Interior/Exterior Need some advice on gauges
Old Aug 10, 2006 | 07:58 AM
pure&simple's Avatar
pure&simple
So here are my plans... 2 Cravenspeed double-gauge 52mm pods holding boost, oil pressure, oil temp, and water temp. I'm looking for the most OEM looking gauges I can find - right now I'm considering the Autometer Ultralites. There are like 6 different variations of each 52mm Ultralite gauge that all look basically the same (http://www.autometer.com/). Any advice on choosing which one?
Also, I don't know what I don't know regarding installation. I will be having these installed at Helix, however, I want to purchase the right parts. I should be looking for electric full-sweep gauges, right? What else do I need to know to be an educated consumer?
Old Aug 10, 2006 | 05:38 PM
ZigZagN's Avatar
ZigZagN
Hi
I have the ultralites and the look great.
I made my own bracket to hold the gauges from aluminum flat plate
I used carbon fiber pods so they match my dash.
As for installation, you want to T off the oil pressure sending unit.
DO NOT let them drill a hole in the end of your oil filter cup.
Other than longer screws to mount the bracket to the back of the factory tach and the T fitting, the gauges should have about everything else you need.
Attached Thumbnails Need some advice on gauges-jun12_01.jpg   Need some advice on gauges-jun12_03.jpg
Old Aug 11, 2006 | 05:38 AM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Click on my signature links (image & text) to see my Ultralite boost gauge. I think I got it to match really good the stock gauges.
PM me if you have any questions.
Old Aug 11, 2006 | 05:56 AM
pure&simple
Thanks guys!
anyone else care to share info on their OEM-looking gauges?
Old Aug 11, 2006 | 06:02 AM
rrdusek's Avatar
rrdusek
yeah, the ultralights look pretty close to stock, ( see mine my gallery) but i still haven't found the right color lighting for them. once you get them in, you'll wonder how you got along without them
Old Aug 11, 2006 | 07:29 AM
JoeCool's Avatar
JoeCool
If you want something that matches the silver face/red lettering of the tach, check out www.speedhut.com. Pricey, but you can make custom faces in lots of colors. They have 2 1/16 gauges (52mm) that should fit the Craven pod.
rikaro
Nov 24, 2015 02:05 PM
Doc Pain
Oct 28, 2015 07:09 PM
zdw2082
Oct 5, 2015 09:59 AM
Snotrocket555
Oct 1, 2015 08:59 AM
papawhiskey
Sep 30, 2015 02:50 PM
