007 | 09:51 PM
  #63
TonyB's Avatar
TonyB
Ok, am the only one, or are there others who are seeing the rubber grommet get cracks and showing signs of deterioration? Heck, it's only been about 5 months...
Old Apr 16, 2007 | 10:57 AM
  #64
Smokey's Avatar
Smokey
Nope you aren't the only one
As I was closing the hatch this morning I noticed the same thing. Already searching for a replacement........... thinking a firewall panel plug would be better. I think I'll check the NAPA store on the way home tonight.
Old Apr 16, 2007 | 11:07 AM
  #65
TonyB's Avatar
TonyB
Smokey, if you find somthing worthwhile (that can withstand the elements better), please share. Thanks much!
Old Apr 16, 2007 | 11:09 AM
  #66
Smokey's Avatar
Smokey
Will do!
Old Apr 16, 2007 | 01:31 PM
  #67
blumini's Avatar
blumini
Tony? Kinda obvious isn't it???
GO BEARS!
Old Apr 16, 2007 | 01:59 PM
  #68
1nf3rn0's Avatar
1nf3rn0
I guess I'l get a michigan M for mine....
Old Apr 16, 2007 | 03:18 PM
  #69
TonyB's Avatar
TonyB
OK, blumini... what did you use, just a decal over the hole? I can't quite tell... Yes, I like it! What is the green, white and red on the right side of the bumper?
Old Apr 16, 2007 | 06:56 PM
  #70
blumini's Avatar
blumini
I used electirical tape over both sides of the hole and then covered the outer hole with a CAL sticker. No problems for over 8 months now
Green white & red half moon sticker (over the tow plug) is an Italian flag.
Mi familia come from Lombardia near Milano and my wife is a hot blooded Siciliana (Palermo). I know better than to cross her, the family is very well *conected*
Ciao,
Roberto
Old Apr 16, 2007 | 07:32 PM
  #71
TonyB's Avatar
TonyB
Too much in common!
IB MCS, penchant for performance, Cal and yes, I'm an Italiano also... and actually have one of the Euro "ITA" oval stickers on my rear window. Too funny, I'm half Northern Italian (near Milan also) and Sicilian.
I'm guessing you just trimmed the excess electrical tape around the Cal sticker with an exacto knife. I'll give that a shot. Heck, I was just at Cal, and could have gotten such a decal! Thanks again.
Ciao... Antonio
Old Apr 16, 2007 | 08:11 PM
  #72
blumini's Avatar
blumini
Ciao Antonio!
Indy Blue = Is there any other color for a Cal alumni?
I've got some great little ita stickers on my rear quarter windows. They're off a Moto Guzzi (long gone). Might be visible in my gallery.
Rear wiper hole: I trimmed the electrical tape so it just covers and seals the hole. The CAL sticker fits completely over the tape. The student store has all shapes and sizes. I've got them on everything. Cult?
Click here for an example of my blue accessories:
https://www.northamericanmotoring.co...ad.php?t=97535
ciao,
Roberto
Too much in common!
Ciao... Antonio
Old Apr 16, 2007 | 08:46 PM
  #73
TonyB's Avatar
TonyB
And besides Cal... the Italian soccer team... the Azzurri, all decked in blue!
That's a cool thread, thanks. Just another excuse to go back to Cal. Or just order online...
Thankfully the rainy season is over, so no rush on replacing this plug. Thanks again for the great idea!
Old Apr 16, 2007 | 09:05 PM
  #74
blumini's Avatar
blumini
Man I am so homesick for Norcal I could scream!
My wife and I spent 5 weeks in Italy last summer, Scicily to Milan. Half of it was by motorcycle. Trip of a life time. We were there through out the World Cup. Nothing can come close to that experience. Needless to say I own their home jersey, visitors and goalies along with several other national teams including both of Milan's. Mostly blue I might add. Blue is a lifestyle. It's just good mojo
Old Apr 16, 2007 | 09:42 PM
  #75
TonyB's Avatar
TonyB
Hey, let me know when heading back to NorCal! We need to hook-up. Yeah, I've got a few Italian soccer shirts and jerseys also... Sorry for taking this thread off course.
