Interior/Exterior Mini Black Line: factory blackout parts
Old Feb 5, 2013 | 03:08 PM
  #26
Lady_May's Avatar
Lady_May
Originally Posted by Mini-LSE
I was looking into this too. Are they hard to swap out?
I found the ones for the cooper hard tops if you are looking for those. Just can't find the countryman ones. And from what I understand they are easy to install.
http://mini.sewellparts.com/oem-cata...SLCI-2012.html
Old Feb 5, 2013 | 05:25 PM
  #27
Weare138's Avatar
Weare138
http://mini.sewellparts.com/oem-cata...R60S-2012.html
these should be it for a 12 CMS
Old Feb 6, 2013 | 04:04 AM
  #28
Lady_May's Avatar
Lady_May
Originally Posted by Weare138
Yeah, but when you look at the actual part it says some kind of crazy grey "SCHIEFERGREY" not black, so is it the black line or is it grey?
Old Feb 6, 2013 | 04:12 AM
  #29
Mical's Avatar
Mical
That should be the black ones. If you have any questions email Justin at Sewell parts & he'll verify it for you.
Old Feb 6, 2013 | 04:50 AM
  #30
MBj's Avatar
MBj
It's called Shiefergrey, which is a real black grey, nearly black, but not black.
Nevertheless it looks realy good and black. Saw at the dealer.
Old Feb 6, 2013 | 04:57 AM
  #31
Lady_May's Avatar
Lady_May
Ahh, ok. I was getting confused when I was reading the parts. Thanks for the clarification!
Old Feb 17, 2013 | 03:05 AM
  #32
MBj's Avatar
MBj
Here what they look on a black CM.
The grey is the same as the side cuttles.
Old Feb 17, 2013 | 05:23 AM
  #33
joshuabowman's Avatar
joshuabowman
that looks good. I think I may have to get these. as for swaping them out its just a lot of clips. i found a small flat tip screwdriver or a plactic pnl tool works on the rings. I took a look at my tail lights when i had to have the uk light mod done to mine.
Old Feb 17, 2013 | 06:33 PM
  #34
Lady_May's Avatar
Lady_May
Oooo. I was debating but after these pics I think I'm sold.
Old Feb 19, 2013 | 09:59 AM
  #35
Here are the parts :
Headlights are european and will take some time to get in.
http://www.ecstuning.com/Search/51132254023/
http://www.ecstuning.com/Search/51132254028/
Rear taillight trims :
Are available in the US now
http://www.ecstuning.com/Search/51132296301/
http://www.ecstuning.com/Search/51132296300/
Old Mar 31, 2013 | 03:28 AM
  #36
komet155's Avatar
komet155
Does anyone know if there's a blackline version of the boot lid handle (that big thick piece of chrome above the license plate)?
Old Apr 1, 2013 | 05:01 AM
  #37
Mini-b10's Avatar
Mini-b10
As far as I know there is not one. I ordered another one and had it painted. Looks a lot better now. If you go this route, I think it's like $50 for the piece and depending on what a painter will charge you, it should be under $100.
Attached Thumbnails Mini Black Line: factory blackout parts-emblems.jpg
Old Apr 1, 2013 | 06:06 AM
  #38
komet155's Avatar
komet155
Thanks!
I just ordered the paintable one and will either paint it the same black as my roof OR body color. I'm going to photoshop the black option ahead of time to see if it goes well on my car with the black taillight frames on either side. I wouldnt want the back end to look too "busy."
Old Apr 1, 2013 | 06:43 AM
  #39
Komet , are you talking about the R56 version primed boot handle?
Old Apr 1, 2013 | 08:06 AM
  #40
komet155's Avatar
komet155
Yes, part #51132754240. I have a 2013 Cooper (non-S) which is equipped with a chrome handle.
Old Apr 1, 2013 | 09:22 AM
  #41
Yes,
Thought you were talking about a possible black line version of the R60 handle / emblem.
You could get the primed version and paint or wrap it so if you ever go back to stock you will have your chrome version.
R56 R57 models
http://www.ecstuning.com/Search/51132754240/ES77826/
I think it would go well with the Black Line Trim around the tailights. Also if you can paint it to match the exact color of the blackline w/ gloss.
Old Apr 1, 2013 | 10:13 AM
  #42
komet155's Avatar
komet155
Thanks!
Old Sep 1, 2013 | 08:42 PM
  #43
inh's Avatar
inh
It looks like this might actually be available now:
http://mini.sewellparts.com/oem-cata...60SX-2012.html
I really dig the photos I've seen of the rear lights, but has anyone seen them ON a countryman?
Old Sep 3, 2013 | 12:24 PM
  #44
The kit is available for the rear black-line taillights with anthricite trims.
#1 Retrofit Kit For MINI Black Line Lights Part # 63212280158
http://www.ecstuning.com/Search/SiteSearch/63212280158/
The side turn signal lamps are not available yet. #3 63132221503
But the front headlight trim kit is to match the rears.
Headlight Trim Ring Gray - Set #4
http://www.ecstuning.com/Search/SiteSearch/51132254023/ES2635829/
Dec 23, 2015 10:36 AM
tr3y003
Oct 22, 2015 10:48 AM
phrza81
Oct 10, 2015 11:37 PM
OutMotoring
Aug 6, 2015 09:32 AM
