Interior/Exterior boot handle
Old May 8, 2010 | 03:14 PM
tmo8462's Avatar
tmo8462
boot handle
Does anyone have a write up on how to remove the boot handle? Or know how to do so?
Old May 8, 2010 | 04:55 PM
onefish2's Avatar
onefish2
Simply remove the screws and then disconnect the plug.
Old May 8, 2010 | 04:56 PM
tmo8462's Avatar
tmo8462
what screws?
Old May 8, 2010 | 05:18 PM
rkw's Avatar
rkw
4 screws, look under the handle.
Old May 8, 2010 | 05:19 PM
Uncl3's Avatar
Uncl3
That's the way to do it.
Old May 8, 2010 | 05:24 PM
tmo8462's Avatar
tmo8462
Thanks.
Old May 9, 2010 | 01:37 PM
TyCrox07's Avatar
TyCrox07
The only thing that concerned me when removing mine was the electrical connection. A firm pull will undo it, nothing special needed.
Old May 9, 2010 | 02:48 PM
tmo8462's Avatar
tmo8462
Thanks everyone I managed to get it off fine. The wiring was a little tricky didn't want to break it. I put some tape on it to make sure it didnt go inside the boot and I wouldnt have to take it all the way apart to get it out.
Old May 10, 2010 | 03:03 AM
swooshmac's Avatar
swooshmac
so what cool thing are you doing now tmo? hey dude, how is the weather down there anyways? trying to do a roadtrip down south in Spain this long weekend, but weather is sucking EVERYWHERE in Europe! Rain Rain and more rain! what about where you are?
Old Jan 13, 2011 | 02:00 PM
gothmdoc's Avatar
gothmdoc
Nice, I'm going to remove my boot handle to wrap it soon, this thread was just what i was looking for! Hopefully shouldn't be too tough, but good idea with taping the wires down
Old Jan 14, 2011 | 05:41 AM
tmo8462's Avatar
tmo8462
What are you going to do it with? I suggest vinyl, if so I suggest the wet method. Very easy to do and with the curves on the boothandle makes it harder to get the vinyl right. Also a heat gun. Good luck hope to see some pics. I haven't been on here for a while now. I'll have to take some pics to show off some.
Swoosh sorry yet again for taking so long to get back to you. The weather down here has been pretty good lately. I know it's about 8 months later, but better late than never. To kinda give you a run down on what the weather in Southern Spain is; Rain during the winter no snow about November to end of December time. Jan-April still a little chilly out and rains every other day but off and on all day. So November to April rain. May starts getting a little warmer, about 70's-80's (F)and sunny. June to August it's prefect weather! 90's(F) and up. Sunset isn't until about 10-1030pm. August and September is pretty much the regular fall time. A little chilly out, jacket weather and late sunsets still and really nice weather. October is a toss up month. It's warm one day and chilly the next. I'd say if your going to make a trip down be sure to bring something to clean the bugs off during the spring/summer time. They are really bad and our windshield angle doesn't help out at all with them. When driving out with my friends, we have to stop every so often( 45 minutes) to clean our windshield off. I'll be gone probably by the time you make it down towards my way again. Getting out in May and shipping my car back to the States around April.
Old Jan 14, 2011 | 06:00 AM
jeanstpierre's Avatar
jeanstpierre
when replacing the boot handle make sure the gasket is put on properly and not kinked or crooked. I had a problem with the boot latch and after the dealer replaced the boot handle the boot opened by itself when it got wet because water (from rain or washing) seeped inside the handle and got the eletronics wet. Dealer had to take it off again and let it dry completely.they found the gaslet had been put on incorrectly thus allowing moisture inside.
Old Jan 9, 2013 | 09:10 AM
sikamini's Avatar
sikamini
Is there a diagram or pictures of this handle with location of garkets? I looked at the wiring connector, but I'm a bit unsure where it disconnects. Lastly how do you separate the two plastic pieces without breaking the clips....any tips appreciated!
Old Jan 12, 2013 | 07:18 AM
sikamini's Avatar
sikamini
Any tips?
Old Jan 12, 2013 | 09:48 AM
rkw's Avatar
rkw
What two plastic pieces are you talking about (post pics)? What is your goal?
It's been years since I took off the handle to install a rear camera on my R52, but I don't recall anything unusual or complicated. There are some diagrams of the handle here:
http://www.motoringfile.com/files/rear_camera.pdf
The parts catalog shows a gasket piece (item #14):
http://realoem.com/bmw/showparts.do?...80&hg=41&fg=60
I don't remember the type of connector it uses, but like other connectors on the car, you just pull it off or there might be a catch or tab that you have to release while pulling.
Old Jan 22, 2013 | 04:47 PM
MotorWorf's Avatar
MotorWorf
Has anyone seen chrome door scoops for the rear door handles on the Clubman? Like the the ones being so for side doors?
Old Jan 23, 2013 | 05:31 PM
sikamini's Avatar
sikamini
what two plastic pieces are you talking about (post pics)? What is your goal?
It's been years since i took off the handle to install a rear camera on my r52, but i don't recall anything unusual or complicated. There are some diagrams of the handle here:
the parts catalog shows a gasket piece (item #14):
i don't remember the type of connector it uses, but like other connectors on the car, you just pull it off or there might be a catch or tab that you have to release while pulling.
This part, I want to detatch the electrical without breaking anything.....remove the yellow cover from the black back piece. I need to unstick the locking mechanism....
Old Jan 23, 2013 | 06:07 PM
Melangell's Avatar
Melangell
Seriously... Give it up, walk away before someone gets hurt.
Old Jan 23, 2013 | 06:30 PM
sikamini's Avatar
sikamini
Old Jan 23, 2013 | 10:25 PM
rkw's Avatar
rkw
That connector will disconnect. Many connectors on the car have some kind of lock so they won't come loose from vibration. If it doesn't just pull apart, there will be a tab to push or pull to release it. You have to examine and look at how the parts fit together.
However, if your hatch locking mechanism is sticking, fiddling with the handle won't help. The handle has nothing more than an electric switch. The locking mechanism itself is inside the hatch door. You should be able to access it by pulling off the interior panel of the hatch.
Filmy
15
Jun 6, 2023 06:27 AM
67morris
Dec 1, 2015 12:53 PM
Classic R53
Nov 5, 2015 01:39 PM
MAGICIAN
Oct 13, 2015 09:29 PM
MINI MX
Sep 25, 2015 07:28 AM
