Interior/Exterior MOMO shift knob
Old Feb 25, 2003 | 05:36 AM
dave's Avatar
dave
pug poo picker-upper
I really like the MOMO Race Airleather Shift ****. Is there anything unique to the MINI I need to know about doing this? I seem to recall with the VW's there was a little adapter necessary to make the shift boot fit nicely.
Old Feb 25, 2003 | 07:54 PM
DK23's Avatar
DK23
Actually it is somewhat involved in making the Momo **** fit the MINI gear lever. If you look at the MINI lever closely, you notice the shaft flares larger from the top of the boot to form a seat for the standard **** to fit down on. The Momo **** is designed to slip down on straight lever shaft, and be tightened with three set screws. In order to hide the set screws, it has a collar that slips on the shaft first (below the ****) then screws up onto the bottom of the ****, covering the set screws. The design is great, however the flared seat on the MINI shift lever prevents the collar from sliding down the shaft far enough to allow the **** to go on completely (the collar has to go down on the shaft further than the final position of the ****). My solution was to dremel and file down the flared section enough for the collar to slip further down the shaft, then installing the Momo **** as it was designed. The shaft is plastic, and shapes very easily. I also shortened the shaft a bit to make the taller Momo **** fit in the same postion as the stock ****. The **** postioning was such that all the file marks were hidden under the **** or collar. At the same time, I installed the Moss leather shift boot, and positioned the top of the boot right up against the bottom of the ****, so no shaft shows. Made for a very clean install.
Old Feb 25, 2003 | 07:59 PM
dave's Avatar
dave
Thanks for the great explanation.
Do you have any pictures of it installed?
Old Feb 25, 2003 | 08:01 PM
aVjai's Avatar
aVjai
I like the Hamman shift **** more~
Old Feb 25, 2003 | 08:10 PM
dave's Avatar
dave
Do you have any larger pictures showing the ****? Also, who sells that in the U.S.?
Old Feb 25, 2003 | 08:14 PM
rfibanez's Avatar
rfibanez
The pedals in that pic look great, who makes them? And is there an aftermarket shift **** that is a direct replacement without and modifications necessary?
Old Feb 25, 2003 | 08:21 PM
dave's Avatar
dave
The pedals are Hamman.
My major requirement is that the aftermarket **** have a leather top since that's where my hand contacts the ****. The metal gets pretty cold in the winter and hot in the summer.
Old Feb 25, 2003 | 08:32 PM
DK23's Avatar
DK23
My camera went belly up yesterday, so I can't take a good photo of the **** install. However
https://www.northamericanmotoring.co...pic=5731&6
That should link you to a photo of my boot and **** install as posted on page 5 of this forum.
OutMotoring
Mar 3, 2017 06:29 AM
gar56
Nov 15, 2016 06:41 AM
aldito2
Sep 30, 2015 10:44 AM
kevinlhr310
Sep 27, 2015 02:31 PM
mini_mike237
Sep 25, 2015 12:45 PM
