Interior/Exterior Removing rear windshield wiper
Old Nov 30, 2006 | 08:32 PM
  #26
in the flesh's Avatar
in the flesh
So did you do it or not?
Old Nov 30, 2006 | 08:55 PM
  #27
RonP's Avatar
RonP
More questions, what's the intercooler and where is it at and why are some using their washing fluid to cool it?
Old Nov 30, 2006 | 09:00 PM
  #28
MarioKart's Avatar
MarioKart
Vendor
You don't have one because you don't have a supercharger. The sprayer cools the aftercooler that will keep the compressed air of the supercharger cool, which means more power. I swear my Mini has 25wheel hp more in the morning compared to the afternoon. The "S" Mini love cold weather.
But you could still have a clean rear glass with no wiper.
Mario
Old Nov 30, 2006 | 09:35 PM
  #29
RonP's Avatar
RonP
Cool, thanks. My rear window rarely gets dirty and it takes all of 5 seconds to wipe down. Plus, I never use the darn thing when it's raining anyway. Mine's going away very soon, it just looks so much cleaner without it.
Old Nov 30, 2006 | 09:47 PM
  #30
Jtrem's Avatar
Jtrem
Yes it does look a lot cleaner. Thats why I have decided to do it as well.
Old Dec 1, 2006 | 09:44 AM
  #31
JohnMonk's Avatar
JohnMonk
Coordinator :: Nashville–Middle Tennessee MINI Club
Shave it!
Old Dec 2, 2006 | 10:26 AM
  #32
in the flesh
Do I have to take off the whole engine with it??
Old Dec 2, 2006 | 11:09 AM
  #33
COR BLMY's Avatar
COR BLMY
Yes ... you do need to remove the Wiper Motor (3 x 10mm bolts for the motor)
So by that info
YES I did it
Maybe we need a CLUB "NRW CLUB"
Old Dec 2, 2006 | 11:53 AM
  #34
in the flesh
I just finished cleaning my car and my wiper blade is gone! Woot! I love the clean look , thank you everyone for your help!!
  #35
in the flesh
And yes, we should start a club, I don't have photoshop, someone needs to make a logo..
Old Dec 2, 2006 | 05:32 PM
  #36
COR BLMY's Avatar
COR BLMY
Old Dec 2, 2006 | 09:46 PM
  #37
1nf3rn0's Avatar
1nf3rn0
The wiper blade and motor are gone on mine right now, but I couldn;t make it to the hardware store before they closed. Tomorrow I will finish the job, wash the car and post some pics.
Old Dec 2, 2006 | 10:38 PM
  #38
Rawhyde's Avatar
Rawhyde
My MCS is the first car I've owned with a rear wiper. I think it's a handy thing to have...that glass gets nasty quick! That said, it DOES kinda clean up the appearance of the rear. Too bad there's not a wiperless model from the factory so you could get a piece of glass without the hole in it.
Rawhyde
Old Dec 2, 2006 | 11:45 PM
  #39
1nf3rn0's Avatar
1nf3rn0
I think it looks fine with the plug method... The one with the decall over the hole loked really nice. Too bad I don;t do decals on my car...
Old Dec 3, 2006 | 04:22 AM
  #40
daleCarlsbad's Avatar
daleCarlsbad
I did the plug and like the Union Jack better.
Old Dec 4, 2006 | 06:10 PM
  #41
Jtrem's Avatar
Jtrem
I finally did it and im happy with the result. The boot feels so much lighter.
Old Dec 6, 2006 | 07:39 AM
  #42
JohnMonk's Avatar
JohnMonk
I haven't gotten around to it yet, but I have a JCW center cap that I am going to try out instead of the plug. I'll post pix when I get around to doing it.
Old Dec 11, 2006 | 03:15 PM
  #43
RCGMini's Avatar
RCGMini
No Rear wiper
Sign me up for the NRW Club. Pull it, plug it, sticker it!
Last edited by RCGMini; Dec 11, 2006 at 03:17 PM. Reason: Sorry, I'm having problems attaching the photos. You can see a couple in my gallery.
Old Dec 11, 2006 | 03:49 PM
  #44
RCGMini's Avatar
RCGMini
No Rear Wiper Club
Here we go.
Attached Thumbnails Removing rear windshield wiper-p1030803.jpg   Removing rear windshield wiper-p1030805.jpg
Old Dec 11, 2006 | 04:44 PM
  #45
astromini's Avatar
astromini
any pics of the acutall plug.. and how do you remove and motor and where is the motor located.. and how did you guys reroute the hose to spray into the IC
Old Dec 18, 2006 | 09:19 AM
  #46
Smokey's Avatar
Smokey
I went a different route on the plug or the reroute as I didn't do that yet, so I can't help you there astromini but the motor is no problem;
For my 02, the newer models have redesigned the sprayer.
1. On the outside of the car - lift the plastic elbow piece covering the pivot part of the rear wiper blade. Make sure to look for the rubber "o-ring/seal" where the trim piece snaps to the wiper shaft.
2. Remove the 13mm nut and work/rock the blade arm while pulling up to remove the blade.
On the inside of the car -
1. Remove the phillips head screws holding the rear panel on (6, I think).
2. Gently pull down the trim panel, start at an edge and work your way around.
3. Check to make sure all the metal clips stayed with the trim panel, if not reach behind them on the hatch and pop them out of their metal holes, reinstall them on the panel. Note the 3 in the middle of the panel - you'll want to make sure these get snapped in when installing to avoid a rattle.
4. Remove the fluid line, down stream of the oneway check valve, the electrical connector and the 3 bolts hold the motor on.
5. I chose to drain the fluid by using the pump to spray it empty.
6. Pop the factory rubber seal out of the shaft hole.
For my plug I wanted to get a rubber sheetmetal bulkhead plug, like these where they would pop in and seal against the glass by pinching the glass in a slot. Well what I ended up doing was getting a rubber grommet and a plastic hole plug and fitted them together;
Here are a few shots of the install:
I applied a bead of silicon in the groove of the grommet to help with the sealing. The grommet is a Hillman's 1 - 1/8 OD by 23/32 ID by 5/16" thick (Lowes item number: 139378 and plug is also a Hillman's from Lowes it's the 7/8" item number 139481. I also applied a bead of silicon on the under side of the plug. The grommet is a little loose, until you force the plug into it. The plug forces the grommet out and over the edges of the glass to better seal the opening.
Installed:
Inside view: Use a little spit on your finger to help spread the silicon, without it sticking to you and lifting off of the glass
Wires and hose secured: I wrapped a vw bug cooling tin stainless screw (doesn't everyone have one of those) with teflon tape and plugged the hole, then a ziptie to make sure it doesn't go anywhere. Note that the hose will be with the opening up when the hatch is closed.
Some cheapman's Dynamat (sticky backed rubber with alum roof valley repair material, brand Peal & Seal, $13 for 25' x 6" at Lowes):
Outside View: Love the look and leaves more room for decals
I haven't looked yet but I'm sure there is a fitting on the passenger side engine compartment where you can disconnect the hose to the rear and install another to the IC.
Let me know if you have any questions
Old Dec 18, 2006 | 09:34 AM
  #47
TonyB's Avatar
TonyB
This has been on my list for a while actually, for aesthetic, and weight-loss purposes. Can someone please share the weight of what was removed? I would really appreciate it.
I already lost the rear wiper (and head lamp) storage tank a year or so ago, and that was worth nearly 10 pounds (full). Thanks much.
Old Dec 18, 2006 | 09:43 AM
  #48
Smokey's Avatar
Smokey
On the bathroom scale, it's 4 lbs max at best.
Old Dec 18, 2006 | 09:44 AM
  #49
not-so-rednwhitecooper
If i had to guess, id say the wiper motor weighs almost 10 lbs. it seemed like it was kinda overkill for a rear wiper...
edit,,, whats your build smokey? my wiper motor was a friggin beast.
Old Dec 18, 2006 | 09:48 AM
  #50
Smokey's Avatar
Smokey
July 02, it's hefty but not that bad.
