Interior/Exterior Mini Alarm
Old Oct 6, 2013 | 10:31 PM
  #51
Jmaxxz's Avatar
Jmaxxz
Just finished, I've successfully installed the factory alarm in my 2012 mini cooper s. So it is possible, but let me warn anyone looking at doing it. It is hard.
Pictures coming soon, but here is the quick summary:
  • Remove battery connectors
  • Remove wiper arms
  • Install tilt sensor/siren under wiper motor
  • Install hood switch
  • Run wiring harness to the through the firewall on the driver's side
  • Remove all interior panels
  • Remove Radio
  • Remove A pillars
  • Remove top of dash
  • Remove Remove Remove
  • Wire up CAS and steering wheel. (Note the CAS is under the top of the dash just above the steering wheel.)
  • Run rest of harness over to the fuse box on the passenger side. (Pick a very direct route as harness is barely long enough. I went under the glove box.)
  • Wire up all the connections in the fuse box
  • Run remaining wires up A-pillar on the (right) passenger side
  • Install sensor in head unit
  • Close up and put it all back together
  • Get coding with NSCExpert ($302 added to the FA)
Words of warning:
  • Wiring diagram uses German abbreviations for colors.
  • Harness is shorter than you would think.
  • A lot of the connectors are in what I can best describe as cases. These will prevent the insertion of pins. You must remove these cases first.
Took me two days to do, and about 20ish hrs.
Old Oct 7, 2013 | 09:37 AM
  #52
Thanks for the update:
For the parts # I have the
65730445530 to 9/2009 R55/ R56 models.
http://www.ecstuning.com/Search/SiteSearch/65730445530/
65120443179 from 9/2009+ R55/ R56 models
http://www.ecstuning.com/Search/SiteSearch/65120443179/
65732154413 to 9/2009 R57 models
http://www.ecstuning.com/Search/SiteSearch/65732154413/
65732157425 from 9/2009+ R57 models
http://www.ecstuning.com/Search/SiteSearch/65732157425/
Old May 3, 2022 | 03:14 PM
  #53
Jmaxxz's Avatar
Jmaxxz
Install guide in post #48 of this thread. The pictures I promised and never delivered are below (apparently the lighting, the camera, and the photographer all were terrible):
The right side cowl needs to be removed
Left side windshield cowl needs to be removed
Wiper motor is on the left side, the rubber grommet on the far right side of this photo is where I ended up running the wires through the firewall
Wiper motor with siren installed to the left of it. (apparently the lighting and my phone's camera were pretty terrible in 2013)
This is where the hood switch gets installed
Kombi wiring exposed, we need to attach a wire here to enable the red flashing light
Taking apart the dash
Success
Old May 4, 2022 | 07:06 AM
  #54
Thanks for the update,.
Old Apr 6, 2023 | 04:05 PM
  #55
ApexF60SE's Avatar
ApexF60SE
Curious, is there an alarm retrofit kit available for F60 2018 Countryman SE?
I installed an interior rear-view mirror with compas and remote garage door opener and exterior auto-dim mirror triggered from the light sensor in the interior mirror. That mirror has the bump haning down with an LED meant to flash with the armed alarm. I'd like to make that work if possible.
Old Apr 7, 2023 | 07:33 AM
  #56
I dont think there is a retrofit kit. Its a factory option. Its would be under here: https://www.realoem.com/bmw/enUS/par..._SE_ALL4&mg=03
https://www.northamericanmotoring.co...em-on-f60.html
https://www.minif56.com/threads/alar...etrofit.93209/
MINI now has these advanced Cameras that record.
https://www.ecstuning.com/b-genuine-...0/66215a38dc1/
You can get the individual parts but i dont think its prewired. Thats for people that optioned from factory.
https://www.realoem.com/bmw/enUS/sho...diagId=65_2599
silvia
11
May 1, 2010 08:32 PM
odobo
May 12, 2008 11:22 AM
d2mini
12
Dec 5, 2003 06:37 AM
AK430
Apr 3, 2003 05:51 AM
aerodragon
Jun 17, 2002 11:56 AM
