Interior/Exterior Want to add an auxiliary input
Old Jan 3, 2011 | 03:19 PM
gabber's Avatar
gabber
So Its time to add my aux input thing for my ipod. Im a cheap *** when it comes to spending money and I found this
http://www.mossmini.com/Shop/ViewPro...eIndexID=89613
but I also seen this one somewhere else b 4 for $20. Does anyone know where I can get it cheaper? And has anyone ever used this method? Is it plug and play or not?
Old Jan 3, 2011 | 03:20 PM
meanmeanstride's Avatar
meanmeanstride
That's the correct part for the Mini. I looked up the procedure and it looked like a lot of work so I took it to my dealer to install. They charged me somewhere around $200 for the part and labor a few years ago. Completely worth it but expensive
Old Jan 4, 2011 | 03:13 PM
mini53's Avatar
mini53
You need a 12 pin connector and the right size, it is a common plug in europe so you can source it there, however with shipping etc, you are probably not going to save much.
This should fit and it is $15, last one left and I dont know how much shipping is.
http://cdchangeremulator.com/accesso...t/prod_67.html
Old Jan 4, 2011 | 04:22 PM
Eric_Rowland's Avatar
Eric_Rowland
Someone made a DIY aux-in years ago and posted a 'how-to' in this forum. A patient search ought to find it.
Old May 27, 2011 | 02:23 PM
jsupak's Avatar
jsupak
Go here to find the part for $39.95
http://www.outmotoring.com/mini-coop...pod_mp3_hookup
Old May 27, 2011 | 02:40 PM
Capt_bj's Avatar
Capt_bj
Ouch - I've installed this in about 20 minutes and most of that time is the owner deciding where they want the plug mounted.
Once you've done one you know where to reach behind the radio, then it simply plugs in and all you need to do is fix the other end someplace.
Old May 27, 2011 | 08:04 PM
firemerc13's Avatar
firemerc13
From: Just south of the White mountains, just north of the lakes region, in other words, Rumney, NH
i just did mine. you may need a ground loop isolator if you recharge your ipod while playing it.
Old Sep 19, 2011 | 10:50 AM
Mynewt's Avatar
Mynewt
I found it took less than 90 seconds to get mine plugged in and working and for the last couple months, i just used it hanging out from under the dash. But this weekend I finally had the time to mount it properly. It took about 2 hours. I've never taken this interior apart before so a third of that time was spent reading. And half was spent figuring out how to apply what I had just read.
I ended up mounting mine next to the mirror switch (where some of you have seat heater switches). I originally thought I'd put it with the toggles for the windows and locks, but this location was way easier.
Not pictured is the little plug I made to cover it when not in use. If any of you have ever owned old Saabs, you know the horrors of getting debris in little vital openings in your center console. (That's where the Saab ignition is and debris can keep the key from being fully inserted --but I digress)
Old Sep 19, 2011 | 01:22 PM
dannyhavok's Avatar
dannyhavok
+1 for the outmotoring kit. It's only $40 and it's a quick and easy install. My time is worth more than the difference between the OutMotoring and an involved DIY. Also, they're a good vendor to deal with and I'm glad to give them the business. Aaron is helpful and prompt with responses and shipping.
Old Sep 26, 2011 | 09:55 PM
Mootsdog's Avatar
Mootsdog
Here is one for $36.95 with free shipping. They are good people to deal with and are close to my house. http://www.minicarparts.net/Parts/M3367.cfm?ref=nxtfb .
Old Sep 26, 2011 | 09:58 PM
Mootsdog's Avatar
Mootsdog
Mynewt- That's a cool location. Seat heater buttons keep from doing it. I'm mounting it in my Parcel shelf.
QuickCooper
Dec 29, 2016 06:46 PM
ShadyCoop
Sep 20, 2015 08:57 AM
weaver9000
Sep 14, 2015 05:48 PM
Norton70
Sep 7, 2015 05:06 PM
Ntety
Sep 2, 2015 08:39 PM
