Interior/Exterior I have JCW front seats an need the air bag light to go off
Old Nov 24, 2006 | 07:26 AM
fozworth's Avatar
fozworth
Since ive fitted the front non air bag JCW seats the air bag light stays on and i wonderd if there is a way i can switch it off without going to the garage and paying a fortune.
Old Nov 24, 2006 | 07:47 AM
chows4us's Avatar
chows4us
Nm
Old Nov 24, 2006 | 07:57 AM
Minibeast's Avatar
Minibeast
Go to your dealer. They will need to contact MINI USA for the code to deactivate the seat airbags in your computer system. Once that is done, you should be set.
Old Nov 24, 2006 | 07:58 AM
biggripper's Avatar
biggripper
Do a search for threads with after market seats. Most people use a resistor from Radioshack to pluck into the wire for the seat sensors.
Old Nov 24, 2006 | 08:05 AM
vm's Avatar
vm
Congratulations, how much are they? do you have pictures?
Old Nov 24, 2006 | 08:27 AM
GoodFinder's Avatar
GoodFinder
Will they really do that? I would love to have the flexibility to change my driver's seat to a better one, but the concern about the airbag lights and the "computer system" have held me back from even starting to think about it much.
Old Nov 24, 2006 | 08:42 AM
k-huevo's Avatar
k-huevo
Too late to help fozworth, he has to sign the waiver and have the light disabled by the MINI service department. But, if the key is not turned on during the seat swap and the correct resistor placed in the loop, the light will be avoided. http://store.webbmotorsports.com/for...wtopic.php?t=9
You will need a T40 also.
Old Nov 24, 2006 | 09:06 AM
fozworth's Avatar
fozworth
So are you saying i cant buy a aftermarket resistor then to sort this ,or do i need a resistor and then a trip to the dealer to get the code enterd to deactivate my light?I live in the UK so no warenty issues,just an annoying light.
Old Nov 24, 2006 | 10:23 AM
rkw's Avatar
rkw
Once the light has come on, it will stay on until reset. Adding a resistor should prevent the light from coming on again, but won't reset it. It can be reset by the dealer or at most shops that service BMW or MINI.
Old Nov 24, 2006 | 10:48 AM
fozworth's Avatar
fozworth
How much are resistors
Old Nov 26, 2006 | 07:20 AM
THE ITCH's Avatar
THE ITCH
Minibeast
I recently checked with my dealer to see if they would do that. I have a GP and was thinking about trying to get a set of Recaro seats like the rest of the world gets in a GP. My dealer checked and said that that could not be done. I gave them the whole senario of my signing a waver but they were unable to find anyone at MINI who said this was a possibility. If you have more info (I.E. person to contact at MINI who my dealer could call) please advise. Thanks Steve
Also please note that from 2005 and newer the airbag system has changed to include the 12 lb. passenger seat sensor which to my knowledge no one has come up with a "resistor fix" for.
Old Nov 26, 2006 | 12:15 PM
Minibeast's Avatar
Minibeast
Itch, I'll contact my dealer tomorrow and confirm this can still be done. I get a name for you to contact as well.
Old Nov 27, 2006 | 10:41 AM
AZMCS's Avatar
AZMCS
I've been thinking about this one. Couldn't you just tapp the wiring look for this circuit and hardwire it closed so that is basically sees the seat as always occupied? Seems like the pressure plate simply closes a ciruit that could be manually "closed" by this technique.
Old Nov 28, 2006 | 01:20 AM
fozworth's Avatar
fozworth
Its sounds to technical for me.Ive found a local company who have designed little fused resistors that plug in under the seat ,then all they do is hook the car up and reset the airbag fault and the resistor cheats the system.£60 all in im told.
Old Nov 28, 2006 | 01:25 AM
fozworth's Avatar
fozworth
Have fitted a Aero rear bumper and now my exhuast tips look way set in?
I have fitted my aero bumper and its seems to be a spot on fit appart from now my exhuast tips seem to be set further back compaired to my stock cooper s bumper.I have a play mini exhuast an so the tips fill the appiture but they could do with sticking out further ,is this comon?
bneer
Jul 15, 2019 04:41 PM
Dec 23, 2015 10:36 AM
dyeLucky
Sep 11, 2015 10:41 AM
dyeLucky
Aug 7, 2015 07:10 AM
