Interior/Exterior Ok...I joined the boost gauge club
Old Apr 2, 2004 | 03:53 PM
MSFITOY's Avatar
MSFITOY
I custom made a "one arm" mount for my boost gauge with a hacksaw, files, and a drill (my garage floor looks like a Taleban gun shop LOL). They're aren't any affordable mounts made for the Nav system yet and I don't see the need for two gauges around the pod. The right one on a Nav system would block the ventilation so my oil pressure/water temp would go down low like Andy's set up.
Thanks everyone for your help
I'm curious...how much boost are you guys getting with a 15% pully?
Old Apr 2, 2004 | 03:56 PM
bigpmj's Avatar
bigpmj
That looks really good where its at. I wouldnt have it any other way.
Old Apr 2, 2004 | 10:52 PM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
ryan got about 19 1/2 lbs of boost on the dyno, almost 20. i have the video to prove it. but i would expect at least 18 lbs at least. that was top of 4th gear.
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Apr 3, 2004 | 07:20 AM
aokdoug's Avatar
aokdoug
s-w just releasted a boost gauge that
goes to 25#. also perfect color match.
doug
Old Apr 3, 2004 | 11:18 AM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
Nicely done! :smile:
Old Apr 4, 2004 | 11:26 AM
sanddan's Avatar
sanddan
I also custom built a bracket to mount the gages using Autometer gages and pods. Here are some pics.
I trimmed the pod to fit tighter to the dash.
This shows the bracket design. I made it in steel (can't weld aluminum)
The stock sender is the green connector to the right.
Thanks to all the help in figuring out the wiring and vacuum hookups.
Dan
_________________
MCS, EB/W, Madness sway bar, Intake, EBC green pads,Madness pully,H-Sport Springs and lower bars,MSD c
Old Aug 31, 2004 | 01:00 PM
bbmykal's Avatar
bbmykal
Any other ideas out there for people with the NAV? The mechanical intstall looks doable what would you guys say is the difficutly rating? (8/10)
Old Aug 31, 2004 | 01:11 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Looks good! I see about 15 psi at redline with the 15% pulley.
Old Aug 31, 2004 | 01:19 PM
greatgro's Avatar
greatgro
Helix now carries a THREE gauge pod for the NAV. Me personally, I wish I had a third gauge (oil temp).
Old Aug 31, 2004 | 01:46 PM
bbmykal's Avatar
bbmykal
I didn't find the gauges on the Helix site. you got a link?
Old Aug 31, 2004 | 03:31 PM
greatgro's Avatar
greatgro
No. I think they are mentioned on his "news" page. I'd call him if you want more info.:smile:
Old Aug 31, 2004 | 06:25 PM
JustinLewis's Avatar
JustinLewis
this is with a 15% pulley??????? This makes me curious. What Gauge was he running? I have learned the hard way that some of the gauges out there are off.
Old Aug 31, 2004 | 07:22 PM
greatgro's Avatar
greatgro
Yeah there's no way a 15% is making more than 15lbs of boost - MAX. Maybe a tad more with the stock exhaust but 15 is probably the limit. I get 16 so far in hot weather and I've seen 16 1/2lbs once on a less humid day with my 19%. But I don't bring it to redline often any more.
Old Aug 31, 2004 | 07:30 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
I have NAV, and I took the easy route (due mostly to injury) and ordered the PROMINI gauge set and installed it prior to the Dragon Run. With a stock pulley I get just a bit over 10psi. 15% coming soon. I have plans for a homebrew 3 gauge cluster to go under the toggles. In there will go oil temp, water temp and volts.
Old Aug 31, 2004 | 11:32 PM
darkfact's Avatar
darkfact
Another thing you could do (I did this to install a third gauge aside from the 2 on the side of the tach) is use the existing ring bracket that holds the cup holder on the center console pillar (Or, I guess you could get another one if you want to keep the cup holder.) I took an autometer gauge pod and attached it to the side of the ring with a couple screws/nuts. Then fit the ring back around the pillar and tighten. Works great and looks nice too.
Filmy
15
Jun 6, 2023 06:27 AM
dinomaniac
Sep 18, 2018 04:19 AM
Oct 19, 2015 08:07 PM
molala
Oct 2, 2015 01:53 PM
gzaos
Sep 14, 2015 04:21 AM
