Interior/Exterior UK Hazard Triangle: Retrofit
Old May 3, 2022 | 07:36 AM
RichsMINI's Avatar
RichsMINI
Hi everyone,
I know this isn’t really a “modification” but more of an OEM retrofit. I wanted to share how simple it is and links for anyone looking to perform this retrofit
My MINI is a ‘21 F56 S 2DR
Parts:
The hardest part about this is locating “in-stock” MINI OEM brackets
- MINI parts department and others can order them but they ship from Germany and can take about a month
- MINI: 51497375203
- 2 are required
BMW uses the same bracket but there’s a small alignment tab on the rear of the bracket and they cost more money
- MINI has the tab horizontally
- BMW has the tab vertically
- BMW: 51497167548
- 2 are required
BMW/MINI uses the same part number for the hazard triangle: 71606770487
Some BMW/MINI parts department websites list the part as “no longer available to order”
- If you call sometimes they say “yes, it can be ordered”, “no, it cannot be ordered” or “it’s not compatible”
I ordered the BMW brackets from @ECS Tuning and the hazard triangle from Bimmerworld
- All items were in-stock and shipped out the next day
Install:
Since I went with the BMW brackets I used an X-Acto knife and cut the small alignment tab
- Removed the 2 T-25 torx screws from the trunk lining
- Mounted both brackets using the original screws and fastened the triangle down with the bracket clips
Pictures:
Links:
: https://www.bimmerworld.com/BMW-MINI-Warning-Triangle-with-Container-71606770487.html
: https://www.bimmerworld.com/Genuine-BMW-Bracket-For-Hazard-Warn-Tri-51497167548.html
: https://www.ecstuning.com/b-genuine-...497375203~oem/
: https://www.ecstuning.com/b-genuine-bmw-parts/warning-triangle-mounting-bracket-priced-each/51497167548/
: https://www.ecstuning.com/b-genuine-bmw-parts/warning-triangle-with-container/71606770487~oee/
Quick and easy, not more than five minutes and I think it adds just a little more UK to the US MINI
Hope this helps any MINI owner looking to perform this retrofit
Rich
Old May 3, 2022 | 07:44 AM
Nice! Thanks for the order, i had that on my old R56 MINI Cooper S.
Old May 3, 2022 | 08:12 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
That reminds me, I need to get the strap for my Clubman triangle on order...
Old May 9, 2022 | 05:28 AM
IrishCooper's Avatar
IrishCooper
Interesting, I wondered what that space was for.
Old May 10, 2022 | 02:58 PM
TVPostSound's Avatar
TVPostSound
Rich
If you REALLY want more UK to your MINI, get this too!!
82262288693
Old May 10, 2022 | 05:23 PM
RichsMINI's Avatar
RichsMINI
82262288693
@TVPostSound, Now that I know about it I may have to
It would be another great safety item to have in the boot and it doesn’t cost a lot.
@ECSTuning has it in-stock and I have some AMEX points to spare…
Rich
Old May 11, 2022 | 09:05 AM
TVPostSound
I believe the vest is also a requirement in the EU along with the triangle.
Imagine getting out of your car on the autobahn, with cars flying by at over 240 kmh at night? While you are trying to change your flat tire?
Old May 11, 2022 | 09:38 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
82262288693
But... it says "BMW" on it, not "MINI"?!
Old May 12, 2022 | 12:28 PM
RichsMINI's Avatar
RichsMINI
@TVPostSound the vest has been purchased
@njaremka it really should say MINI
Update: Here’s another picture of the hazard triangle
If anyone was wondering while driving and going over bumps in the road I don’t hear it making any noises.
Rich
Old May 13, 2022 | 05:53 PM
TVPostSound
Well, if you're that picky..................!!
82 26 2 288 694
Old May 18, 2022 | 08:08 AM
Its right here: https://www.ecstuning.com/b-genuine-...262288694~gem/
wolfe
Aug 8, 2011 02:36 PM
Chainsaw Flowerchild
Northern California
Feb 17, 2006 12:36 PM
MiniPilo
Dec 6, 2003 07:17 PM
Daytona955i
May 14, 2003 04:57 PM
