Interior/Exterior OutMotoring Gen2 Custom Gauge Face Replacements
Old 06-01-2013, 01:55 PM
Sacred Disorder's Avatar
Sacred Disorder
Sacred Disorder is offline
I did not remove the whole speedo. I was able to use a 90 degree o-ring pick to pop all the plastic off. Once you remove the old face the silver overlay will come off with the old face and you have to transfer it to the new face. The buttons and all that stay attached to the speedo. The needle on the speedo will reset as well once the car is turned on. If you have any other questions feel free to pm me.
  #102
Old 06-01-2013, 02:43 PM
Kirby11's Avatar
Kirby11
Kirby11 is offline
Originally Posted by wzabrouski
Did you guys completely remove the speedo to change? If not, how did you remove the piece in the photo.
Picture on page 16 shows the lens being taken off with the trim attached:
http://www.fes-auto.com/upload/doc/5...tion_Guide.pdf
  #103
Old 06-01-2013, 06:32 PM
wzabrouski's Avatar
wzabrouski
wzabrouski is offline
Piece is not attached to the clear cover on the CM.
Attached Thumbnails OutMotoring Gen2 Custom Gauge Face Replacements-image-186567809.jpg   OutMotoring Gen2 Custom Gauge Face Replacements-image-4140189733.jpg   OutMotoring Gen2 Custom Gauge Face Replacements-image-3373543749.jpg
  #104
Old 06-01-2013, 06:53 PM
wzabrouski's Avatar
wzabrouski
On the CM there is two screw on the bottom that hold the speedo ring in place. They are not easy to get to without taking the center stack pieces apart and I am trying to avoid that.
  #105
wzabrouski's Avatar
wzabrouski
On the CM there is two screw on the bottom that hold the speedo ring in place. They are not easy to get to without taking the center stack pieces apart and I am trying to avoid that. I can get the clips with the o ring pick but I still have to access these two screws.
  #106
Old 06-01-2013, 08:18 PM
wzabrouski's Avatar
wzabrouski
Done. I am guessing the CM is different than the standard 2nd gen. You have to take the 2 side pieces that run along the center stack off. They pull off to the side me are held by pressure clips. This will give you access to the two screws hold the speedo trim ring that hold the face on. After you remove the 2 screws you will still not be able to completely remove the trim piece but it gives you enough room to remove the gauge face from the speedo. The black trim piece that is attached to the gauge face was a pit of a pain and I noticed that a few of the little stubs had the tips broken off after I removed the gauge face. I took the extra measure to put a tiny drop of hot glue on each of the stubs to make sure it stayed on. I then was able to wiggle the new gauge face in place. All in all not too bad but hopefully this will help any CM owners that want to do this mod.
  #107
Old 06-01-2013, 09:01 PM
wzabrouski's Avatar
wzabrouski
Some pics.
Attached Thumbnails OutMotoring Gen2 Custom Gauge Face Replacements-image-2285588041.jpg   OutMotoring Gen2 Custom Gauge Face Replacements-image-3269621223.jpg
  #108
Old 06-01-2013, 09:13 PM
SMOG's Avatar
SMOG
SMOG is offline
So you went from black to silver!?! I am trying to go the other way
I am pretty spooked about removing the needles and getting them back on without destroying some internals in the Tach or Speedo.
I tried getting the needle off a junkyard tach and I could tell I destroyed the functionality of the tach. It had rough spots in its rotation when I put it back together.
  #109
Old 06-01-2013, 09:19 PM
wzabrouski's Avatar
wzabrouski
Silver to white. I had these gauges on my last mini. Needles came off pretty easy but you do have to put a little pressure. I use my finger and gently squeeze while pushing on the gauge face. As you squeeze, push and you will it raise slowly.
  #110
Old 06-02-2013, 05:39 AM
SMOG's Avatar
SMOG
SMOG is offline
WHITE, no I get it, that makes perfect sense.
Since you just used your fingers to pull straight the needles off. What were you squeezing? Do you mean grabbing the needles firmly? No tools to pry them up(perpendicular to the gauge face) and off?
I really want to go black with mine. I would have purchased a JCW and already had the black faces but I need an automatic to drive since I have a bum leg given to me by a Chinese Anti-Personnel Mine and MINI did not make an Automatic JCW at the time.
BTW, how did that ECU Tune work out?
  #111
Old 06-02-2013, 12:05 PM
wzabrouski's Avatar
wzabrouski
If you want to send me your email address, I just took a short video to describe what I did. I love my tune from NM. They have put the tune on hold for the autos since the tyranny controller does not like the additional power and dumps some of the boost. In my opinion, you hear it more than you feel it. The tune made a HUGE difference in the way the car feels. I have the All4 so I needed the extra power.
  #112
Old 06-02-2013, 12:11 PM
wzabrouski's Avatar
wzabrouski
Also I noticed that the font size, maybe font changed on the Outmotoring faceplates when the 80mph moved to the center. In my opinion, this does change the look of the gauge face. The Outmotoring site only shows the gauge faces when the 70mph was in the center. I had these on my R53, and prefer the look of the ones I had previously. If you look at the photos I posted and the ones on their site, you can see the difference. I have reached out to Aaron from Outmotoring to clarify. I am guessing the font got smaller since one speedo went up to 140 and not they go up to 160. I prefer the look of the 140...
  #113
Old 06-02-2013, 12:30 PM
Texasfly's Avatar
Texasfly
Texasfly is offline
Black or grey ..
Trying to decide between the two ... Was thinking about the grey to offset my black interior a bit. Does anyone have pictures of either? The site shows the black, but I was wondering about the grey. Thanks.
  #114
Old 06-26-2017, 06:47 AM
aabcds's Avatar
aabcds
aabcds is offline
Found this video of how to remove the tach needle.
The following 2 users liked this post by aabcds:
bugeye1031 (11-01-2017), miniuy (06-07-2018)
07-16-2020 12:54 PM
Herleman
08-16-2015 06:41 PM
Emnotek
08-13-2015 05:47 PM
PSIChocolate
08-13-2015 12:46 PM
OutMotoring
08-06-2015 09:32 AM
Quick Reply: Interior/Exterior OutMotoring Gen2 Custom Gauge Face Replacements
