Interior/Exterior Factory Cooper S pedals
Old May 22, 2005 | 07:48 AM
UnMini's Avatar
UnMini
Does anyone know where I can get the factory Cooper S pedals. I have a early 02 MCS that came only with cheap rubber covers and I want the set which is used in all the late models.
Old May 22, 2005 | 09:05 AM
MINIAC's Avatar
MINIAC
The parts should be available from your dealer ... see the following DIY for part numbers:
How to fit factory alloy pedals to older models
Old May 22, 2005 | 12:04 PM
UnMini's Avatar
UnMini
I already checked at the dealer but am not paying $250 for some lausy pedals
Old May 22, 2005 | 12:28 PM
Bilbo-Baggins's Avatar
Bilbo-Baggins
This is excellant advice.
I did it but used the second "dead" pedal for the accelerator. I did not glue mine but actually seperated the metal cover piece from the plastic backing and screwed the plastic piece to the accelerator pedal.
Total expense about $35.00 for all three pedals.
Old May 22, 2005 | 12:30 PM
MINIAC's Avatar
MINIAC
The accelerator pedal is expensive, but I got all the parts for about $100.
You should check to see if Classic will ship to Mexico.
Old Jul 11, 2005 | 03:53 PM
UnMini's Avatar
UnMini
thanks for the advice
Old Jul 11, 2005 | 04:15 PM
biggripper's Avatar
biggripper
Nice pedals Bilbo...now you just need to do a little cleaning of your carpets.
Looks like you tracked half of the dirt in the SHIRE into your MINI.
Old Jul 12, 2005 | 03:05 PM
UnMini's Avatar
UnMini
I installed the set and also screwed the dead pedal on the original gas pedal everything looks great
Old Jul 12, 2005 | 03:11 PM
ZAKdog's Avatar
ZAKdog
I don't see the screws on the gas pedal...? Would you please post a close up?
I bought the clutch and brake but couldn't see paying for the gas either...
Old Jul 12, 2005 | 04:13 PM
MINIAC's Avatar
MINIAC
The screws are hidden behind the alloy cover plate ...
Old Jul 12, 2005 | 06:35 PM
UnMini's Avatar
UnMini
you can secure the screws from behind with some nuts
Old Jul 13, 2005 | 05:32 AM
ZAKdog's Avatar
ZAKdog
doh! I thought you took off the metallic plate and secured it to the factory gas...not knowing it has a backing plate of its own
I may have to try the junkyards to cannabalize a wrecked MINI
Dec 23, 2015 10:36 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
