Interior/Exterior Air Bubble in Stripe
Old Jan 17, 2005 | 07:16 AM
ChiliCooperS's Avatar
ChiliCooperS
Hey guys, I just recieved my mini on saturday, I have no complaints about anything... Well maybe I do. There is a sizable (1.5 - 2.0 in) air bubble in the left bonnet stripe. My dealer says it will go away with time, but my uncle, a bmw mechanic, says it won't. Who do I believe and if it won't go away with time what do I do?
Old Jan 17, 2005 | 07:18 AM
CoryB
Doesn't really matter but is it a factory stripe or dealer installed?
Either way, it isn't right. Give it a week or so to see if it disappears. If not, make the dealer fix it. That's why you have a warranty.
Old Jan 17, 2005 | 07:22 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
Take a pin and put a small hole at one end. Then push, with a flat object, the strip down from the other side to get the air out. You might get a bit of distortion and see the hole for a while, but after bein out in the sun and heated up a few time, it will smooth out and look good. Good Luck!:smile:
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Jan 17, 2005 | 11:08 AM
SHUMopper's Avatar
SHUMopper
id personally make them put on a new set of stripes.
Old Jan 17, 2005 | 11:17 AM
BuckeyeMCS's Avatar
BuckeyeMCS
I had a few of those in mine and they did go away after a few times in the hot sun. Not this time of year.
Old Jan 17, 2005 | 11:40 AM
agranger's Avatar
agranger
I've got no experience with these stripes, but I've read specifically that you SHOULD NOT do the pin-***** method suggested above (though it seems to make sense). I don't know why, etc... I just remember reading somewhere that you shouldn't do it.
Old Jan 21, 2005 | 09:48 AM
BradB's Avatar
BradB
I remove these bubbles the same way I do with clear pain protection film. Use a syringe. I take a thin gauge (thinner than a pin), and pierce, then withdraw the air/moisture from underneath. It will instantly go flat.
ronn
23
Sep 5, 2017 10:36 AM
HogWldFLTR
Oct 1, 2015 11:38 AM
M7Speed
Sep 3, 2015 07:48 AM
Ntety
Sep 2, 2015 08:39 PM
broncobuddha
Sep 1, 2015 06:32 PM
