Interior/Exterior You-ification: show 'em
Old Jun 22, 2008 | 04:37 PM
  #276
Jhud's Avatar
Jhud
is it bleeding?
Old Jun 22, 2008 | 06:03 PM
  #277
shooler's Avatar
shooler
Originally Posted by Jhud
is it bleeding?
Well, if it can "bleed" fiberglass, then yes. I have lost enough fiberglass packing from this new exhaust to insulate my garage.
Old Jun 24, 2008 | 06:35 AM
  #278
RussellCory's Avatar
RussellCory
Originally Posted by shooler
I didn't care for the exhaust tip that came with my Alta V2 exhaust, so I had one made.
That is very slick.
Old Jun 24, 2008 | 02:09 PM
  #279
erickvonzipper's Avatar
erickvonzipper
Practically invisible. Very cool.
Zip
Old Feb 11, 2009 | 11:11 AM
  #280
2mD's Avatar
2mD
i revised my old self made suspension arm support.
thats what it looks like now :
Old Feb 11, 2009 | 11:20 AM
  #281
BlimeyCabrio's Avatar
BlimeyCabrio
Let's call it the "Burning Man" brace!
Old Feb 13, 2009 | 02:47 PM
  #282
tehSAC's Avatar
tehSAC
Originally Posted by Malcon
thirsty??
love the scoop lights. diy?
Old Aug 22, 2009 | 01:46 AM
  #283
corduroy's Avatar
corduroy
Sorry for the lame picture quality. These are off my phone.
1st pic: I made some seat pulls out of an old guitar strap. They're black vinyl with a white offset stripe. It was a great looking strap, I just never used it because it didn't match any of my guitars At least it matches well with my seats now. I tried to get my ameoba sticker in there. It's the ONLY sticker I will allow on my car.
2nd pic: Someone mentioned squeezing a drum between the seats. I do this too! These are mini set of bongos. I wear a lot of hats and I found my circular headrests to be a nice shape for holding hats
Attached Thumbnails You-ification: show 'em-photo_082209_008.jpg   You-ification: show 'em-photo_082209_009.jpg
Old Sep 4, 2009 | 09:36 AM
  #284
MaxMini81's Avatar
MaxMini81
Wanderer
Power Supply Solution...
Attached Thumbnails You-ification: show 'em-switch-panel-final-2.jpg
Old Sep 4, 2009 | 10:29 AM
  #285
2mD's Avatar
2mD
@ maxmini81
what does the "belkin" thing do ?
got some "new" thinks myself ( forgot to post them here )
self made water/air intercooler:
parst:
- moddified oem intercooler
- the radiator was from a Smart
- the water pump from a bmw 5 series
- a few hoses an stuff
works REALLY well
i did some test runns @ 22C° ( 72F° ) ambient temp. ( inlet air temp readout from obd with a scangauge )
50km -> 220kmh ( 31mph -> 136mph ) revving till 7000rpm = the inlet air temperature reached 26C° ( 79F° )
after that i did the same run 4 times in a row. at the end of the 4. run the inlet air temp had reached 39C° ( 102F° )
right now im thinking about doubling the cooling surface ( a second radiator ) to prevent heat soak
Polished inlet manifold + the 2 things left/right from the intercooler ( forgot to make pictures now that they are installed )
polished outside AND inside
self made exhaust: r53jcw + r56cooperS parts ( had to lift the battery, but it was worth it )
Old Sep 4, 2009 | 10:51 AM
  #286
PureWorks's Avatar
PureWorks
Custom aluminum spiltter and hook polished. M7 grills cut out to fit over fog lights, also cut out rear aero and put in M7 grills
Attached Thumbnails You-ification: show 'em-chrome-car-updates-014.jpg
Old Sep 4, 2009 | 02:54 PM
  #287
MaxMini81's Avatar
MaxMini81
Wanderer
Its a USB charging station. Since my Bluetooth, iPod, iPhone, gf's Blackberry, and my iPod/iPhone recharger all use that common connection, it seemed more practical and much cooler than a typical 12V accessory port.
Old Sep 8, 2009 | 08:16 AM
  #288
AggieMini11's Avatar
AggieMini11
Old Sep 15, 2009 | 11:55 AM
  #289
MaxMini81's Avatar
MaxMini81
Wanderer
New Addition
After realizing how little I actually touch my head unit, I decided to move it to the glove box. I can control what I need via the steering wheel, and the Harmon Kardon Drive and Play and Sirius components. Having completed this move, I used some left over ABS to fabricate a DIN gauge panel to replace the head unit in the center rack.
Old Sep 15, 2009 | 07:00 PM
  #290
BlimeyCabrio
that's pretty happenin
What's the **** to the left of your ScanGauge? And what are the other toggles? just curious
Old Sep 15, 2009 | 08:31 PM
  #291
MaxMini81's Avatar
MaxMini81
Wanderer
The **** is actually just an insert in a 12V accessory port. It used to have a Belkin USB port plugged into it, but somehow I lost that. The "Bombs Away" switch is for the Drive+Play/Sirius. All of the switches were originally going to have indicator lights, but the bracket holding the Scan Gauge II got in the way of that. I figured that since the audio components were the most likely to be left on, I'd make that switch stand out. With the addition of the gauges (the toggle panel was built in May), I rewired the entire assembly. So, from left to right we have Audio, AC Power [USB] Port & Gauges, GPS, Outer Driving Lights, Inner Lights (Alta Light Bar). The wiring goes into a double 4-1 hub - the positive side going to the positive battery terminal under the hood. The negative runs behind the euro shelf to a cut-off switch mounted therein (with an indicator light) and is then grounded into the frame behind the dash.
My own little spaceship.
Old Sep 15, 2009 | 08:34 PM
  #292
Malcon's Avatar
Malcon
what is it about us mini drivers that really wish we were pilots.....haha
Old Sep 16, 2009 | 05:03 AM
  #293
BlimeyCabrio
Nice work!
I like the cutoff switch, too...
Old Sep 16, 2009 | 06:03 AM
  #294
Fatandre's Avatar
Fatandre
Originally Posted by agranger
I couldn't find any custom Passport remote installs on a MINI, so I made up my own rules. I was a bit freaked while drilling through my dash, but it all came out OK.
I got a Union Jack on a bead-blasted Whalen ****. I didn't like the bead blasted finish at all (nails-on-a-chalkboard texture, grabbed dirt and oil off of your hand very quickly and looked nasty after 10 minutes) so I figured 'why not?" and got out a microfiber and the Wenol Blue (fine metal polish). It took about an hour of 'polishing my ****' (I made the joke so you wouldn't have to) to get an even finish all the way around.
In the end, I got a nice polished finish that doesn't show fingerprints like the normal Whalen **** and it has a very nice feel to it. It also looks a bit richer than the machine polished ****, so it fits in a bit better w/ my anthracite dash and downtubes.
A similar Whalen **** with a bead-blasted finish:
My **** after an hour of polishing w/ Wenol Blue:
The finished interior:
Where can I get that **** and how much is it?
Old Sep 16, 2009 | 04:25 PM
  #295
nabeshin's Avatar
nabeshin
Functioning Lunatic
It is a Whalen Shift Machine ****, they are a vendor here on NAM. Vendor directory
Old Jan 11, 2011 | 07:25 PM
  #296
MyMiniGidget's Avatar
MyMiniGidget
I feel like this thread has been lost so here's a nice little *bump*
Old Jan 11, 2011 | 07:50 PM
  #297
veggivet's Avatar
veggivet
Definitely a thread worth reviving from hibernation.
Old Jan 22, 2011 | 06:35 AM
  #298
R53 Speed's Avatar
R53 Speed
Thanks everyone for keeping me entertained for the past 2 hours while I sipped my coffee
Some neat stuff happening.
Old Jan 25, 2011 | 10:55 AM
  #299
MyMiniGidget
What did it take to do this? Just a few hours and a little elbow grease? What polish did you use. This is one thing I've always wanted shiny on the Mini.
Old Jan 25, 2011 | 11:27 AM
  #300
2mD's Avatar
2mD
you need one of these:
a giant metal tub ( fittet with some giant vibrators ) filled with ceramic abrasive stones ( dont know what they are called in English )
the only thing i did myself was building the steel plate to mount all the parts i wanted to polish ( you can see that in the first pic you quoted )
tough the machine i used looked more like this:
also used to polish wheels
