Interior/Exterior who owns this Mini
Old May 22, 2005 | 06:35 AM
Cooper S IRE's Avatar
Cooper S IRE
who owns this Mini
ok so who owns this Mini
where did they get the front grill
or how
part numbers please if you can
Old May 22, 2005 | 06:56 AM
AldoS's Avatar
AldoS
Appears to be a stock MCS grill with the chrome painted black.
Old May 22, 2005 | 07:00 AM
Cooper S IRE
yeah thats what i thought but i read that paint wont stick to the chrome part too well so i thought that someone ordered it this way???
Old May 22, 2005 | 07:33 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
You would have to sand the Chrome to get the paint to stick, but it should be an easy task for any paint shop. but i know you can not order the grill like that. good luck
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Cooper_Si's Avatar
Cooper_Si
if you look even closer you may notice its half aerokit...and half normal grille!
The usual chrome part has been swapped for the aero trim .... then they must have chucked the mesh away to keep the slats
good idea and very different
Old May 22, 2005 | 07:37 AM
Cooper S IRE
now that makes sense
it sure looks good
thanks for the feedback
Old May 22, 2005 | 09:55 AM
jimz68's Avatar
jimz68
Nope, It's a 2005. (notice the headlamps) The chrome grille surround on an 05 is all smooth.
Jim
Old May 22, 2005 | 10:56 AM
Detroit Tuned
Vendor - 15 Years
nope they are stock parts, just painted black.
Old May 22, 2005 | 11:16 AM
Cooper_Si's Avatar
Cooper_Si
Jim
<--goes off to check his MINI bible...ahhh yes new model minis are now smooth...but probably just as easy to mod the aero grille instead of worrying that paints gona peel off
Old May 22, 2005 | 11:22 AM
Rick-Anderson's Avatar
Rick-Anderson
Painting Chrome
I have painted chrome parts in the past by sanding the chrome. It doesn't work. Etching the chrome works a little better, but not good enough to stick. The only effective way I have found to paint chrome is to have the plating removed from a chrome shop.
Old May 22, 2005 | 11:30 AM
webstrands's Avatar
webstrands
I have a question about this setup...
Was this done to accomidate the driving lights? When you use the Aero-Kit's upper black grille, what happens to the light brackets? Don't the driving light brackets stick out from between the stock grille slats? If this is the case, then how do they insert the brackets on the aero kit? Do they cut through the aero kit grille and slide the brackets through?
Old May 22, 2005 | 11:39 AM
Detroit Tuned
Vendor - 15 Years
Metal Chrome or Plastic Chrome?
Old May 22, 2005 | 11:47 AM
Detroit Tuned
Vendor - 15 Years
Yes, you have to cut slots in the aero grill for the Rally Lights. If you read in the Driving Light instructions on Motoring File, you will see how it is done. They have cut marks molded right in to the grill on the back. New Note: they now also have a template for cutting them out. looks like to many dealers can not do it correctly....
Old May 22, 2005 | 12:53 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
I have painted chrome (plastic) and still no problems besides a few rock chips (so i changed to vinyl)....i just painted my grill.....see pic in my sig. I got some ultra fine steel wool at home depot and scuffed the chrome entirely...then primed a few coats, then paint. Its easy
Old May 22, 2005 | 02:07 PM
DaCrema's Avatar
DaCrema
The MINI One has black slats. A dealer should be able to help with the part number. It just not imported into the USA. I have also heard of people using tape to cover the chrome.
Old May 22, 2005 | 02:17 PM
Rally@StanceDesign
yah....the only problem is that its far easier to paint them then to have them shipped in from europe...and none of the cars come with the outer chrome part painted which is what he is interested in. I think the only option is to paint it or put vinyl on it
Old May 22, 2005 | 03:57 PM
amorican's Avatar
amorican
WOw
I am halfway into the grille swap and what a *****. I have enlarged some of the tab holes and cut off the louvers on the lower grille slot, but getting the aero grille modified and fit is proving to be quite a hassle.
Any tips for cutting this thing up, besides a solid and charged dremmel with a cutting wheel?
Thanks!
TJM
Old May 22, 2005 | 08:12 PM
SCMiniGuy's Avatar
SCMiniGuy
It ain't here...
That Mini is not in the US of A. Check out the wipers...they wipe the other way, to the left when looking at the front of the car. Mine wipe to the right when looking at the front.
OK...everyone go outside/into the garage and check it out now.
It must be a right hand drive Mini then.
Old May 22, 2005 | 08:33 PM
Rally@StanceDesign
which would explain the front plate
Old May 22, 2005 | 09:19 PM
YYC's Avatar
YYC
Cooper S Ire is in Ireland!! From the beginning of the thread, I had just assumed this photo was not taken in North America.
Where is this car, Cooper S Ire??
Old Aug 2, 2005 | 04:46 PM
fj0's Avatar
fj0
Wow that is crazy hot!
What are those lights? Not OEM right? They look a little bigger. I want that setup, hot.
Old Aug 2, 2005 | 05:06 PM
JCW Driver's Avatar
JCW Driver
Thanks!
TJM
I presume you have the motoring file write up in hand?
arf88
May 31, 2016 03:07 PM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
Dashdog
Aug 10, 2015 06:17 AM
