Interior/Exterior Added red highlights - Brake Ducts and Stripes
Old Sep 11, 2016 | 07:34 AM
llebcire's Avatar
llebcire
Wife wanted to add red highlights to her MINI.
I found that Duplicolor doesn't make MINI paint and I wasn't interested in paying for a custom mixed spray ($20) plus adhesion promoter ($20) from a local auto paint supplier (Sherwin Williams). Little research showed that a MINI owner had found the Ford OEM Cardinal Red was a close match so I went with it. I also assume that using products designed to go together would yield better results.
First, needed to remove the brake duct intakes which was very easy after finding on NAM that the bumper doesn't need to be removed - they just pop out:
Old Sep 11, 2016 | 07:44 AM
llebcire's Avatar
llebcire
Next, I gave them a thorough scrubbing with soap and water. I followed this with a green scuff pad:
This was the last time I used my bare hands to touch them. After scuffing (wasn't noticeable) I used a tab to hang them with speaker wire for painting and wiped them down with 91% rubbing alcohol
My products from Duplicolor:
Adhesion promoter
Cardinal Red paint
Protective clear coat
Process:
3 coats of adhesion promoter, waiting 3 minutes between coats
4 coats of base waiting 10 minutes between coats. 1st coat was within 10 minutes (actually 6) of final adhesion coat
3 light coats and 1 heavy coat of clear, 10 minutes between coats, 1st coat 30 minutes after final base coat
Old Sep 11, 2016 | 07:47 AM
llebcire's Avatar
llebcire
Final product turned out much better than I expected. Has a nice shine and I don't plan on messing with it as it's pretty low on the vehicle.
Overall, less than $25 and 3.5 hours of my time.
Old Sep 11, 2016 | 07:50 AM
llebcire's Avatar
llebcire
To accent this, I added one stripe outside of the factory stripe which was very easy.
Product:
Finished product. We're changing the "4" in All4 to red and adding the red/silver and black checkerboard JCW mirror caps along with painting the calipers to complete the look
Old Sep 11, 2016 | 07:56 AM
llebcire's Avatar
llebcire
We discussed adding a red stripe to the sides as well but think the caps and "4" will be just right:
Before:
Thanks!
-Eric
Old Sep 12, 2016 | 08:10 PM
mikey_t's Avatar
mikey_t
Well done Eric
Old Sep 13, 2016 | 06:08 AM
llebcire's Avatar
llebcire
Originally Posted by mikey_t
Well done Eric
Thanks!
We have a few more red accents to add but not too many.
-Eric
Old Sep 13, 2016 | 09:09 AM
isamin's Avatar
isamin
NICELY DONE. Also, others may wish to check out Krylon FUSION (for plastic &metal) #2328 safety red as a good match for chilli red. No primer required ,drys in 10 mins, costs about $4 @ walmart.
ISAMIN
Old Sep 13, 2016 | 09:50 AM
llebcire's Avatar
llebcire
ISAMIN
I considered the Krylon route but didn't know if it could be successfully clear coated for durability.
-Eric
Old Sep 14, 2016 | 06:42 AM
isamin's Avatar
isamin
it doesn't need to clearcoated .I've run this on my lowerd JCW for about 3 years with NO bad effects.
ISAMIN
Phillbis
Jun 6, 2020 09:24 AM
NascarGuy
Aug 15, 2016 10:07 PM
TJANK
Aug 15, 2016 11:28 AM
AhmadYAlHamed
Aug 15, 2016 12:22 AM
Gen1
Aug 13, 2016 06:40 PM
