Interior/Exterior Doing a perfect projector retrofit on '11 R56
Old Nov 6, 2012 | 10:16 AM
  #26
calforhelp's Avatar
calforhelp
Originally Posted by themitch22
Did you mount the projectors onto the halogen reflectors? I just cut a hole in the reflector and used silicon RTV to glue the Morimoto mini H1's directly to the reflectors, no way to rotate adjust it but I can use the x and y adjusters.
Look through the build and you'll see that I used a ton of JB Weld and JB Quik to hold everything together. It worked great and is still holding strong.
I too attached the projector to the reflector bowl. I did so without it touching anything else so I can just use the stock adjustment screws on the outside of the headlight housing to adjust the aim. It worked flawlessly.
Old Jul 3, 2013 | 01:58 PM
  #27
JonsR56's Avatar
JonsR56
Those lights look amazing calforhelp. I went to a shop in Alhambra and they quoted me almost $700.00 for morimoto projector convertion kit/hid incl installation. Awesome job on your lights.
Old Oct 15, 2014 | 03:33 AM
  #28
Sok Sombath's Avatar
Sok Sombath
hey, nice one you got there.
Do you have any problem like weird flickering whenever you startup the engine?
I have this problem with 2012 Countryman. Does retrofitting from H13 stock halogen to D2S solve this problem?
Thanks before hand man!
Old Oct 15, 2014 | 08:26 AM
  #29
calforhelp's Avatar
calforhelp
Yep, I had a problem just like this. It was solved by a custom wiring harness.
I was getting a bulb out warning and the HIDs were flickering without being able to turn them on. This was with using a regular CAN-BUS harness from TheRetrofitSource. Matt over there had a harness custom made for me that takes power from the battery instead of the stock wiring. The harness included a capacitor to level out the flickering, and a load resistor to prevent a bulb warning on the low beams. The harness was $50 and works perfectly, I still use the OEM headlight switch to turn them on so it essentially works as stock.
Call TRS and ask for Matt. Tell him that you need the same custom harness that he made for a 2011 MINI Cooper S back in May '12. It was for order number 18817. It was a custom H13 harness made with a capacitor to level out the flickering.
Old Oct 19, 2014 | 02:14 PM
  #30
s0n1c's Avatar
s0n1c
Do your high beams and flash-to-pass work? I have warning cancellers I used for the low beam, but had to leave them off the hi-beams because they wouldn't work if I connected them. So my lows and highs work (just a cut-off removal), but my car whines that my high beams are not working for both lights each time I start the car.
Old Oct 20, 2014 | 09:27 PM
  #31
calforhelp's Avatar
calforhelp
Yep, everything works on the headlights as if they were stock. I don't remember where I used the load resistors to cancel out the bulb out warnings but I eventually coded the car to ignore the warnings and then took all of my resistors off.
It sounds like you just need your car coded to disable the bulb checks. If you're in the Los Angeles area, I provide this service for $20. If you're elsewhere search the forum for "NCS Expert Directory" to find a member near you!
Old May 3, 2022 | 07:47 PM
  #32
OhNo2's Avatar
OhNo2
I am planning to do something similar to my 2013 MCS. Can you give me the diameter of the turn signal hole? I want to see if the part that I want will fit into it. I want to have an RGBW demon eye inside the dual projector that I can utilize as a turn signal.
Alkaidovich
Jan 30, 2021 01:35 AM
jwmolmen
Sep 22, 2015 10:00 AM
patrioticmini
Aug 20, 2015 10:54 AM
panerai21
Aug 18, 2015 02:15 PM
marendt428
Aug 8, 2015 04:44 AM
