Interior/Exterior 2006 mini cooper - how to program key to open windows
Old Mar 6, 2013 | 02:47 PM
rfw's Avatar
rfw
New used 06 base model - replaced battery - key will open and lock doors but I have lost window open function - are there reprogrammin steps? Thanks - I am a new NAM member
Old Mar 6, 2013 | 04:20 PM
astroBlackMetallic_Mini's Avatar
Click open once, again, then hold it a third time. Eventually the windows should open.
Old Mar 6, 2013 | 04:52 PM
ZippyNH's Avatar
ZippyNH
06
Does not have a replacable battery....it is recharged in the ignition....a standard battery WILL LEAK/FAIL, a rechargeable battery must be used.
The window features are PROGRAMMED into the car, not the KEY.
Old Mar 6, 2013 | 04:55 PM
ZippyNH's Avatar
ZippyNH
PS
Welcome to NAM!!
LOTS of info around....use google site serch!!
Old Mar 6, 2013 | 05:37 PM
Originally Posted by ZippyNH
06
Sorry, but incorrect on the recharge thing. I cracked one of my Keys open, there is no recharge function. There are no wires or any inductance circuit to charge the battery... At least not in my key!
Old Mar 6, 2013 | 05:41 PM
chrunck's Avatar
chrunck
What year is your MINI? Supposedly only the 05 and 06s have a rechargeable battery.
Old Mar 6, 2013 | 06:17 PM
ZippyNH's Avatar
ZippyNH
Yup...2005+ MODEL YEAR, gen1cars....
100% sure on this...you can tell by the keystyle. With the change in the keystyle, the change in the charging happened.
Old Mar 6, 2013 | 06:29 PM
I have an 06. I have just a key, not the radio only key, I think those are self recharging. The batt inside IS the rechargeable model, I was going to build a charger circuit for the key I tore open actually, just haven't gotten to it yet.
Well, if my key is supposed to be charging, why is my range getting shittier every month?
Old Mar 6, 2013 | 06:31 PM
rkw's Avatar
rkw
When the OP said "replaced battery", I think it meant the car battery.
Old Mar 6, 2013 | 06:32 PM
Braminator's Avatar
Braminator
RFW try this maybe your key needs to be intialized again.
Initialize remote key as follows:
1.) Close all doors
2.) Switch the ignition switch to KL-R (first turn), switch back off within 5 seconds and remove the key
3.) Within 30 seconds, press and hold the unlock button and at the same time, press and release the lock button (3) times. (Must be completed within 10 seconds)
4.) Release both buttons. The doors will lock/unlock to signal a successful initialization.
5.) If additional keys need to be initialized, repeat steps 3-4 within 30 seconds
6.) Switching the ignition to KL-R completes the initialization
Old Mar 7, 2013 | 03:50 PM
rfw's Avatar
rfw
Yes I did replace car battery - and I tried all of your suggestions, but the windows will still not open.
Old Mar 7, 2013 | 04:17 PM
ZippyNH's Avatar
ZippyNH
The functions of the buttons are assignable..it was an option at the dealer when buying the car, they are "dealer programable" in the cars computer....
not sure what happen...some cars have this feature turned on, so do not...but the range has always been very short....
A few folks with the sunroof got into trouble with this option....the button gets held down in a purse or pocket...and everything opens....letting in rain....
in my experance, the range of the auto window opening has been so short since new, it is not really useful.....
Old Jul 3, 2013 | 07:56 AM
wodturner's Avatar
wodturner
My 06 did the same, nothing worked. You have to get it programmed :( I got mine done by Helix here in Philadelphia. I got, locks unlock at the engine turnoff, windows and sunroof open with the fob. I don't know of a list of options of what's available to program.
Hope this helps.
Old Jan 30, 2014 | 12:02 PM
tonmilv's Avatar
tonmilv
Hello guys,
one of my keys works fine, all buttons and starts the car. but the other key only starts the car. i cant lock or unlock doors.
06 MINI
thank you
Old Jan 30, 2014 | 12:21 PM
PrplPplEtr's Avatar
PrplPplEtr
Originally Posted by tonmilv
Hello guys,
06 MINI
thank you
The key has a rechargeable battery that is charged when its in the ignition. If your "spare" hasn't been used in ages try using it for a couple of days to recharge the battery and see if it comes back to life.
Sent from my Galaxy Nexus using NAMotoring
Old May 7, 2018 | 07:01 AM
cdemarco4's Avatar
cdemarco4
Hey guys, old thread but does anybody have any definitive answer to the key opening the windows? With the summer coming, I NEED this feature. So far i've tried:
1) press button, release, then hold
2) press, release, press, release, hold
3) re-initalizing the key then tried #1 and 2 again
Any ideas??
Old May 7, 2018 | 08:58 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Going to move this to the Gen1 area.
Old May 7, 2018 | 09:23 AM
cdemarco4's Avatar
cdemarco4
hopefully we'll find some help there
Old May 7, 2018 | 12:55 PM
rkw's Avatar
rkw
That procedure is only to initialize the remote lock/unlock. If your car doesn't respond to remote window opening (post #2), the feature would need to be programmed into the car with a computer. A dealer can do it, or a shop with the necessary software. If you are tech savvy, you can also program it yourself using NCS Expert software (search the forum).
TREX
Nov 2, 2019 07:31 PM
bigramdizzle
Aug 6, 2019 09:19 PM
SosoMINI
Nov 22, 2015 03:17 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
sungjk
Aug 5, 2015 08:23 PM
