Interior/Exterior Mini roof rack fork mount update
Old Mar 22, 2004 | 08:34 AM
miniswami's Avatar
miniswami
I just picked up the fork mount bike tray for the factory rack. I haven't mounted it yet, but it appears of very high quality. Essentially it is the Thule V2 rack with MINI specific mounting hardware, including locks. It costs $125 which is no more than the thule or yakima version. I will post pics this week. I initally only ordered one because I was unsure of how it looked (no pic in accessory catalog), performed, etc.. I have already ordered a second. According to the instructions the only potential problem would be with rear spoiler clearance when the boot hatch is fully open. I am glad Mini did not skimp and the rack is as good as the aftermarket ones.
ps- I am not quite sure why some are concerned with holes being drilled- the sunroof requires two giant holes, and the rear spoiler I believe also requires holes, in addition to the mandantory third brake light. :smile:
Old Mar 22, 2004 | 08:52 AM
dave's Avatar
dave
pug poo picker-upper
You can cut down the length of the bike trays to prevent any interference with the spoiler. A final step would be to paint the "cut" end black to match the rest of the tray. That's what I did to my Thule trays when I cut them down.
The concern about holes in the roof is that when the bike rack is removed you still have visible holes in the roof.
Old Mar 22, 2004 | 09:13 AM
OctaneGuy's Avatar
OctaneGuy
Or slightly worse, visible covers to "hide" the holes.
Old Mar 23, 2004 | 01:52 PM
chollomo's Avatar
chollomo
its really sucks that you can't buy a regular roof rack for the mini... has anybody heard of any suction cup racks out there for the mini? that way you could have the strength of a roof mount without having all the wieght on the plastic rain guards
Old Mar 26, 2004 | 09:22 PM
PaulF's Avatar
PaulF
I bought some 1/2" x 1" aluminum bar stock from North Coast Metal Mart and a 1/4-20 tap. I screwed my Thule rack into some short aluminum bar pieces. I put the tray way to the side with the front a little closer to the middle of the car and the back sticking out at an angle to miss the spoiler. This morning I was looking at my work and it occured to me that if I put the fork on the back rack bar with the bike facing backwards the spoiler wouldn't hit the bike rack even if I put the bike in the center of the rack bars.
Old Mar 26, 2004 | 09:30 PM
sambusik's Avatar
sambusik
Paul, can you post some pics, interesting in seeing your setup..
Old Mar 27, 2004 | 04:22 PM
PaulF's Avatar
PaulF
I'm new here. How do you post pics? I can see an image button as I am editing this message, but it looks like I have to put my pics on another web site to use the image button.
Old Mar 27, 2004 | 04:52 PM
MiniCD's Avatar
MiniCD
I was about to suggest you turn the tray backwards. I mounted the Thule tray the 'correct' way around, and cut the ends off then realized they would fit with the fork mount towards the spoiler.
I used some flat bar stock which I tapped and then bolted through the metal clamps of the Thule front mount. I found there was still some movement so inserted the Thule cross-bar between the two trays to reduce the twisting. The result is I can now use the Thule wheel mounts just outboard of the MINI rack to keep the dirty wheels out of the car.
Accessory Products
Aug 10, 2015 01:35 PM
Aug 10, 2015 01:33 PM
Aug 7, 2015 07:12 AM
