Interior/Exterior Ultragauge Install
Old Feb 17, 2018 | 02:10 PM
  #101
philwarner's Avatar
philwarner
Originally Posted by Mini Clementine
Reviving a dead thread? Well if anyone is still wondering if UG can drain your battery, yes it can. But I think I have a fix.
Here's my story (in short). Bought UG ex Ver 1.20. Plugged it in and set gauges. Turned car off and noticed UG screen stayed on... and on... so read manual and changed settings. Next morning, clock and date were zeroed and I got a pending P15E8 error code - likely due to draining battery.
Emailed UG, asked for settings for Mini Cooper. They replied it's impossible to drain battery. Reset it to factory settings - but then the screen stays on. So I think I have the settings right now.
Starting at p.45 of the manual so you can find your way around the UG.
Power ON detect - set to Mode 2
Power OFF detect - set to mode 5
Batt High threshold - set (or leave) at 13.2V - essentially tells UG to turn on when voltage is at 13.2V
Batt Low Threshold - set to 12.85 - tells UG to turn off if voltage is under 12.85V after you tried 4 times**
Power Off Retries - I set to 4 - tells UG if you find voltage is under 12.85V and you tried 4 times and it is still under 12.85V, turn off.
I put these settings and started the car with no clock/date issues after 8 hours sitting and again after another 24 hours sitting. Hopefully this does the trick and the code goes away after some time. I like the larger screen display and I've already made a nice mount so I'd like to keep the UG if I can.
I ran across this thread while looking for where the OBDII plug is hidden. I found pics of the plug location elsewhere and it appears that the cover should be pried down by the end closest to your knee, right? And it looks like there are pins in the cover - any problem if an Ultragauge is plugged in semi-permanently and the cover left open?
And...are there any battery drain issues with a UG on 2004 models? Should I use the above listed settings on my 2004?
Old Jul 3, 2020 | 04:08 PM
  #102
Way2Fst4U's Avatar
Way2Fst4U
Originally Posted by Bnourai
...R56 OBD will not support oil temp or pressure.
Well that's a bummer...the main reason I wanted an UltraGauge.. :/
Old Jul 3, 2020 | 06:17 PM
  #103
Lex2008's Avatar
Lex2008
Why do you want oil temp? I had it on a car and really... It was kinda pointless.
Old Nov 12, 2020 | 07:45 AM
  #104
dstressman's Avatar
dstressman
Originally Posted by 5zero4
I'm using Coolant temp, Intake Air temp, Voltage, Timing, Engine load, and MAP. Would have liked to have Oil temp and Oil pressure, but no go unfortunately.
oil pressure and temp aren’t available? or just not enough screen space ?
Old Nov 12, 2020 | 08:18 AM
  #105
Lex2008's Avatar
Lex2008
You need to install an oil pressure sending unit onto the engine and then to the gauge (If the gauge can accept the signal. My gauge does). Coolant temp is available from ECU.
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
