Interior/Exterior Stuck Shift Knob
Old Jun 5, 2009 | 06:17 PM
FlipitFloyd's Avatar
FlipitFloyd
Stuck Shift ****
Like everyone else I was ready to replace my stock shift **** and went ahead and bought one from another NAMer. I assumed the stock **** would simply twist off but no matter how many profane names I call it the thing won't torque off. I tried pulling up the cover and checking for a screw or something underneath but I couldn't find the answer. Does it simply twist off? Am I missing something? Please help me out. I really want to put my new JCW **** on.
Old Jun 5, 2009 | 06:24 PM
claancy's Avatar
claancy
Do NOT twist. Just pull...HARD. I find it's easiest if you put the transmission in 2nd and brace against the dead pedal. (This is of course assuming that you have a manual... no clue for the automatic.)
Old Jun 5, 2009 | 06:33 PM
miniconcarne's Avatar
miniconcarne
REAL hard straight up. Open sunroof, if applicable, and watch your forehead!
....this is an OEM ****?
Old Jun 6, 2009 | 12:33 AM
rcantu's Avatar
rcantu
yeah if OEM you pull the **** up.
Old Jun 6, 2009 | 07:40 PM
Act_04's Avatar
Act_04
When I did it I put my left foot on the driver's seat, right foot on the passenger's seat, butt perched between the two about shoulder level, and pulled up. It actually popped off pretty easy cause I could use my legs for power. Don't hit yourself in the face.
Old Jun 6, 2009 | 08:12 PM
howsoonisnow1985's Avatar
howsoonisnow1985
Just Pull hard on the **** while holding the shaft down. And wala, it comes off.
Old Jun 6, 2009 | 08:16 PM
howsoonisnow1985
BTW if you are also doing the handbrake lever good luck with that cause basically ripped it apart
Old Jun 8, 2009 | 11:26 AM
FlipitFloyd
Haha thanks guys! Act 04 I actually used your squat lift technique and while a felt rediculous in my car it was extremly effective. The JCW **** is 100 times better but taller than the OEM ball so now its time to chop down to a shorter shifter. Thanks again for the advice everyone.
Old Jun 8, 2009 | 10:26 PM
Act_04's Avatar
Act_04
YES! It does feel silly, but works really well.
Old Jul 13, 2009 | 08:30 PM
Eirerogue's Avatar
Eirerogue
I was totally spent trying to unscrew mine tonight and thought of turning here for advice. Thanks for posting this!
Old Jul 13, 2009 | 09:13 PM
MrCooperS's Avatar
MrCooperS
Moderator
Hmm... I must be strong. I can pull it off with just one hand.
OutMotoring
Mar 3, 2017 06:29 AM
gar56
Nov 15, 2016 06:41 AM
MINI Stupor
Oct 1, 2015 11:36 AM
aldito2
Sep 30, 2015 10:44 AM
kevinlhr310
Sep 27, 2015 02:31 PM
