Interior/Exterior Gauges
Old Mar 9, 2011 | 07:29 PM
minics07's Avatar
minics07
Gauges
What is a good set of gauges for the MCS?
Old Mar 10, 2011 | 11:56 PM
howsoonisnow1985's Avatar
howsoonisnow1985
I have OEM VDO gauges, but many like Auto Meter
Old Mar 11, 2011 | 02:00 PM
minics07's Avatar
minics07
Thanks!!! What are the gauges that are the most need ? Water/ boost/ oil ? And thanks for any input!!! New to the mini world.
Old Mar 11, 2011 | 03:35 PM
Capt_bj's Avatar
Capt_bj
what do you want to know about?
sorry, but it sounds like you don't know what any of this data means therefore you are just looking for bling ....
If looking for bling buy a couple of the right size and mount 'em but don't bother to hook 'em up. Most people look at your car when it is parked anyway . . .
OTOH what's the most useful? Depends on your concerns or what problem you are trying to solve.
overheating: water temp (maybe oil temp)
lubrication: oil pres' and or oil temp
ignition: volts and or amps
blower: boost pres'
more specific????
if one were going to install 4 gages in a MINI (forget what might already be there 'cept the tach and speedo) what would you's be?
Old Mar 11, 2011 | 05:01 PM
Vollgas's Avatar
Vollgas
Marshall Instruments makes a set of gauges that match Gen 1 factory gauges.
Oil PSI, Oil Temp, Water Temp, Volt, Vac./Boost
Top quality
They have web site.
Old Mar 11, 2011 | 06:26 PM
minics07's Avatar
minics07
Top quality
They have web site.
Thanks I will check it out.
Old Mar 11, 2011 | 06:34 PM
minics07's Avatar
minics07
Capt bj .... I'm not looking for bling. I thought that it would be good to be able to see what was going on with the car. I am use to being able to see gauges on my other cars. Do I not need gauges?
Old Mar 14, 2011 | 01:00 AM
howsoonisnow1985
I do wish I had boost pressure, someone noted that I could that with oem type VDO gauges that look identical to the MINI oem ones.
Old Mar 16, 2011 | 07:00 AM
rjb's Avatar
rjb
Here's the tread for Marshall. Long thread, but some pictures toward the end. I installed them and love them.
https://www.northamericanmotoring.co...ry-gauges.html
Old Mar 16, 2011 | 10:10 AM
minics07's Avatar
minics07
Thank you very much!!! Which ones do you think are most needed water/boost or oil?? I'm use to these already being on the cars I drove!!! Thanks for your help.
Old Mar 16, 2011 | 06:54 PM
rjb's Avatar
rjb
I have the water temp, oil pressure (both of those I consider mandatory) and boost gauge. I'd like to add the oil temp, but because of the design of the oil pan on the Gen 2 cars the sender is an issue. If you have a Gen 1 car, I understand you can install an adapter where the drain plug is for the sender unit. Check with Steve at Custom Mini Shop (SRTech), he should have everything you need to do the job (mounts, gauges, etc)
Old Mar 16, 2011 | 07:10 PM
Checkmate_2006's Avatar
Checkmate_2006
I agree with rjb. I also have the Marshall gauges and have the oil pressure, water temp, and boost gauges. The Marshall gauges look the best IMO!
Old Mar 16, 2011 | 08:17 PM
minics07's Avatar
minics07
I have a R56!! I like your set up with the 3 gauges it looks really good. I just finished reading all the post from the thread that you sent me!!
Thanks for input, that is the setup I'm going with
Old Mar 16, 2011 | 08:26 PM
minics07's Avatar
minics07
I have had my mini for 1 1/2 weeks now. So the gauges are just the start of my mods!! Thanks for all your guys input it's greatly appreciated
Old Mar 16, 2011 | 10:02 PM
Checkmate_2006
after your first it's all down hill after that.
bahman
Feb 14, 2016 10:29 AM
Doc Pain
Oct 28, 2015 07:09 PM
Snotrocket555
Oct 1, 2015 08:59 AM
papawhiskey
Sep 30, 2015 02:50 PM
aldito2
Sep 30, 2015 10:44 AM
