Interior/Exterior Looking for mod..
Old Oct 9, 2005 | 04:55 PM
Madnikos GR's Avatar
Madnikos GR
Looking for mod..
I am thinking of buying door steps for my 05 MCS.they look like these
and havent found any "how to install"....
Waiting for help guys....:impatient :impatient :impatient :impatient
Old Oct 9, 2005 | 05:02 PM
DrDiff's Avatar
DrDiff
Coordinator :: Northwest Indiana MINIacs
I have heard of steps for 4x4's and SUV's but a MINI?
Oh you mean Door Sills! More Specifically lighted door sills. You will need Adobe Acrobat but click here. I don't think it has to be hooked to the dealer computer to be "Activated"
Old Oct 9, 2005 | 07:30 PM
Madnikos GR
yeap "door sills" thats the one..
Thanks Doc...
Old Oct 9, 2005 | 07:31 PM
Madnikos GR
Thanks Doc...
Old Oct 9, 2005 | 07:42 PM
bumble's angel's Avatar
bumble's angel
Thanks Doc...
Thanks Doc...
Do I hear an ecco?
Old Oct 9, 2005 | 07:51 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
You would install them right where the stock ones are. So....remove stock ones, peel off adhesive backing and apply the new ones. There will be wiring, which needs to be spliced into some of the lights that come on when you open the door. Your best bet would be the lights under the dash. You can hide that wire however you seem fit. It would be pretty easy to run the wire under the sideskirt and up the interior kick panel. From there its a short stretch to the wiring in the dash.
I havent seen pics or anything for the install which would probably help a bit more
Old Oct 9, 2005 | 07:59 PM
Madnikos GR
a silly question..
Do they drew lots of power?I really do not any fuses going like fsss???
Old Oct 9, 2005 | 08:03 PM
Rally@StanceDesign
unfortunately i cant tell you without knowing how they are lit up? I can say that they PROBABLY dont draw much at all because they are likely either LED or EL lighting. Both of which have very little draw, but i cant be certain until i know the workings of the parts.
Old Oct 9, 2005 | 08:07 PM
Madnikos GR
Ok then...I Know who to ask for help...Maybe in a couple of weeks I will post here my own "how to" if i can make this work!Thanks rallymini
Old Oct 10, 2005 | 04:39 AM
petecrosby's Avatar
petecrosby
Actually they are called "sill plates". :smile:
Old Oct 10, 2005 | 08:42 AM
DrDiff's Avatar
DrDiff
Go back to the link and print out that .pdf file. That gives Genuine BMW Full install instructions. They are genuine factory parts so there should be no problem with them shorting anything. If I remember there may be some drilling required.
Achilles honor
Dec 22, 2011 02:35 PM
lilruffcat
68
Jan 17, 2008 08:59 AM
