Interior/Exterior Opinions on CHROME interior?
Old May 19, 2004 | 11:22 AM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
I'm considering of adding some chrome interior pieces to brighten up the interior a bit. Since there're so many different pieces, I'm not sure which one I like.
Suggestions? Photos would be great!
_________________
Old May 19, 2004 | 11:29 AM
countrym's Avatar
countrym
Chrome interior trim will be a dealer option in '05. Maybe they can retrofit it to an '04?
To quote from Motoring File, "(345) Chrome Line Interior: Chromed rings around all gauges, bezels around the hazard light button & dash light dimmer, inserts on the hand-brake, and rings around the gearshift and rear cup holders (as seen in Cabrio press photos)"
Old May 19, 2004 | 11:35 AM
MGCMAN's Avatar
MGCMAN
Get the toggle switch covers, and the "three rings" (Tach, Speedo and Shifter) to start. Chrome IMO is the one thing the MINI interior lacks as part of its 1950s-1960s appeal.
Old May 19, 2004 | 11:36 AM
dcsmd007's Avatar
dcsmd007
From the photos, the 05 OEM chrome looks different than the aftermarket ones. The OEM chrome covers the entire silver area, where as aftermarket one is just a ring.
Aftermarket
05 OEM
_________________
Old May 19, 2004 | 11:39 AM
dcsmd007's Avatar
dcsmd007
That's exactly what I have in mind - the trio and the switches.
Switches
Trio
_________________
Old May 19, 2004 | 11:49 AM
scotteast's Avatar
scotteast
Old School!
I like the idea of doing the bars between the switches and the three rings.
I think the important thing is not to add TOO much chrome. There can be too much of a good thing.
Scott
Old May 19, 2004 | 12:12 PM
rg's Avatar
rg
I've been doing some chromatization myself here lately. Started with the trim rings for the speedo/tach (my mini is Nav enabled) from Moss Mini and love them!! EASY to install and a factory look. Next, i moved on to the Nav trim pieces and the "Chrome Center Vent Ring - Pair" also from Moss. I'm happy with the Nav trim pieces, but got one on a little crooked and it rubs against the Menu button, so take caution when installing that piece. The Center Vent Rings are a little dissapointing. I was expecting the same type rings as the speedo/tach rings, but these are just thin little rings that sit on top of the vents housing, kind of a highlite of chrome. My next thought is towards the button guard things, but i'm not sure i like the looks of those yet. will then probably go for the ring around the shifter, and then who knows where.
Old May 19, 2004 | 12:18 PM
dcsmd007's Avatar
dcsmd007
rg, sounds like you have some nice chrome trims there! Pictures?
Old May 20, 2004 | 10:19 AM
retroom's Avatar
retroom
I prefer the full covers over the rings, but the rings look good too. Moss Mini sells the chrome covers for gear shift and two front cup holders as a all-in-one package, they look great along side the stock chrome gearshit **** (MC). Moss also sells chrome covers for the Speedo, and center vents (non-navigation), hazard, and dashboard light switch.
retroom
Old May 20, 2004 | 10:32 AM
kenchan's Avatar
kenchan
I wonder if that chrome glares in the sun... ?
The guages all look like clocks from the 80's. :smile:
Old May 20, 2004 | 10:39 AM
MGCMAN's Avatar
MGCMAN
Actually they do, at least a little. It's part of their appeal, veddy British, govn'r.
Old May 20, 2004 | 10:53 AM
retroom's Avatar
retroom
The gauge(s) located on the steering wheel will probably reflect the most light but the others shouldn't be too bad.
retroom
Old May 20, 2004 | 02:26 PM
Moorlockx's Avatar
Moorlockx
Here's a link to some pics of mine.
http://www.mini2.com/gallery/personal/gallery_8856.html
Old May 20, 2004 | 11:33 PM
maxmini's Avatar
maxmini
I have pretty muchthe entire chrome design line from Moss Mini on the car and I think it adds a lot to the basic interior . Of course it is always a matter of opinion if it is a good thing or not.
Randy
Team M7
Old May 21, 2004 | 12:19 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I like the chrome trim rings-they come from different sources (some are german-speaker rings/toggle rings)
I have-
Speedo ring
Tach ring
Shifter ring
Toggle ring set
front door rings
And chrome/CF shift ****
Old May 21, 2004 | 03:24 AM
dcsmd007's Avatar
dcsmd007
Thank you all for your inputs and photos! :smile:
Old May 21, 2004 | 07:03 AM
GJR's Avatar
GJR
Just FYI...Paul Mullett (of MINI2 fame) just posted this information pertaining to the upcoming factory chrome kit. He hasn't released the supplier name yet, but I'm anxious to find out! Otherwise, MINI dealers will carry the kit in the near future. Good luck!
_________________
<IMG SRC="http://209.61.216.212/upload/gjr/let....jpg">
Old May 21, 2004 | 10:56 AM
dcsmd007's Avatar
dcsmd007
Several european vendors offer the same kit. The cheapest I've found is 175 GBP for the entire kit (13 pieces). They're from the same supplier as the OEM. :smile:
Old May 26, 2004 | 10:23 AM
dcsmd007's Avatar
dcsmd007
For those with Auto Meter accessory gauges and would like to have chrome rings for them, there's a solution. Auto Meter has "Traditional Series" with chrome bezel, which can be used for the Ultar-lite series as long as they're the same size gauges.
Old May 26, 2004 | 04:59 PM
minicoopermike's Avatar
minicoopermike
Great pictures everybody! The extra chrome sure adds a little something special to the interior (already a great thing IMO). I think I will wait for the OEM kit to come out..........
Old May 27, 2004 | 12:13 AM
Rick-Anderson's Avatar
Rick-Anderson
minihune, I love your wood dash and trim. Is this part of a kit or is it custom?
Old May 27, 2004 | 12:36 AM
minihune's Avatar
minihune
Thanks. I removed the stock dash and various trim pieces and had them custom airbrushed in a wood finish then put them back in place. Rough cost $300 to paint.
Old May 27, 2004 | 12:44 AM
Yucca Patrol's Avatar
Yucca Patrol
Get one of these gauges to help you make sure you do not exceed the "bling" redline
Old May 27, 2004 | 07:40 AM
dcsmd007's Avatar
dcsmd007
_________________
Old May 28, 2004 | 05:17 AM
ChiliCooperMark's Avatar
ChiliCooperMark
I need one of those, too, Yucca. How 'bout a group buy? I'm afraid I'm redlining already.
