Interior/Exterior The $2 Wiper Delete Kit
Old Dec 2, 2010 | 02:09 PM
  #51
automan21's Avatar
automan21
How hard is it to just wipe the snow away with a snow brush in the winter which you are supposed to do for saftey on all the window before you drive. Using the wiper on iced or wet/heavy snow will likely damage the wiper motor or arm If you put a nice coat of way on that rear window then the rain will just bead off it and the defroster will keep snow from staying on there.
To the OP, great write up Thanks.
Old Dec 2, 2010 | 02:28 PM
  #52
cop1406's Avatar
cop1406
I'm gonna do mine. I like it.
Old Jul 17, 2011 | 05:15 PM
  #53
ryangschultz's Avatar
ryangschultz
Originally Posted by 10Zero
Both from Lowes, a 1" plastic hole plug, and a GM automotive trim fastener (for the water line). Each packet comes with 2ea, so you can do 2 wiper deletes. A little black RTV under the lip of the hole plug before popping it in, and a little cleanup on the glass with some WD40 (excess RTV).
Parts for this project at Lowes:
1" Plastic Hole Plug, 2pk, $1.39, p/n 139483
GM Automotive Trim Fastener, 2pk, .68cents, p/n 138211
RTV Silicone (your preference)
10Zero, this is great! I just did mine and got those exact parts you listed from Lowes. Worked great! Looks great too, definitely looks a lot cleaner than with the wiper.
Old Jul 17, 2011 | 10:13 PM
  #54
10Zero's Avatar
10Zero
Originally Posted by OCKOLBY
Reviving this thread. I bought the black 1" cap from LOWES and inserted a small irrigation nipple in the middle of it. Now my MINI can pee about 15 feet behind its-self...lol. Tail-gaters beware.
Damn, haven't been back in this thread for a very long time...and I busted a gut when I read this!
  #55
10Zero's Avatar
10Zero
Glad it worked out, it's a very clean and cheap mod...and doesn't look ghetto!
Old Jul 18, 2011 | 04:37 AM
  #56
ryangschultz
To think, I almost bought one of the $25 kits!
Old Oct 23, 2011 | 04:49 PM
  #57
S&CLC's Avatar
S&CLC
yep, $2.00.
Lowe's.
did it today.
simple.
looks awesome.
1000 thanks 10Zero.
Old Oct 23, 2011 | 05:46 PM
  #58
chaswyck's Avatar
chaswyck
I had the $25 kit on my list of things to get when my MINI arrives. Thanks for saving me 23 bucks! Looks great and where I live we don't have to worry about snow! In the Outmotoring description for their wiper delete they call the wiper 2 and a half pounds of pure ugly! I agree. I might feel differently if I had to drive in snow all the time, but it was about 90 degrees here today! Hell, it hardly even rains!
Old Apr 15, 2012 | 07:42 PM
  #59
dboard7's Avatar
dboard7
so my window was broken into and the bolt on the motor had seized to the motor itself. i dug up this old thread and did the mod, great idea! i also drilled a hole and put a small nozzle in the hose and well look below to see the results lol
Old Apr 16, 2012 | 12:16 PM
  #60
AdrenaliNate's Avatar
AdrenaliNate
I have since replaced my squirter with a vinyl-wrapped headset cap, but people sure got a kick out of it.
Have you measured how far it shoots? With a 1/4" drip line connector, I measured about 15 feet. Let the pissing contest begin!
Old Apr 18, 2012 | 06:21 AM
  #61
dboard7's Avatar
dboard7
Mine was right about the same not sure what I used I just found it at home and it fit so I put some silicone on it and its holding lol. I have been tempted to use it on a few people already but I have been able to hold back for now lol
Old Apr 18, 2012 | 07:10 AM
  #62
Porthos's Avatar
Porthos
Has anyone deleted the motor in their when doing this?
Old Apr 18, 2012 | 07:20 AM
  #63
dboard7's Avatar
dboard7
my motor is out, its just 3 bolts pretty easy to do
Old Apr 18, 2012 | 08:16 PM
  #64
Porthos's Avatar
Porthos
Might do this before the Dragon
Old Apr 18, 2012 | 09:05 PM
  #65
AdrenaliNate
The wiper post is attached to the motor, so yes, it needs to come out.
Old Apr 22, 2012 | 07:46 AM
  #66
Tyler Colin's Avatar
Tyler Colin
LOL how do i even turn on the rear wiper...DELETE
Old Apr 22, 2012 | 09:07 AM
  #67
S&CLC's Avatar
S&CLC
2 doll-lah, kah-leen ree-arh.
thanks again 10Zero
Old Apr 22, 2012 | 02:58 PM
  #68
Tyler Colin
Deleted... thanks!
Old Jul 14, 2012 | 07:15 PM
  #69
CooperS24's Avatar
CooperS24
This worked really well! I went with the bolt and reverse original grommet technique. the plastic plug looks a little cleaner but I'm happy with the results..
Old Aug 9, 2012 | 01:35 PM
  #70
LiquiDGD's Avatar
LiquiDGD
This could be used as the pump for intercooler sprayer, has anyone tried this mod yet?
Old Aug 9, 2012 | 01:57 PM
  #71
Bigprfed22's Avatar
Bigprfed22
Pump is part of the wiper motor, they are both one unit.
Old Aug 9, 2012 | 02:17 PM
  #72
NewCooperFanatic's Avatar
NewCooperFanatic
I have no idea how you guys can actually even think about doing this!!
The ole R50 I have kicks up so much crap that I regularly use the rear window wiper haha.
If I could I would do this though, very clever.
Old Aug 10, 2012 | 02:43 PM
  #73
LiquiDGD's Avatar
LiquiDGD
http://www.madnessmotorworks.com/mad...-diverter.aspx
This is what mod i was refering too, they state they they used the rear wiper motor... Any thoughts?
Old Aug 10, 2012 | 02:47 PM
  #74
Bigprfed22's Avatar
Bigprfed22
It would be a lot of tubing but give a shot. It can be done
Old Aug 10, 2012 | 10:41 PM
  #75
LiquiDGD's Avatar
LiquiDGD
I was thinking or relocating the motor into the engine bay, as I have some room after removing the factory snorkle. I am still in the decision making process, so we shall see. I live in AZ so this would be a good mod for the heat.
