Interior/Exterior Homelink Mirror swap on R53. Need input
Old Jan 3, 2014 | 06:06 AM
actulsiz's Avatar
actulsiz
Today, I swapped my basic mirror (non-dimming/homelink) with a Homelink autodimming mirror. The swap was very easy(plug-n-play). Once I did the swap, My lock/unlock features in my fob, no longer works. I swapped back to my original and my keyfob still does not work. Is there something special I need to do in order to reactivate my unlock/lock features? BTW, I own a 2005 R53.
Old Jan 3, 2014 | 07:07 AM
Mike02MCS's Avatar
Mike02MCS
I did the same mirror swap on my 06 R53, no issues.
Old Jan 3, 2014 | 07:10 AM
actulsiz's Avatar
actulsiz
So no programming anything? you just hooked it up and your keyfob began to work??
Old Jan 17, 2014 | 10:02 AM
F1USGP's Avatar
F1USGP
Where did you get the mirror?
Old Jan 17, 2014 | 11:50 AM
actulsiz's Avatar
actulsiz
It was pulled from a 2006 R53.
Old Jan 28, 2014 | 06:59 PM
wmcginnis's Avatar
wmcginnis
You need to reinitialise the key, step one: turn the key to the second position in the ignition, step two: remove key and press and hold the lock button, step three: while holding lock button press the unlock button three times, the locks should cycle if done properly, repeat steps two and three for the other key too, also make sure all the doors are shut
Old Jan 28, 2014 | 08:24 PM
actulsiz's Avatar
actulsiz
Thanks, however I sold the homelink mirror
potterstein
Dec 30, 2024 05:18 PM
potterstein
Sep 4, 2015 09:52 AM
Manny_cooper
Sep 3, 2015 05:48 AM
Ntety
Sep 2, 2015 08:39 PM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
