Interior/Exterior Headlight ring removal
Old Mar 23, 2009 | 06:07 AM
PortMCS's Avatar
PortMCS
Im getting ready to remove my lights and paint the insides. In doing so, i want to paint the rings while im at it with some Plastidip. My question is, i kinda got it figured out how to remove the lamps, But do the rings just snap back into place ? Or do i have to use some silicone to re-apply them ?
Old Mar 23, 2009 | 10:53 AM
glnr13's Avatar
glnr13
double stick tape holds them in ALONG with the clips that are VERY easy to break.
to remove, best to start from the bottom three clips, get those undone, then slide it upwards. the OEM double stick tape will make it hard to slide it off but it'll come off if you keep working it.
Old Mar 23, 2009 | 11:17 AM
PortMCS's Avatar
PortMCS
Thanks !
so did you reuse the double-stick tape thats already there ? Assuming it will still stick well once i get ready to put them back together
Old Mar 23, 2009 | 12:01 PM
glnr13's Avatar
glnr13
i bought some double stick tape at auto parts store. grabbed the slimmest they had, exact match to the oem stuff. i cant remember what size though :(
Old Mar 23, 2009 | 01:29 PM
PortMCS's Avatar
PortMCS
NP ! Thanks for the help !
I'm gonna look around Home Depot as I gotta get Plastidip anyway
Old Apr 28, 2009 | 08:31 PM
luvlee's Avatar
luvlee
how to you get the headlight assembly off? I want to paint the rings but I'd rather remove the whole light
Old Apr 28, 2009 | 09:41 PM
xnotfunkylex's Avatar
xnotfunkylex
3 bolts on the back. Open the hood and look behind the lights. Should see them pretty easily.
Old Apr 28, 2009 | 09:44 PM
luvlee's Avatar
luvlee
If I happen t change my mind and want to remove the rings and washer cover without removing the light, how would I do this without breaking it? Where are the tabs located? Do I just pry it out?
Old Apr 29, 2009 | 07:09 AM
JohnnyVillan's Avatar
JohnnyVillan
You have to remove the light to get the rings off
When you take the light out, you'll see the tabs
Old May 17, 2009 | 12:52 PM
h20polo93's Avatar
h20polo93
so to remove the rings its not too hard you just have to take the light out and push the tabs? thats it
Old May 17, 2009 | 02:15 PM
4Boogie's Avatar
4Boogie
all throttle no bottle
use a flathead to carefully pry the rings off the light, work your way around it
Old May 17, 2009 | 09:16 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
The ring is stuck on with double sided tape, so just prying at the tabs won't get you far. You must be very careful thanks to the tenacity of the tape.
dyeLucky
Sep 11, 2015 10:41 AM
greekzilla
Aug 23, 2015 03:44 PM
kpl
Aug 11, 2015 04:52 AM
dyeLucky
Aug 7, 2015 07:10 AM
