Interior/Exterior Adding fog lamps?
Old Aug 30, 2005 | 02:59 AM
jtso23's Avatar
jtso23
Adding fog lamps?
Ok so I just contacted my MA to see if I could get a spec change but she said my car was already in production. I wanted to add front and rear fog lights and switch the 16'' 5 star wheels for 15'' 5 star Rockets. I didnt think my car would go into production so soon because I got royal grey with a silver roof and I thought that color combo would take a bit longer. Any advice as to what I should do? Is there a way to add fog lights after I recieve my car?
Old Aug 30, 2005 | 08:07 AM
kyriian's Avatar
kyriian
you can either do what i did and add aftermarket fogs in the little slots, but to fabricate a mount for them can be the pain, and no pretty switch
i think dealer does charge a pretty penny for the factory set though
Old Aug 30, 2005 | 08:11 AM
not-so-rednwhitecooper
the fog lights in the bumper is avaliable as a retrofit kit, BMW PN 63130395387 and runs about $133 dollars. Its plug and play, needs to be reprogrammed and needs a new toggle bank.
The rear fog light "retrofit" is just a matter of buying the light housing and getting a new toggle bank and having the programming done, which you are going to have to do already.
just ask for a toggle bank like your including a fog light and rear fog switch, a rear fog light for an 05 cooper and a front fog light retrogit kit, BMW PN 63130395387.
Hope this helps,
Old Aug 30, 2005 | 12:02 PM
chows4us's Avatar
chows4us
see http://forums1.roadfly.com/mini/foru...6807056-1.html
Old Oct 29, 2005 | 12:00 AM
rkw's Avatar
rkw
Is the car pre-wired for front fogs in 2005/2006 models? To retrofit, is it only necessary to install the light fixtures, not the harnesses?
Old Oct 29, 2005 | 08:17 AM
buy the retrofit kit, it will include everything you need.
Old Oct 29, 2005 | 09:40 AM
rkw's Avatar
rkw
I ordered my 2006 without front fogs. I'd be especially interested in installing the front fog retrofit if the harnesses are already on the car and all I had to do was to install and plug in the actual lights. There is a PDF of installation instructions on MotoringFile (http://www.motoringfile.com/howto/Fog%20Lights.PDF) but it is dated 2001 and shows a fair amount of work to add the wiring. Does anyone know whether more recent cars from the factory come pre-wired for front fogs?
Old Nov 1, 2005 | 11:37 PM
rkw's Avatar
rkw
I had my front bumper off today while changing to a black grille. My 2006 is not pre-wired for front fogs.
HogWldFLTR
Sep 8, 2015 05:25 AM
Gen1Parts
Sep 7, 2015 03:50 PM
Gen1Parts
Sep 7, 2015 01:37 PM
Ntety
Sep 2, 2015 08:39 PM
