Interior/Exterior Those with Navigation
Old Feb 7, 2006 | 09:23 PM
skitelluride531's Avatar
skitelluride531
Since with the addition of a factory navigation system removes the ability to have a digital speed read out, I wanted to see if anyone out there successfully added something in order to get a digital speed readout. Anyone? Care to share what you did?
Old Feb 8, 2006 | 08:35 AM
mdsbrain's Avatar
mdsbrain
Anyone? I'm curious too.
Old Feb 8, 2006 | 08:47 AM
onasled's Avatar
onasled
Not sure what you are asking. Digital readout on what?
As far as I know the Nav is not in the loop with the ECM.
Old Feb 8, 2006 | 11:55 AM
rkw's Avatar
rkw
Digital readout of speed on the Tach. You lose this feature if you have the speedo/tach dial combo with Nav or Chrono pack.
I also have Nav and would like to get digital speed. The small speedo is hard to read and it only has tick marks every 10 mph. I can only read speed to about a 3 mph accuracy.
Old Feb 8, 2006 | 12:06 PM
MSFITOY's Avatar
MSFITOY
OBD display. I have the lowest readout to show actual speed The 10.1mph is just memory from when it was last shut off...
Old Feb 8, 2006 | 06:24 PM
skitelluride531
Interesting...how much did that cost you?
Old Feb 8, 2006 | 07:17 PM
Z-Mini's Avatar
Z-Mini
Is the digital speed readout realtime? somewhere down the line I had it in my mind that is was avg. speed.
Thanks-
Randy
Old Feb 8, 2006 | 07:55 PM
rkw's Avatar
rkw
If you don't have on-board computer, you can select between displaying real-time speed or outside temperature.
If you do have on-board computer (included with Nav), you can display various computer functions including avg. speed, but real-time speed is not available.
Old Feb 9, 2006 | 05:09 AM
MSFITOY's Avatar
MSFITOY
http://www.auterraweb.com/
You can set one of the five readouts to show speed in real time, rpm, engine temp, AIT, boost/vacuum, timing advance, and a bunch of other things I can't remember right now. However, at this particular display function, you can only see 5 parameters. There's another window that shows only 2 displays but with much larger digits. There's also a graph readouts...
Besides the cool readouts, it can also record/define the pesky error codes and if you choose, erase them
And...I forgot about the Palm Dyno feature
Old Feb 9, 2006 | 10:00 AM
Z-Mini's Avatar
Z-Mini
Do you know if the MINI uses K-bus (ISO-9141) or CANbus or both?
Thanks-
Randy
Old Feb 9, 2006 | 10:14 AM
phaedrus's Avatar
phaedrus
I, too, have the factory nav, and...
...(now, don't roll your eyes if you already know this, but) the 'average speed' selection on the on-board computer can almost give you your real-time speed just by pressing and holding the reset/select button on the left (turn signal) stalk. As it re-calculates average speed, you'll notice that it'll continuously adjust to your current speed within a half-second or so, until the next time you depress the select button.
Hope that makes sense; but I don't know if it's what you're looking for.
Old Feb 9, 2006 | 10:20 AM
MSFITOY's Avatar
MSFITOY
Thanks-
Randy
CAN is the version I use
Old Feb 9, 2006 | 10:32 AM
Z-Mini's Avatar
Z-Mini
Thank you much!
-Randy
Old Feb 9, 2006 | 02:53 PM
haulin_oats's Avatar
haulin_oats
why not just look right beside your tach at the speedo?
Old Feb 9, 2006 | 03:54 PM
rkw's Avatar
rkw
Of course I do, because it is the only speed I have available. However as I commented earlier, "The small speedo is hard to read and it only has tick marks every 10 mph. I can only read speed to about a 3 mph accuracy."
Old Feb 9, 2006 | 08:13 PM
skitelluride531
Thanks for that link. I am seriously considering this, so I have a few more questions regarding integrating the system into the MINI if you don't find :D . First, where is the OBD connector located in the MINI? So basically, you have installed software on your Palm, and then have run a wire from the Handheld to the MINI OBD connector? Is that all there is to it? Thanks again!
Old Feb 13, 2006 | 07:32 PM
Z-Mini's Avatar
Z-Mini
This OBD-II Scan Gauge would fit the bill well if it worked with the MINI. Only appears to support a few US makes but mentions CanBUS support.
Anyone want to buy one to try it out with a MINI?
-Randy
Old Feb 14, 2006 | 05:02 AM
MSFITOY's Avatar
MSFITOY
-Randy
Oh brother...what does post #5 mean then?:impatient
OutMotoring
Nov 16, 2015 07:04 AM
vulkandino
Oct 31, 2015 08:29 PM
Wombat Pie
Navigation/Audio
Oct 5, 2015 08:00 PM
ahorvath
Oct 3, 2015 01:13 AM
krohm
Sep 28, 2015 12:16 PM
