Interior/Exterior Black LED Tail Lights from OutMotoring
Old May 24, 2011 | 08:14 PM
  #26
MrCooperS's Avatar
MrCooperS
Moderator
Haha your car is great already! But I can think of a couple things for your MINI...
Have you ever looked into DuelL parts?
-sorry to thread jack-
Old May 24, 2011 | 08:20 PM
  #27
onefish2's Avatar
onefish2
They do have some nice pieces. They sell a CF part that replaces the plastic part under the wipers. They call it a carbon cowl top.
Wonder where I can find a reseller in the US?
Old May 24, 2011 | 10:06 PM
  #28
cop1406's Avatar
cop1406
I'm liking those alot.
Old May 24, 2011 | 10:13 PM
  #29
cop1406's Avatar
cop1406
Try these guys!!
http://battleperformance.com/contact.html9
Old May 24, 2011 | 10:19 PM
  #30
sooper_cooper's Avatar
sooper_cooper
I can't help myself... I am trying so hard to find something else to do to my car. Maybe I will get rid of the JCW suspension and get some KW V2 coilovers from Way Motor Works next .
Do it, you won't regret it. The ride is phenomenal and the ride height and damping rates are adjustable too. It's a great setup and perfect for both track and street use.
Old May 25, 2011 | 10:39 AM
  #31
ironbarista's Avatar
ironbarista
Do they make it for left hand drive? That looks like for right hand.
Old May 25, 2011 | 04:49 PM
  #32
onefish2's Avatar
onefish2
This thread is already all over the place so it won't hurt to ask this. So I decide to go with Coilovers... who dials everything in and sets the ride height. Then who does the alignment. And what about corner balancing?
Old May 25, 2011 | 06:03 PM
  #33
sooper_cooper
I took mine to a speed shop here in the DFW area that has experience with all of the above. You can tell them where you want the ride height to be based on your road conditions and how you plan to use the car. I didn't slam mine but did get rid of all the wheel gap.
What I did was to have the KWs installed and an alignment done and then I rode around on them for two or three weeks to let the springs settle. Once they did I had the ride height re-adjusted (raised up a little since it had gone a bit lower) and at that time I had the car corner balanced and re-aligned once more.
I found that the car did feel more planted after the corner balance and since the the final adjustments the ride height has remained where I set it.
I set the rear dampers in the middle and I adjust the fronts up or down for track days and street driving as necessary.
So far it's been perfect. If you enjoy the sporty feel of the JCW suspension you'll really enjoy the ride, improved handling characteristics and adjust-ability that the KWs provide.
And to keep the thread on subject - I plan to order a set of the clear LED tail lights as soon as Outmotoring has them in stock.
Old May 25, 2011 | 06:06 PM
  #34
onefish2's Avatar
onefish2
Excellent. Thank you!! Been waiting 2.5 year to read a review like that on NAM. Perhaps you should make that into a FYI type of post.
Do the KW V2s from Way come with camber plates?
Old May 25, 2011 | 06:39 PM
  #35
sooper_cooper
The KWs don't come with camber plates. I added a set of Vorshlag in the front and some H-Sport lower control arms in the back to adjust my camber settings. I did it for track usage though. You may not need to change your camber settings in general if you don't track your car, but of course it doesn't hurt to have that capability.
Old May 25, 2011 | 06:46 PM
  #36
MrCooperS's Avatar
MrCooperS
Moderator
Personally, I think the KW V2s are overkill for a daily driver car. Aren't these meant to be track suspensions? I would recommend the Koni Yellows with your choice of lowering springs - H&Rs or TSWs. But you can also call Way and see what he recommends.
Old May 25, 2011 | 08:11 PM
  #37
sooper_cooper
I use my JCW as a daily driver and the KWs work great in that regard. The H&R and TSW springs as well as the Koni yellows are all great pieces but, in my opinion, and after using the JCW suspension myself for almost 3 years, not enough of an upgrade over the suspension that onefish is currently using to warrant the switch.
Old May 25, 2011 | 09:37 PM
  #38
sLy201's Avatar
sLy201
ooohhh wee .. those are some hot lights and it looks so mean on the CR !! def want to get them ... PS dig the black headlight rings
Old May 26, 2011 | 07:15 AM
  #39
sLy201's Avatar
sLy201
if you do i know someone who will buy your old JCW suspension
Old May 26, 2011 | 07:16 AM
  #40
onefish2's Avatar
onefish2
I will keep you in mind if I go the coilover route.
Old May 27, 2011 | 06:04 PM
  #41
Davidoyo's Avatar
Davidoyo
My friend also just got these for his R56, I'll take some photos tomorrow...
Did you take those pictures yet?
I love to see more examples of the lights
Old Jun 15, 2011 | 08:25 PM
  #42
NavyNUKE's Avatar
NavyNUKE
Anyone know if these will work for the '11s? I saw something about replacing the reverse light but the reverse light for the 11s isn't in the tail light assembly.
Old Jun 16, 2011 | 08:47 AM
  #43
ngweibing's Avatar
ngweibing
i liek those tailight
Old Jun 20, 2011 | 01:27 PM
  #44
sooper_cooper
Outmotoring has stock in again, both the black and clear versions. Just ordered a set of the clears!
Old Jun 21, 2011 | 01:37 PM
  #45
Emvin15's Avatar
Emvin15
Just purchased a Black Set!! Going to look absolutely amazing once installed!!!
Old Jun 21, 2011 | 10:46 PM
  #46
onefish2's Avatar
onefish2
I ordered a pair as well. They will arrive on Thursday. I will post pics after I get them in.
Old Jun 22, 2011 | 12:48 AM
  #47
sooper_cooper
Not sure yet exactly when my arrive but I'll post some pics too when installed. I'm guessing sometime early next week.
Old Jun 22, 2011 | 08:53 AM
  #48
dez's Avatar
dez
+1 on the working on 11's question... these look hot!
ryoma111, your MINI is smokin
Old Jun 22, 2011 | 08:57 AM
  #49
onefish2's Avatar
onefish2
Contact Aaron at outmotoring.com. He should be able to tell you if these will work on the 2011 cars.
Old Jun 23, 2011 | 03:08 PM
  #50
bertyboy69's Avatar
bertyboy69
Tailights
Got my tailights in today!
too bad the cleart plastic on both of them is cracked in the corners
