Interior/Exterior gearknob
Old Jan 22, 2010 | 10:24 AM
bean44's Avatar
bean44
gearknob
hello ive got an 04 mini anyone know how to remove the gearknob and refit a new one thanks anyone
Old Jan 22, 2010 | 10:48 AM
Aeromax's Avatar
Aeromax
To remove the stock gearknob, just pull up. HARD! Don't hit yourself in the face.
If you want to put on an aftermarket ****, you'll have to get some sort of adapter for the OEM shifter. Aftermarket shifters come threaded, with adapters for OEM *****.
Old Jan 22, 2010 | 11:25 AM
bean44's Avatar
bean44
thanks ill have a try
Old Jan 22, 2010 | 01:40 PM
MrCooperS's Avatar
MrCooperS
Moderator
I would suggest, wrapping the gear in a towel/cloth and then pull. Make sure your chin/face is not on top of the gear when you pull. And if you have a sun roof, you might want to open that too since it's your first time. You might come out swinging!
Old Jan 22, 2010 | 02:08 PM
ZippyNH's Avatar
ZippyNH
Yup...it would suck to hit it with a ring on, shatter it, and get stuck replacing the entire thing!! I bet somebody has done it....or just broke a few fingers!!
Old Jan 22, 2010 | 03:16 PM
Bigshot's Avatar
Bigshot
Best method I have had described was to face the rear of the car straddling the shift **** and putting your shoulders against the seat backs.
Old Jan 22, 2010 | 05:41 PM
FranticFreddy's Avatar
FranticFreddy
Put it in 2nd gear, grab the **** with both hands and pull up. It lets go all at once. And, yes you might want to open the sunroof if so equipped. Once it comes off you will realize how simple it is. And I replaced it with a Whalen Shift ****. That makes life a whole lot easier.
daveke
Jun 18, 2017 07:34 AM
MattyKHZ
Jun 1, 2012 12:14 PM
phil@detailersdomain
Detailing 101
Sep 6, 2009 10:25 AM
Mab01uk
Apr 5, 2007 08:16 AM
