Interior/Exterior Maybe a dumb question: Tow Hook MOD?
OK, quick question...
I finally found the tow hook (who woulda thought that foam thing by the battery actually opened? Duur), and I went to test fit it. I love the look of it on the car, and am planning on coating it with red, rubberized paint (like in the picture below), but I have a problem.
When screwed in, the hook is not straight (either horizontal or vertical), but rather stops turning when at a 45-degree angle. I've seen plenty of NAM photos of cars with the OEM (I assume) tow hook, usually in a straight up-and-down or straight horizontal position. How did you guys get it to be tight in the socket in that position?
Doesn't it vibrate out? Maybe if I squirt some Lock-Tite or some silicone in there first...?
I like the eBay hook, but wish it didn't stick out from the grill so much... Plus the price tag is a bit daunting.
I've hear dof many using teflon tape. Wasn't an issue for me, but I no longer regularly run a tow hook as it kept getting faded from sun exposure (orange kept turning into a yellowish hue). Debating re-installation for the winter, plus the orange on the black car stands out more and makes me just a little more visible.
Try putting a washer on the end reinstall the tow hook, if it does not sit straight then try 2 washers. Their should be a enough teeth to hold it in place.
If you're going to do it, then might as well do it right. Vertical is not the proper position. Proper position is as shown in the picture......
I used an old fashion bit brace with a very large bit. Very slowly and carefully ream the shoulder of the hole, it's aluminum. Take a tiny bit off, then try the hook. Do this until it's just a bit pre-horizontal. Remove the hook, coat the threads with thread lock, reinstall hook and level at horizontal.
Now you'll look official.
....Les
....Les
Teflon Tape
I wouldn't use lock-tite--you'll never get it off. Primed it and painted it caution yellow. Used teflon tape and when it got snug, used a screwdriver as a lever and tightened it until vertical. Really sets off against my purple haze MINI--I like the look.
....Les
....Les
I got it in with a dab of silicone sealant - that way it will be firm and vibration-proof when the silicone hardens, but I can also remove it if and when I want. And the hole is now sealed against corrosion!
I also picked up a can of the rubberized dip paint (see first post for pic) - it's pretty cool and coats the hook in bright red rubber. I have plenty left over if anyone wants their own hook dipped - I'll put up a seperate thread for it and I'll take a photo of the final result in the morning...
Thanks, guys!
Thanks, guys!
Yes it is... It's intended to give a winch hook something to grab onto. It screws right into the main bumper plates and can be used to winch the car out of mud or snow. You have one on the front AND rear, actually...
For actual towing, however (meaning, towing something WITH the car), you'll need a tow bar (sold at Outmotoring or Miniaturetrailer.com).
The hooks lend a bit of a racy look to the car because such hooks are required for many racing events in order to tow your car off the track quickly in case of a breakdown.
Scott
Where's the one in the rear?
well since we're all posting pics of our hooks, I'll join in
