Interior/Exterior Push Button Starters
Old Mar 22, 2003 | 08:47 PM
'*Ace*''s Avatar
'*Ace*'
I have seen a couple sites advertise these things. What is the point of them?
Old Mar 22, 2003 | 08:50 PM
foldinghalo's Avatar
foldinghalo
To make you feel like you're in a real racecar!
Old Mar 22, 2003 | 09:01 PM
8ball's Avatar
8ball
Don't know which (new) ones you've seen but in the old cars (even as recent as early Spridgets, Minors and Minis through the mid 60's) initial component cost and inevitable maintenance made separate ignition and starter functions more appealing - some cars also had a starter button under the bonnet so one could turn the engine over when doing things like adjusting points and rockers.
In some race cars where high amperage was needed to turn the starter of a high-compression motor, the switch had to be by itself so as to avoid frying the rest of the harness with all those amps.
Old Mar 22, 2003 | 09:24 PM
jcs's Avatar
jcs
I have one in my 91 ford Festiva - connected to unused rear wiper switch and works great :smile
Not going to do this to my mini....
Old Mar 23, 2003 | 07:41 AM
dominicminicoopers's Avatar
dominicminicoopers
So, if the MINI had a push button start, then you'd have to insert the key. Turn it to the on position. Then press and hold the button until the engine fired. Right?
Old Mar 23, 2003 | 07:46 AM
8ball's Avatar
8ball
right ... that's the routine ...
Old Mar 23, 2003 | 08:50 AM
'*Ace*''s Avatar
'*Ace*'
Not a routine I want to take up...
Old Mar 23, 2003 | 08:53 AM
dominicminicoopers
What if it was one of the toggle switches instead of a button?
Old Mar 23, 2003 | 09:25 AM
Chrisscat77's Avatar
Chrisscat77
the new BMW 7 series has this- the key isn't a key at all it's just a square that inserts directly into the dash and then you press the brake (on the auto tran) and push the start button. to release the 'key' you push the same start/stop button and push in 'key' again and it pop out. very interesting- but the car is complicated to drive- none of the features are self-explanatory... i tried valet parking the beast the other day (dad's car- not mine) and the valet had no idea how to put it in park
Filmy
15
Jun 6, 2023 06:27 AM
Peking Duck
Jan 19, 2021 03:17 AM
Filmy
Jun 28, 2016 08:58 AM
nighthaw2k
Sep 30, 2015 01:51 PM
jennster
Sep 28, 2015 06:19 PM
