Interior/Exterior S2k HID's BRIGHTER?? MINI INSTALL?
Old Aug 16, 2006 | 05:31 AM
whataricky's Avatar
whataricky
Anyone else notice s2k headlights are way brighter than other HID's-- How do we get that intensity out of our coopers
Old Aug 16, 2006 | 05:36 AM
mdsbrain's Avatar
mdsbrain
Projectors?
Old Aug 16, 2006 | 07:12 AM
xizor's Avatar
xizor
Originally Posted by mdsbrain
Projectors?
right, s2000 and TSX projectors are widely used for retrofits for non-HID cars because they are some of the brighest and have a sharp cutoff.
Old Aug 16, 2006 | 07:18 AM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Just a note about HID bulbs:
The brighter is not always the one that gives the best visibilty while driving. They sure look cool but that's about...
If I remember correctly, any HID between 4000k and 5000k give the best visibility. Higher than that, it is only for the look (you knot those aftermarket HID kits that you can get with 8000k bulbs...)
It also ahs something to do with the color of the light. From white to blue, to purple...
Old Aug 16, 2006 | 07:45 AM
cristo's Avatar
cristo
Alliance Member
True HID systems are only a few types of bulbs
HID-D1S, -D1R, -D2S, & -D2R
MINIs with Xenon lights used D2R through 2004 and
D2S starting in 2005
Honda S2000s use D2S (although the headlight assembly may be
better designed).
[SIZE=4]Characteristic[/SIZE]
[SIZE=4]Unit[/SIZE]
[SIZE=4]Xenarc®
D2S
[/SIZE]
[SIZE=4]Xenarc®
D2R
[/SIZE]
[SIZE=4]Xenarc®
D1S
[/SIZE]
[SIZE=4]Xenarc®
D1R
[/SIZE]
Light Source Wattage
W
35
35
35
35
Luminous flux
lm
3200
2800
3200
2800
Luminous efficacy
lm/W
91*
80*
91*
80*
Color Temperature
K
4250
4150
4250
4150
Average luminance
cd/cm
6500^
6500^
6500^
6500^
Lamp Life B3
h
1500
1500
1500
1500
Lamp Life Tc
h
3000
3000
3000
3000
Arc length
mm
4.2
4.2
4.2
4.2
[FONT=Verdana][SIZE=1]
[/SIZE][/FONT][FONT=Times New Roman][SIZE=3]^Minimum value
* Light Source only [/SIZE][/FONT]
Old Aug 16, 2006 | 08:03 AM
cristo's Avatar
cristo
Alliance Member
better designed).
here's a link
http://members.misty.com/don/d2.html
Old Aug 16, 2006 | 08:37 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
hahah perfect timing!!!
I just got my spare set of headlights ready to be put in the oven today.
I will be installing TSX projectors in mine
Just wish HIDplanet.com wasnt down....sad
Do you have any experience with retrofitting HIDs? This is my first time so it would be awesome to have another MINI owner that i could talk to about this.
Old Aug 16, 2006 | 08:38 AM
Rally@StanceDesign
He is talking about the projector. The S2k and the TSX have much better projectors than what is offered on many other cars as stock Xenons. They have a greater light output that is in fact BRIGHTER and increases visibility a large amount. Most people continue to use 4300k when they retrofit S2k/TSX projectors.
You are right though, bulb changes are usually just bling.
Old Aug 16, 2006 | 11:25 AM
whataricky's Avatar
whataricky
I dont just want bulbs, I was curious if anyone had replaced the actual projector lenses??
Old Aug 16, 2006 | 11:37 AM
Sixspeed-J's Avatar
Sixspeed-J
My old S2000's HIDs were by far the best I have had so far. Followed by my 350Z.
Old Aug 16, 2006 | 11:40 AM
Wake|MCS's Avatar
Wake|MCS
RallyMINI, be sure to take step-by-step pics and make a how-to as I'm sure this will be useful to many people in the future! Oh and, Good Luck!
Old Aug 16, 2006 | 11:41 AM
Rally@StanceDesign
Oh, do you have the MINI HID's? I never thought about that
I have halogen housings that i plan to PUT the TSX projectors into. I just got all the necessary tools to start, so after i post this I'm off to experiment with it.
Old Aug 16, 2006 | 11:42 AM
Rally@StanceDesign
Thanks dude....i definitely plan to take pics and write a little article or something up.
*warning though, this may take quite a while. Others who do this to other cars spend months...and that's probably where i will be headed too. I want it to look as clean as stock when done *
Old Aug 16, 2006 | 12:53 PM
DarkMiniCooperS
Still have that 350Z ??
I love that car.
Old Aug 16, 2006 | 08:13 PM
whataricky's Avatar
whataricky
Yeah I have the MINI HID's, I was just curious if anyone had done a conversion
Old Aug 16, 2006 | 09:14 PM
Rally@StanceDesign
I doubt it, especially a lense conversion. I haven't heard of anyone thinking about it
I started the project. I have it all in pieces and I'm measuring it all out to see what projector will fit and how. Getting the headlights open was the biggest pain in the butt ever....very well put together by BMW. Most cars' headlights just pop off when heated.
Old Aug 17, 2006 | 07:26 AM
Crashton's Avatar
Crashton
Rally how will you aim those HID's once you have them mounted? Will the leveling feature from the TSX work with your MINI? Every OEM HID that I've seen has a leveling feature, either automatic or driver controlled. That feature makes them livable for others on the road. The reason I ask is there are some young guns running around Hooterville with home brewed HID conversions that are painfully mis aimed. Yikes!
Old Aug 17, 2006 | 09:43 AM
Rally@StanceDesign
Well they will be hooked onto the stock reflectors which are levelled by ***** on the back
I do believe you have this conversion confused with the "HID conversions" you see on ebay. Those kits are used in halogen housings by many younger kids for pure bling. By using HID bulbs in Halogen housings they get A LOT of light that goes above the cutoff. This glare above the cutoff is what causes problems for other drivers. Because I am installing projectors into the headlight housing, i will have a MUCH sharper cutoff....even sharper than an OEM HID cutoff since i'm going with TSX projectors. This will eliminate the glare that causes problems for other drivers.
It will not have an auto-level system (which is technically required by law), but it will not cause any problems for on coming traffic. I wouldn't do something that puts others in harms way (which is why I'm putting in a whole projector rather than just putting HIDs in halogen housings)
I would point you towards HIDplanet for more information about the safety and effectiveness of these retrofits, but the site is currently down. They have some great shots of the cutoffs and detailed info about safely aiming the HID's...
Old Aug 17, 2006 | 09:49 AM
Rally@StanceDesign
here is a pic of the cutoff....notice no glare above cutoff at all...very clean
Just a pic of projectors installed in jetta headlights:
Old Aug 17, 2006 | 09:51 AM
Rally@StanceDesign
and a pic from the side during proper aiming procedure:
Old Aug 17, 2006 | 10:24 AM
xizor's Avatar
xizor
auto-leveling isn't required by law... cause the TSX doesn't have it
Old Aug 17, 2006 | 10:33 AM
Soul Coughing's Avatar
Soul Coughing
your correct, its only european cars that have auto-leveling... because the EU mandates it. Japanese cars don't...
Old Aug 17, 2006 | 11:12 AM
Rally@StanceDesign
I stand corrected, i could have sworn that the US required it now along with a washer system. My bad
Old Aug 17, 2006 | 11:27 AM
Crashton's Avatar
Crashton
Well that is sure different than the young bloods are runnin in uptown Hooterville. I do believe auto or driver adjustments are required for HID's. My friends STI has a **** that lets you adjust them from the cockpit & I believe the Mazda 3 also has that arrangement. If you take the time to aim yours properly, I'll welcome you into uptown Hooterville.
Old Aug 17, 2006 | 11:36 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Rally, please keep us posted on this project.
