Interior/Exterior shift lever spinning around
Old Mar 31, 2014 | 06:16 PM
genik's Avatar
genik
Wanted to see whats underneath the leather cover that "dresses" the gear lever so i tried to unscrew it. Gave it a hard spin and now its all spinning round without stopping to lock in one position. Did something break?
Old Apr 1, 2014 | 12:24 PM
ammodave's Avatar
ammodave
I assume you mean the gear shift **** is "spinning". The **** is not removed by unscrewing it from the shift lever. It is held on by a nylon tab inside the **** and is removed by forcefully pulling it straight up (it just pops off). https://www.northamericanmotoring.co...hift-****.html You've probably broken the nylon retainer inside the ****. If the shift lever itself is "spinning", you may have done serious damage to the shift linkage. Try just pulling the **** straight up to remove it and make sure you haven't damaged the lever itself. Look up inside the **** to see if the retainer is just out of position and can be repositioned. If the **** can't be repaired, you're going to have to spring for a new ****.
Old Apr 2, 2014 | 10:25 AM
genik's Avatar
genik
What about the leather that covers/surrounds the leaver? Shouldn't this be taken of before pulling the ****? How do i do that?
Old Apr 2, 2014 | 11:40 AM
ammodave's Avatar
ammodave
Just pull the boot down. There's a plastic collar inside the boot that fits over an extension protruding from the bottom of the shift ****. Unfortunately the boot is a little hard to slip back over the bottom of the **** when you try to put it back into place so you may have to fiddle with it a bit to get it back on. This pic may help.
Old Apr 10, 2014 | 02:28 PM
genik's Avatar
genik
Guys all is well, i gave it a hard slam on top and its fixed now!
OutMotoring
Mar 3, 2017 06:29 AM
02miniSguy
Nov 17, 2015 10:29 PM
MINI Stupor
Oct 1, 2015 11:36 AM
bahman
Sep 30, 2015 01:59 PM
EVMini
Sep 28, 2015 10:20 AM
