Interior/Exterior R53 driving and fog light question
Old Sep 24, 2013 | 03:21 PM
detonator2's Avatar
detonator2
I've done a quick browse and haven't found anything specific to my needs so I'm hoping a post here will allow me to find the answers I want!
I've had my MCS (used) for about a week now and the driving lights in the grille don't work and the fog lamp on the passenger side doesn't either. The toggle switch for the fog lights illuminates and so does the (assuming factory installed?) driving lights switch. So I know power is going to the switches at least.
I have a multimeter so I'd like to know what wires I should check next. I'm about to go check all the fuses after I post this.
I'm going to check for continuity but not sure from what points I should check.
Any advice would be appreciated and if I should check for any resistance on the lines that would be helpful too.
Thanks in advance!
Edit: Mods can you please move this to the electrical section (where I intended to post it)
Last edited by detonator2; Sep 24, 2013 at 03:24 PM. Reason: Posted in wrong subforum
Old Sep 24, 2013 | 03:46 PM
Bludevilx's Avatar
Bludevilx
Factory driving lights only work with the high beams on. The fog light just sounds like a bulb out.
Old Sep 24, 2013 | 04:26 PM
detonator2's Avatar
detonator2
Well that's embarrassing...
Driving lights came on with high beams as expected, on the passenger side only. Hoping it's only the light that needs replaced and not the whole unit. Anyone know the replacement off the top of their head? Same question for the fog light on the pass side...
Old Sep 24, 2013 | 05:38 PM
detonator2's Avatar
detonator2
I've looked more and I feel like a huge dummy. Is the driving lamp a 2 piece thing? (Number 2 in the picture). I've taken the screw out of the bottom but can't get to the bulb. It'll rotate CCW but I don't want to twist it too much for fear of breaking something.
I have the fog bulb out FWIW
Old Sep 24, 2013 | 08:32 PM
Eric_Rowland's Avatar
Eric_Rowland
I don't think it twists. IIRC the front fascia just lifts out, then you can get access to the bulb.
Old Sep 25, 2013 | 07:27 AM
detonator2's Avatar
detonator2
Oh man. Tell me you're kidding. It just pulls off?
Old Sep 25, 2013 | 08:46 AM
Eric_Rowland
See 'figure 58' here: http://www.pelicanparts.com/techarticles/MINI/52-ELEC-Driving_Light_Installation/52-ELEC-Driving_Light_Installation.htm
for a view of what it looks like when the front ring is removed.
Old Sep 25, 2013 | 11:14 AM
detonator2's Avatar
detonator2
I'm dumb. There's a little lip at the 12 o'clock position on the housing that I wasn't aware of.
Wohnson89
Jun 10, 2020 04:53 AM
Dec 23, 2015 10:36 AM
Zettinger
Aug 25, 2015 04:04 PM
